Question about Toshiba Computers & Internet
Toshiba laptop shows that is receiving power but does not power up and battery will not charge
  • 10,319 Answers
You can take both units to redio shack and they can tell you if the powersupply and the battery are any good
. if you have a volt merter with its instructions you can test these your self
Posted on Aug 07, 2010
What wrong with my computer?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 20, 2013 | Toshiba Satellite L750 Notebook
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
Is there any way to get past the EC power restriction foir BIOS FLASH...My L675D-S7049 Toahiba Laptop had a DEAD (Totally) battery due to a friend...AC shows input but NO CHARGING with new battery (OEM)...
The bios will and does not affect battery charging. Battery charging is carried out before the system and is a switch mode charger on board before the processing. If it required the processor to work and a bios, it would not charge when switched off!
I would suspect the OEM battery for the flashing light but the laptop should switch on with just mains power.
Has it been overheated?
May 29, 2012 | Toshiba Satellite Black 173 L675DS7049...
Hello there, I own a toshiba c655-s5049 laptop about a year. When I connect a charger taskbar icon shows plugged-in, not charging and the front panel power/battery indicator lights green not orange. When...
Take some alcohol and a q tip and wipe the battery terminals and the terminals on the battery compartment. The laptop not getting a good connection with the battery
Aug 07, 2017 | Toshiba Satellite C655-S5049 Notebook
I replaced my toshiba battery the 4000mAh to a new one 7200mAh 9 cells but it is not charging on windows its only charge when i shutdown the computer but the win 7 shows me that the cable is plugged in but...
The charger that you had for the 4000mAh battery was strong enough to charge and power your laptop at the same time.
Now that you have increased the capacity of the battery you need a charger that is powerfull enough to charge the battery and power your laptop.
You need to purchase a stronger charger/power brick.
Take care!
damnor01
Apr 24, 2011 | Toshiba LiIon 7200mAH 9 Cell Battery
The toshiba laptop a505 S6980 will not charge the battery when the AC is plugged in and dies immediately if unplugged . Meters shows 0% available (plugged in), charging. But it is not really charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Apr 20, 2011 | Toshiba Satellite L500-ST2521 Laptop AC...
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Regards.
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
New battery charges but won't work
YOU HAVE A FUALT CONNECTION TO THE BATTARY AND NOTEBOOK POWER SUPPLY AND MAY BE A WIRE COME LOOSE INSIDE THE LABTOP
ROD
Feb 04, 2009 | Toshiba Satellite A105 Notebook
Toshiba A100 Power problems
here are few laptop troubleshooting guide to troubeshoot ur laptop. it has one post about power problem of laptop.
I hope this laptop troubleshooting help to solve ur problem. or chekc ur laptop with another working battry or try to start laptop to without battery. and chekc ur power cable for charging is working or not
May 05, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
47 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
