Question about Audiovox Televison & Video
Audiovox CD Player TK5001 Plays for a little while then stops. Also will not play continuous. Don Coleman
ice man
  • 68 Answers
SOURCE: Player only plays first 3 tracks on CD and then stops
the emitting diode is not shiffting right..it might need some cleaning of its track..open it and check it out. good luck
Posted on Apr 25, 2007
  • 36 Answers
SOURCE: CD won't play; continually shuffles from one CD to another
did it just start doing this....how long have you had the unit for?
Posted on Dec 31, 2007
SOURCE: CD player stopped readiing disc.
Same here. The open/close CD door button doesn't work either. Did you ever get this resolved? -pokie
Posted on May 08, 2008
  • 99 Answers
SOURCE: NAD C541i CD Player plays but...
hi, i've had a few nad C541i's and not so long since the sound on one of them cut out for milliseconds and on some occasions the sound would make the noise very much like a severely scratched vinyl record, i thought it was a faulty laser so i tried another KSS-213C laser out of a scrap kenwood and the fault persisted. to cut a long story short, i took the main PCB out and there were various dry joints. once these were resoldered i was blessed with a fully functioning player. hope this helps?
Posted on Feb 02, 2009
SOURCE: my ford ka cd player only plays out of one speaker
When I first got my Ka, the wiring between the car and the door was snapped. If you open the door there is a rubber tubing, if u assume 2 wires are snapped and try 2 pull them together through the rubber tubing you should hear a crackle if thats the fault. Even if you do not, it will almost certainly be this. To fix it, you need 2 use a stanley knife 2 cut open the rubber tubing then connect the to snapped wires together. I did this by getting a small amount of speaker cable and adding it 2 both ends, using plenty of insulation tape. This is the most common fault for speaker problems in the Ka.
Hope this Helps
Ashley
Posted on Feb 03, 2009
My cd runs but will not play the cd
Quite common problem. Repair it or replace your player if repair cost is too high.
Personally, I stopped using CD players time ago: I use a mp3 player.
May 13, 2015 | Audiovox Car Audio & Video
When playing cd's the player skips and then stops when the second part of the disc is reached?
If the CD plays correctly in some other player (or in the CD-player in your vehicle), then your Panasonic CD-player is the cause of the problem. If under warranty, get it replaced. If not under warranty, purchase a replacement.
Jan 04, 2015 | Panasonic Home Theater System System
Panel lights up, plays CD, plays iPod, but none of the controls work.
switch off, remove battery and replace it after two minutes. switch on. Goodluck Mark
Dec 03, 2013 | JVC KD-HDR50 Car CD/ MP3 Player
Error message (protect) cd plays then goes silent then plays again. have cleaned laser several times with cd cleaner disk.
Dirty lasers don't cause "protection" problems. Are you sure thay message is displayed on the CD player? That word is nowhere in its manual.
May 22, 2011 | Onkyo DX-C390 6-Disc CD Changer
Dvd player stopped working. I put dvd in and it starts turning and says loading and then says no disc & stops turning.
Hi there
Two things can cause the problem you are experiencing,
1.the dvd you are trying to play is bad or
2. the lens of your dvd player is bad
What you should do is to try playing several dvd's to see if they work,if they all do then the particular dvd you are trying to play is bad
If some do not play then the lens is bad ad you should open up the dvd player and clean the lens with a cotton wool dabbed in a little bit of methylated spirit
after cleaning,test the dvd again to see if it plays.
If the problem occurs again,the best solution is to replace the lens of the player because it has become too weak..
Jul 04, 2010 | Audiovox D1718PK Portable DVD Player with...
Plays just a little bit of song and on to next song
FAT or NTFS is damaged reformat and upload music again if continues have the memory tested at service center
Apr 19, 2009 | Sears GC-822 MP3 Player
Noise while playing cd or dvd
the top spin needs more plastic grease
Mar 11, 2009 | Audiovox VM9311TS
Play audio CD
need to clean the lense of the cd player . must be some fine dirt on the laser head
Dec 31, 2007 | RSQ NEO-C320 DVD Player
Televison & Video Logo
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
