Question about Whirlpool LER5636P Electric Dryer
I have a Whirlpool electric dryer (LER5620KQ1). It gets warm but not hot. It takes 3 cycles to dry 1 load of clothes.
  • 12 Answers
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
If your element is operating and drawing about 20 amps when on, your problem may be the thermostat (temperature dial) or the moisture sensor (if applicable).  My dryer has 2 heating elements.
Posted on Oct 15, 2007
jsrock516
  • 5911 Answers
SOURCE: dryer
Normally when a dryer starts to exhibit longer dry times, it could be an indication of some required maintenance. A dryer needs air to breath. Proper ventilation is required for the heating circuits to regulate the internal air temperature properly. If you have to keep placing items back in the dryer to dry again, or the dryer just doesn’t seem to be putting out hot enough air, it may be time to think about checking the dryer vent ducting (a simple separation of more dense clothing from lighter weight clothing can help shorten dry times too). If the heating circuits are starved for air they actually OVERHEAT and can cause problems. When an overheat condition occurs, the hi-limit thermostat is supposed to open to shut off the heating element. This is how the dryer regulates its heat. However, if the hi-limit thermostat malfunctions, the Thermal Cut-Out will blow. This device acts as a fuse, is not resettable, and has to be replaced. This also means that the hi-limit thermostat could be suspect and it should also be replaced at the same time. Most manufacturers recommend replacing the two components together and are sold as a set.
Now...if your dryer has been having problems drying, the first thing you need to check is the ventilation ducting to ensure that it is not kinked or clogged. Poor air flow is the number one cause of dryer failures. Not to mention it can cause fires due to lint backing up inside the dryer. This could be the "electrical" smell a lot of people complain about. If lint accumulates on the heating element it will smolder and burn. It is often reported that you should clean your ducting twice per year. I recommend the ducting be checked (this means inspected to see if it needs cleaning) thoroughly about once per season. That's 4 times per year. If you've never cleaned the ducting, or your dryer is pushed all the way up against the wall causing the ducting to become kinked, you will have air flow problems. One way in determining air flow is to remove the vent hose from the back of the dryer and start the dryer (of course, you need a working dryer in order to do this). The air should be forceful and slowly warm up to about 140 degrees. If the air flow is weak, you may have a clog inside the air baffle of the dryer (this is where the lint screen slides into). If the air flow is good, reattach the dryer hose and check at the output of the dryer vent as it exits your home. If the air flow is weak or non-existent then you know you have a clog in the vent line somewhere. Periodic cleaning will go a long way towards preventing future clogs. Dryer vent rule of thumb: The SHORTER and STRAIGHTER the vent line, the BETTER. Everywhere you have a bend or kink is an area where you will create potential collection points for lint. Poor dryer maintenance is also one of the frequent causes of house fires.
How to troubleshoot a dryer: If your dryer has the lint screen on top of the unit, you will need to remove the back panel to get to the heating circuits. If your dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by pushing in on the release tabs with a putty knife. They are located along the front seam about two inches in from each side. CAUTION: It is recommended that you unplug the dryer BEFORE servicing the inside or cleaning. There are still dangerous voltages present even with the machine turned off.
Symptom:
Dryer Runs, But Does Not Heat:
Suspected Components:
1. Heating Element (located inside the heater box) - Resistance reading should be 9-13 ohms.
2. Thermal Cut-Out (located on the heater box) - Resistance reading of 0 ohms.
3. Hi limit Thermostat (located on the heater box closest to the heating element leads) – Resistance reading of 0 ohms.
4. Operating Thermostat (located on the air baffle) - (May have 4 wires attached to it). Will read 0 ohms across one set of leads, approx. 7 ohms across the other.
5. Bad Heater Relay (usually located in the console) – this is not equipped on all model dryers. However, on dryers that DO have them, this acts as a switch and turns the heater circuits on at the push of the START switch.
Dryer Does Not Run At All:
1. Thermal Fuse (located on the air baffle) - Resistance reading of 0 ohms. NOTE: If the thermal fuse is blown, the drum light will not come on.
2. Broken Drum Belt - If dryer is equipped with a broken belt relay, this will shut the dryer down.
3. Broken Door Switch - If the door switch is broken, this will shut down the entire dryer as no power is applied to the start switch with the door switch open.
4. Bad Start Switch - If the start switch does not toggle close or stay closed when released, the dryer will not start.
5. Bad Timer - If the timer does not function the dryer will not start.
6. Bad Drive Motor - No Motor, drum does not rotate, heating circuits may or may not function. DOUBLE CHECK the CONNECTOR PLUG on the Drive Motor. I have found situations where this plug came loose for whatever reason and caused the dryer to either shut off completely or work intermittently.
7. Bad A/C Receptacle and/or Connector Plug - If you aren't getting the proper voltage to the dryer, it will not run.
These recommendations for TROUBLESHOOTING are not all inclusive as different manufacturer models vary in components and configuration. However, the general cleaning maintenance and proper ventilation requirements should apply to ALL dryers.
Posted on Mar 26, 2008
maklean
  • 1665 Answers
http://www.repairclinic.com/0088_8_1.asp
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Type in model No at search tab to find parts availability
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Jul 15, 2008
  • 3422 Answers
SOURCE: Frigidaire GLGQ642A Gas Dryer Problem - runs warm - cycles hot then cool
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Posted on Aug 11, 2008
jsrock516
  • 5911 Answers
SOURCE: whirlpool ler5620kq1 electric dryer
If you have verified the voltage at the wall receptacle and at the terminal block in the back of the dryer to be 220-240VAC, you need to check the Thermal Fuse inside the dryer to determine if it is still good. On your dryer, the thermal fuse is located behind the back panel on the blower fan housing. To access, follow these steps:
1. UNPLUG the dryer before servicing. Dangerous voltages are still present inside the dryer with the unit turned off.
2. Remove the dryer vent hose from the back of the dryer.
3. Remove the back panel by loosening all screws holding the panel in place.
4. The blower fan housing will be located on the lower left-hand side (as viewed from the rear).
5. Look for a small white plastic component on the housing. This is the Thermal Fuse.
6. Remove the wire leads and perform a resistance check. If good, the fuse will read about a short (0 ohms). If bad, it must be replaced.
Illustrations of your dryer are available at searspartsdirect.com. Just type in your model number and look for item number 7 under the "Bulkhead" heading. Repairclinic.com and appliancepartspros.com are also excellent sources for finding parts.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Jan 14, 2009
Clothes take about 2 times longer to dry than other dryers that I have owned. Thanks
could be the filter is clogged, or that the load to cycle issues are different...is this electric or gas?
Apr 21, 2008 | Dryers
Dryer won't dry clothes
How to check the timer:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 26, 2012 | Whirlpool Dryers
My extra large capacity Whirlpool dryer does not dry in one cycle. Even if I only put a small load it takes at least 3 cycles to dry
There maybe an air flow issue. With the dryer on check the air flow from the exterior location of your home. There should be a good flow of warm/hot air coming out. If not the inside of the dryer may be full of lint.
Feb 21, 2011 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
Whirlpool dryer does not get hot enough to dry clothes.
Clean/repair the dryer vent. If the airflow is restricted the result is the one you just described.
Good luck,
Vlad
First Choice Appliance
Apr 20, 2010 | Roper REX4634KQ Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Whirlpool Dryer has trouble drying (LER5620KQ1)
Hi rfairess
it sounds like the high limit thermostat is cutting out and not resetting itself.
Sep 16, 2008 | Whirlpool LER5636P Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
178 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
