Question about Intex 15' x 36 Fast Set Pool w/ Filter Pump, Ladder, and Cover
My inflated rim around my pool is leaking air. I have notice some yelloyish stain on top of the rim with a in hole. I also notice that the rubber is king of thin in that area. Do you have any idea what could have cause and how to repair?
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. Most places that sell these pools also sell the repair patches that will repair the leak.
Posted on Aug 07, 2010
WANT A SOLUTION AS TO THE RIM I HAVE TO PUMP UP TWICE A DAY WHAT DO I DO ????????
There will be a hole in a seam most likely. Take some soapy water and go around the seam on the top rim where it goes together and locate your leak.
If the top won't stay full of air there is definitely a leak.
Rod
US Parts Center
888-521-6183
Mar 04, 2013 | Intex 2500 Gal Easy Set Swimming Pool...
WHAT DO I DO INTEX POOL RIM GOING FLAT WANT A SOLUTION PLEASE
If the top rim is going flat there is a leak in the material somewhere.
there is no other reason for the air to go out of it if there is NOT a leak at some spot.
Suggest you use some soapy water and go around the complete area starting with the seam areas.
Rod
US Parts Center
888-521-6183
Mar 04, 2013 | Intex Pool & Spa
2004 kawasaki 110cc took apart back tire area and have a thick metal cylinder shaped object and forgot where it goes
hi there hicks32
that metal object is a rim loc , it should have a rubber top bonded on it , this fits into another hole other than the one that the tube valve stem goes into
you should have 2 holes ,fit rim tape, fit one side of the tyre bead, instal rim lock ( with rim tape running over the rubber on the rim loc ) fit the washer and nut losely on the rim loc bolt stem by at least 4 or 5 threads fit the tube as you normally would, push the rim loc stem fully up ( so that the nut rests on rim )do not let the rim loc stem receede into tyre ) refit the other tyre bead and inflate the tyre and seat the beads on the rim , tighten the rim loc nut and the valve stem nut
make sure that that both rim loc and valve stem are straight when inflated and tightened
refit your wheel
cheers pauly46
Jun 08, 2011 | kawasaki Motorcycles
The tube around my intex pool has a leak, how do I find it and fix it?
Your picture above is of a pool float, but I assume you are talking about an inflatable ring pool. Is that right? If so, this link will take you through a tutorial on how to find and repair pool leaks:
http://www.backyardcitypools.com/vinyl-pool-liners/Swimming-Pool-Leaks.htm
Jun 20, 2010 | Creek 4 River Run Inflatable Inner Tube ...
I noticed my pool was leaking air. I opened the upper ring blow up valve and there is hole inside of it. Can this be repaired? I would hate to get rid of my pool just because the air valve has a hole...
Take a 12 X 12 piece of plastic wrap, wet the pool ring, slide the plastic sheet along until you see the air bubble appear, mark leak with marker pen. Use repair patch. I swear this is better than soapy water!
Jun 19, 2010 | Intex Easy Set Pool 15x36
The top ring on my easy set pool leaks air. How
I suppose the pool is already full of water. You could remove some of the water, then use soapy water and a paint brush to find the leak. Bubble blowing liquid is ideal for this. This will be easier on the the outside than on the inside. Once found, you may be able to fix with duct tape. But they sell repair kits that probably work better. Don't use a tire or bike tube patch - those are for rubber. I hope this helps you, and I hope the kids have fun in the pool this summer! Al K
May 25, 2010 | Intex Easy Set Pool 15x36
Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
May 20, 2010 | Intex Easy Set Pool 15x36
Above ground pool is suddenly sinking down-losing air pressure
possible leak in lower or outside seam or cap for inflating
Jun 14, 2009 | Zodiac Pacer Pool Cleaner
Mounting Tubeless tire on Rim of riding lawn mower
With the mower jacked up place a belt or rope around the center of the tire all away around and draw it tight. Apply pressure and when the tire starts to fill you can release the belt. Apply pressure until you hear the bead pop, indicating that it has a bead lock to the rim. Let the air out to the right pressure, check all tire pressures and set the deck to level. Go mow your lawn.
Jul 16, 2008 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Intex 15' x 36 Fast Set Pool w/ Filter Pump, Ladder, and Cover Logo
162 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
