Question about SkyScan 86709 Atomic Wall Clock
The outdoor temperature transmitters are not working for both 88800/88801 and 28700 modles. I have replaced the batteries and reset the clocks several times but no temperature readings. Where can I get replacement temperature transmitters and at what cost?
  • 7 Answers
SOURCE: outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Posted on Dec 19, 2008
  • 7 Answers
SOURCE: OUTDOOR TEMPERATURE
Also,
  • 3 Answers
SOURCE: 3M Precision Digital Atomic Wall
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Posted on Jan 15, 2009
  • 3 Answers
SOURCE: outside temperture
Try changing the batteries in the CLOCK. I had the same problem in a 3M similar clock and it didn't read the transmitter correctly or eventually, at all, when the CLOCK batteries were getting low.
SOURCE: Temperature Transmitter
I have already try putting in new batteries and taken out of the clock and the trasmitter and still dont work what can i do now its a SioScan Temperature Transmitter 433 MHz
Posted on Sep 19, 2009
I have eight atomic clocks,none of them have the outside temperature working,all have new batteries???
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
Oct 20, 2014 | SkyScan 86742 Digital Atomic Wall Clock
Medion md41199 atomic clock, cannot get the outdoor temp to show, how to fix please
Remove ALL batteries in transmitter AND clock.
Insert new batteries in outdoor transmitter.
Insert new batteries in the (receiver) clock.
Wait until outdoor temperature is received AND displayed on clock BEFORE setting time/date/etc.
Mar 11, 2013 | Audio Players & Recorders
The wireless transmitter doesn't work
Mine quits working when the batteries in the outdoor part need changed .
Dec 15, 2017 | Centrios Audio Players & Recorders
Outside temperature not working on Atomic Clock (was working last night). Changed the batteries in both the outside transmitter and the clock tonight. Clock reset within minutes, but the outside...
hello lucy... you most likely have some corrosion in the outdoor component. Remove the batteries from the outdoor component and clean the battery contacts with the eraser end of a common pencil. Reinstall the batteries and then give it up to 8 hours to start reporting accurately again. Joe
Thanks for choosing Fixya!
Feb 18, 2011 | SkyScan 86709 Atomic Wall Clock
How do I get the outdoor temperature to work on my Sharp Atomic clock, have replaced batteries in both clock and transmitter and reset numerous times
Hello jdb..... The outdoor transmitter needs to undergo a wee bit of maintenance. Remove those new batteries and clean the battery contacts with the eraser on the end of a common pencil. Then replace the batteries. IF you notice that the batteries slide in easily, use a small flat blade screwdriver to gently lift the battery contacts to increase the contact when you do slide the new batteries in. Joe
Dec 19, 2010 | Baby Gear
Thermo clock RAR312 not picking up outdoor transmitter temperature. Replaced battery but still nothing.
take a paper clip and reset the reset button located in the battery compartment. Then, try each of the 3 channels until you get a reading in the outside temp field. Wait a good couple of minutes at each channel setting before determining the units are not pairing. Do this with the units side by side for signal acquisition, then once acquired, move the remote sensor outdoors. Hope this helps!
Sep 24, 2010 | Office Equipment & Supplies
My clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Nov 16, 2009 | SkyScan 86709 Atomic Wall Clock
OUTDOOR TEMPERATURE
Also,
Sep 03, 2008 | SkyScan 86709 Atomic Wall Clock
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
You need new SioScan Temperature Transmitter 433 MHz. Take a look on amazon La Crosse Technology TX6U Wireless Temperature Sensor for 433 MHz units.... Hope this was helpful. cheers
Oct 16, 2007 | SkyScan 86709 Atomic Wall Clock
SkyScan 86709 Atomic Wall Clock Logo
93 people viewed this question
Top SkyScan Home Experts
nejones57
nejones57
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
