Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
Problems with power supply not working. There also seems to be an issue with the driver
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
Vostro 230 - Solid Amber Power Light
"power supply seems to be working?" If you had before this happened a issue where had to turn it on a few times to get it up---suspect bad caps in power supply---A look inside that will tell you if this is the issue or not. If the supply can be removed (most can) it can be examined or tested by most repair shops for little or nothing.
see attached photos of what bad caps look like in case you remove the supply to look at it.
Jun 15, 2012 | Dell Vostro 320 Desktop Computer
2.8 gb CPU/1.5 gb mem/IBM ThinkCentre a50p 9183/windows XP I replaced power supply from 230 to 400w and put in a new amd radeon 9600 XT graphic card (256 mb) and booted it up fine and installed the...
Prime95 won't tax the video card, you'd need something like 3Dmark or Everest. It's most likely a power issue. Upgrade to a 500W minimum, the higher the better. Check NewEgg, Slickdeals.net, dealzon.com for deals. The power supply's the last place you want to cheap out - get a good one.
Mar 29, 2011 | IBM Computers & Internet
My Pioneer DVR-520H DVD Player works fine but sometimes when it is powered off the power just goes completely. When this happens I plug it into a different socket or just pull out the power cable from the...
It seems problem with power supply board in Pioneer DVR-520H, possible causes for that symptoms are few dried up/ leaky capacitors, cold/ dry solder joints on circuit board or chip resistors would be devalued.
Local repair shop will help you to replace bad capacitors, chip resistors in power supply board to solve this issue if you are not familiar with soldering work in circuit board.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 11, 2011 | Televison & Video
Is there anyone who knows if graphic card Readeon HD 6870 works with the motherboard Gigabyte GA-P35-DS3. I have already mounted the card but encountered problems getting signal to the monitor. Would be...
There is no reason why this graphics card should not be working. The Gigabyte GA-P35-DS3 has a PCI-Express 16x slot. The HD6870 requires at least 194W at idle and 320W under load (when playing games or video encoding). This leads me to believe that maybe the card isn't getting enough power.
The HD6870 needs 2X 6pin power plugs as show below directly from your power supply.
Motherboard power is not enough so make sure you have connected these plugs firmly and that your power supply has the relevant plugs.
If your power supply doesn't have two 6 pin power plugs then you can use the molex to 6pin coverters that came in the HD6870 package shown below.
Jan 09, 2011 | Sapphire RADEON HD6870, (1 GB) DDR5...
Mouse keyboard and video are not working. I have changed the motherboard and power supply and still having the same issue
First of all you update your drivers ,,,,,,
it seems that there is problem with your mouse and keyboard connector ,check those things ,,,,,,,,,,,,,
Jul 05, 2010 | Gateway E-6100-C PC Desktop
Philips 107 E5 Monitor; display compressed into lower half
This is partial frame collapse and can be caused by a power supply issue supply the frame driver or the frame driver circuit has a problem with an IC or driver transistor. It should be relatively cheap to repair at a computer or TV shop but you may want to consider buying a cheap replacement monitor from eBay etc as the repair may cost you more than the replacement given everyone seems to be dumping CRT based monitors in favour of newer LCDs etc.
Aug 30, 2009 | Philips (6G3B11) for 107E51, 61, 107T51, 6...
My HP pavilion wont start up.it will sometimes but for the most part it won't. it takes me to a screen to repair startup problems but never fixes the issue.
Check the power supply. You can do this by opening up the case and hitting the power button. If the fan on the back of the power supply and the fans internal in the unit all turn of then it is not a power supply issue and is a motherboard issue. This seems to be a power supply problem and will be around 100 dollars if you fix it yourself
Feb 20, 2009 | HP Pavilion s3020n (882780985063) PC...
Gateway FPD 1830 18.1 in. Flat Panel Problem
Usually in these cases the power supply would be the issue, but you say the OSD window shows up clearly, So the LCD panel is good and the Power Supply /inverter depending on which your FPD has.
FPD 1830 should have 3 boards(logic, Inverter, Power) otherwise just 2(logic, power)
If it is super dim, the problem is the inverter. Or the Power Supply if the inverter is embedded
Otherwise what your issue is the logic board, if you can swap out that part for a good one, Chances are for sure that you will have a spanking new FPD working.
I've worked with these a lot. Im working on one right now.
I hope this helps
Wish you luck
Victorsinferno45
Sep 11, 2008 | Gateway FPD 1830 18.1" Flat Panel LCD...
Computer Crashing-seems to be drivers or RAM
it sounds like you have one of three problems that it could be, first you may not have the proper drivers for the chip set. second you could have a bad CPU, or a bad or cracked mother board. i have gotten mother boards that were cracked in shipping and caused the same problems. if you have checked these let me know it will give me further info to work with. also I have found that cdertain sound blaster programs are not compatible with XP.
Dec 07, 2007 | Select Brands ALLPCZONE BRAND COMPUTER...
VP920 goes to sleep
Running Vista? Seems to be a pretty common problem. Thought it was a driver issue at first, since one of the newest released drivers listed a similar issue.
Aug 11, 2007 | ViewSonic VP920b 19" LCD Monitor
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
