I have a system malfunction in my carrier infinity system
Start by going to service in the advanced setup to see fault
Posted on Aug 07, 2010
  • gcochaslb Aug 07, 2010
    are you there? I did all of that already...
2 Suggested Answers
  • 15 Answers
SOURCE: carrier infinity control SYSTXCCUID01-B sensor communication erro
There should be a little black sensor bulb outside either on the unit normally under the electrical panel or inside it. It sound like the wire has come off or been disconected. It needs that on to properly run. Your control is trying to communicate with the outdoor unit and can not.
Posted on Jul 08, 2009
Red heating tab stuck. How do I remove the front plate to access tab. Carrier Infinity System.
I know the infinity, but I have know idea what a red heating tab is. Can you be more specific?
Mar 23, 2017 | Carrier Heating & Cooling
Lights blinking
The best information you could get is from Carrier. Here's their website:
http://www.carrier.com/homecomfort/en/us/for-owners/
There is a toll free number to call 1-800-Carrier (1-800-227-7437)
Apr 27, 2014 | Carrier Performance 2 Stage 17 Series 2.0...
I have the carrier infiniti system. When my thermostat reaches the set temperature it doesn't always shut off. I shut off the main control to let it reset. It works for a while and then it starts
Carrier Infinity system is a variable speed unit that will just slow down as it approaches set point. Unless it overshoots the set temperature (you have it set on 72 and the temperature keeps rising above 72) this just sounds like normal operation.
Nov 13, 2012 | Heating & Cooling
CARRIER INFINITY WEATHERMAKER WHERE IS THE RESTART SWITCH
Carrier Infinity systems, do not have a manual reset switch. It will have an automatic reset depending on the failure.
I would first, turn off the breaker to the indoor and outdoor units. Wait about 5 mins and turn the breakers back on. Doing this will reset the Control Board in the system. The system itself, is probably locked out.
This should get the system to come back on, However, you may have the problem come back and lock out the system again.
If this happens again, i would advise calling a Carrier dealer with Infinity systems to test it.
Hope this helps
Brian
Nov 28, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
We had a thunder Storm come thru and now the infinity control read "System Malfunction Call tech.
Turn off power to complete system and then restart it should clear. Rus Carrier Dealer
Jul 18, 2009 | Heating & Cooling
The Infinity Comfort Control code
Call your local Carrier dealer. They have code to get into system. Rusty Good system
May 21, 2009 | Heating & Cooling
Carrier Infiniti system, system maufunction on primary display
Call a Carrier service comapny and have them investigate further, when system malfunction comes up on the user interface usually there is a substantial problem.
Either that or the User Interface has gone bad and needs to be replaced
May 14, 2009 | Carrier Heating & Cooling
System Malfunction, No communication with outside unit
I work on Carrier Infiity systems. The outside board has a Model plug on it. This tells the system what size unit it is. They do go bad. You can reset your self by turning the power off to the Air Handler. These system have 10 year warranty and if you still have a problem have the replace the outside control board and model plug. Also you can contact Carrier on the their website and get answers. You may need to talk to a service rep in your area. Carrier is good about their Tech support. You should have to pay for a service call if you your problem continues. Sometimes power surges or stoem cause these problems but not often Rusty
Apr 26, 2009 | Heating & Cooling
Carrier Air Conditioner Infinity System - Air Handler Sweating & Duct Work Condensation
Either its not drainning mositure properly or low air flow across the "A" coils- caused by dirty filter .
Sep 12, 2008 | Heating & Cooling
Heating & Cooling Logo
3,280 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
