Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Does not turn on when plugged in. Is this a motherboard or capcitor?
  • Mitsubishi Master
  • 8,617 Answers
That model has been plagued with capacitor failure across the entire Chassis. However if the led is srtaedy blinking green you would need the V26 Chassis DLP DM / Power baord repair kit from www.tvrepairworld.com which does come with instructions. If your symptom is different they can also help assist with what repair kit will most likely solve the issue.
Posted on Aug 08, 2010
How to troubleshoot a mother board
to trouble shoot motherboard you need to know basic of motherboard there are mainly three thing s for motherboard to work first voltage +12v +5v +3.3v the motherboard then needs clock and reset to start adreesing the lcok is produced by the 14.318Mhz crystel and restet is produced by 32 khz crystel when the power is on first the clock has to be present for the reset to function if the clock and reset and there and the adress line is not still working means the elecrolitic capcitors are fult the capacitors in motherboard have huge role to play they are ones prvent audiolines entering the adress lines
Jan 29, 2011 | ASUS M2N-MX Motherboard
Tip
CHIPLEVEL SERVICE OF MOTHERBOARD
I AM A CHIPLEVEL SERVICE ENGINNER I DO CHIPLEVELSERVICING OF ALL MOTHERBOARD
FOR EXAMPLE THE SMPS FAN JUST INSTALIZING MEANS A DEAD SHORTING POWER SUPPLY SECTION OF MOTHERBOARD IF IT HAPPENS REMOVE THE PROCESSOR CHECK ALL THE POWER CONNECTION LINES FROM THE SMPS CONNECTION WITH ANY OF THE RESPECT OF GROUND IF ANY LINE IS FOUND SHORT CHECK WHICH COMPONENT IS PRIMERLY CONNECTED TO THE LINE AND REPLACE THEM
CONNECT THE PROCESSOR WITH ITS HEATSINK AND CHECK THE SYSTEM WETHER THE SWITCHING IS OK IF NOT CHECK THE POWER IC,RELEATED CHIP RESISTORS AND CAPCITORS,FET,TRACK OPEN
IF THE FET IS DAMAGED IT WILL SHOW INTIALL SWITCHING AT GATES IF IC IS DAMAGED IT WONT SHOW ANY SWITCHING
on Sep 11, 2010 | Computers & Internet
Thanks, this is an old and used computer with Intel P4 processor and intel motherboard D915GAV. It became dead silent and no component is powring up. Only the mother-boards light is ON when powered. I...
Thanks for the question its often problem in motherboard the power section in ur motherboard has the problem please consult a chiplevel engineer or if you know elctonics i can help you check the FETs the vrm section and the electrolytic capcitor for leakage
Sep 25, 2010 | Intel D915GAV Motherboard
Fan inside the house comes on and cool air comes thru vent but fan on outside compressor wont come on is is the capcitor
It could very well be the capcitor. If you have a duel capcitor (1 cap. that is used for both the fan & the compressor) the compressor may not run either. First and easieast try the capcitor. If thats not it and the compressor is running & all wires look ok than its probebly the fan motor.
Hope this helps;
John: From JONSCO A/C & HTG. BALTIMORE MD.
Aug 26, 2009 | Carrier Heating & Cooling
Tv plays sound but no picture or any signs of backlight
This sound is a capcitor pop and this could be in the power supply unit itself. The glass could be a fuse that took the brunt from the capcitor pop.
1. Unplug the unit and do not plug it in.
2. if its under warrenty take it in please!
3. if its not under warrenty and you know eletronics verify what cap popped and replace that and the fuse.
4. if you do not know about eletronics this work would cost you around $150 for the wrok done.
Good luck I hope this information helps you!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | Vizio L32 32 in. LCD HDTV
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Tv turns off after 5min,1-2 hrs
This will sooner or yet later get worse as time moves forward why?
You have a power supply unit gone bad in this TV.. The reason why I know is this the capcitors I call caps would look swollen and would heat up to a point that the TV just looses power as the capcitors cannot hold any charge anymore as they are defective. If your SAVVY you can discharge the TUBE and fix the PSU buying the capcitors online and soldering them yourself on the power supply unit. check this website out for reference on how Caps look www.badcaps.com open up your TV and see if you got bulging caps if you do that is a major issue and it would need replacment. Thanks for using Fixya.com hope this helps please rate!!
May 21, 2009 | Sharp 27K-S300 27" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
