Sky+ remote code for the Logik LCX19LN1 LCD TV?
4 digit code required
  • Anonymous Mar 20, 2014
    cannot activate remote
    President:
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
I need a code for a Logic L46FE22
Logik are terrible with remote codes and don't really seem to care about their customers, have a look here for an example - How can I set up sky remote to Logik LCD TV? ' Logik tv
Try these 2058, 1893 or 0726.
The real manufacturers like Sony, Samsung, Panasonic, LG etc, do update their lists. But ones who just stick a badge on someone elses device don't seem to. That is why it is so difficult to get a code for 'in house' products like Logik which is a badge of the Dixon Group.
Jan 24, 2015 | Televison & Video
Code for logik l22fed tv
I have a logik 22'' HD model no L22fedc the sound works but have no picture can anyone help
Jun 15, 2013 | Televison & Video
Sky+HD remote code for logik L40LCD11
Logik
LK74
726
Logix
LTV3601, RC223
696
Jul 17, 2012 | Televison & Video
Code for 37LH3000ZA LG TV
Hello
Get into this link. Enter your TV model number and all details. You can get the code for your Tv frm here.
www.sky.com/.../remote.../operate-tv-with-sky-remo... - United Kingdom
Jan 26, 2012 | LG Televison & Video
32 inch, hannspree tv.1080P I need code to get my sky remote to work.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV (try 0206)
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Mar 15, 2011 | Hannspree XV32 32 in. LCD Television
Need a code so that i can operate my LG tv. model no. 37LG5010 using my sky remote.
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 4: May 2001 (Sky+ introduced)
Codes are 0065, or 0405,or 0037
Version 6: March 2004
Code are 0065, or 0405, or 0037
Version 8: January 2006 (includes all current Sky+HD remote controls)
Code are 1293, or 1206, or 0206
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Apr 25, 2010 | LG 37LG50 37 in. LCD HDTV
Logik L22LID18 22" hd ready digital lcd tv with ipod dock 7 dvd
Logik TV Sky codes; 1065 0908 1245 0726 0399 0039 0221.
Dec 08, 2008 | Directed 434MHZ Remote Control
Just bought a ONN LCD TELIVISION MODEL AO37ZID from asda, looking for a 4 digit code for sky remote
Got this one to work on both the 37" AO37ZID and the smaller 17" Onn branded A017LC
Sky code: 0527
Jun 29, 2008 | Televison & Video
Televison & Video Logo
445 people viewed this question
Top Televison & Video Experts
Electro Med Services...
