Question about Apple iPhone Smartphone
WHEN I PLUG MY IPHONE INTO A WALL OUTLET TO CHARGE IT DOES NOT CHARGE. The charging icon does not light up.
  • Nick Stewart
    Nick Stewart Aug 07, 2010
    Are you using a genuine Apple branded charger or are you using a third party generic one. Also are you charging with a USB cable or a Firewire one?
    Problem Solver:
  • 43 Answers
My iphone won't charge up at all i put it on
hi there.
Follow these steps:
  1. Remove any debris from the charging port on the bottom of your device.
  2. Restart your iOS device.
  3. Try a different USB cable or charger.
  4. Make sure that you have the latest version of iOS.
  5. Contact Apple Support to set up service.
If your iPhone, iPad, or iPod touch won't charge - Apple Support
Why my iPhone is not charging?
2: Change the Wall Outlet or USB Port Plugged Into. The next most common reason aniPhone won't charge is because of where it's actually plugged into. Sometimes the wall outlet itself isn't working or the light switch is turned off, so if you're using a wall charger then change the outlet.20 Feb 2016
iPhone Won't Charge? Here's Why iPhone Isn't Charging & How to Fix It
How do you clean the charging port on iPhone?
To be safe, back up your iPhone or iPad to your computer or the cloud. Power it off, and with a normal toothpick, gently remove the lint. You will be amazed how much can get stuck in the port. Connect the charger and see if it works.16 Dec 2014
Use a toothpick to clean out your iPhone - CNET
https://www.cnet.com/how-to/use-a-toothpick-to-clean-out-your-iphone/
How do I charge my phone if my charger port is broken?All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.16 Jul 2016How to fix a phone that won't charge properly - AndroidPIThttps://www.androidpit.com/how-to-fix-a-phone-that-won-t-chargeSearch for: How do I charge my phone if my charger port is broken?
or try this link.
iphone won charge up Google Search
Nov 19, 2017 | Cell Phones
Tip
Laptop will not turn on, laptop will not power on, laptop will not start
Make sure your laptop battery has a charge. Plug it into the wall outlet for 30+ minutes and then try powering it on. When you plug it into a power source, usually the laptop will have a light indicating that it is charging. Look for a light. If the light does not light up, try a different wall outlet. <br />If it still does not charge, you may have a bad power cord, a bad laptop battery, the wall outlet may be bad or the laptop itself is damaged and will need to be serviced by a technician or replaced.<br /><br />Through the process of elimination you can narrow down possible causes.<br />-Try a different wall outlet(or by testing another device make sure the wall outlet is good)<br />-Try a different power cable.<br />-Try a different laptop battery.<br /><br />If none of the above help then you may need to have your laptop repaired(internal damage) or replaced.<br /><br />If your laptop is under warranty you should contact your laptop manufacturer or warranty policy holder to have it repaired or even replaced. <br /><br />If it is not under warranty you should look for local computer repair shops or technicians. <br /><br />-G33k<br />
on May 22, 2011 | Computers & Internet
What do you do if your iphone screen stays black?
Plug it in to a wall charger to confirm the battery has some charge. Within a minute or so, you should get the charging icon on the screen
Jun 27, 2014 | Apple iPhone Smartphone
Will not charge
Well when the light is green that usually means it is fully charged. If the light is amber then it is charging. If you are having problems with short charged up time duration try this: Plug charger cord into Kindle then plug charger to outlet. Then press on/off button. A screen will pop up asking if you want to cancel or power down the unit. Do not choose either option, keep the button pushed down until every thing turns off. There will be no power light at all. Wait 2-3 hours unplug everything then power up the Kindle. This action will match the battery indicator icon to a truer image of the battery. I do this several times a week, usually overnight. Sorry if I over answered your question.
Apr 01, 2014 | Microtech Corp. ePhotoChest
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Toshiba SP 6100 Battery problem
If the charge light shows a blinking amber, then the battery is dead. If the charge light shows a solid amber, then it's charging.
Which is it?
Dec 31, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sometimes my Iphone will not charge when i connect it to the wall charger. I just bought my iphone a couple of months ago.
If your iPhone is not charging when you plug it into a wall charger or into you computer's usb port, this is a usb connectivity issue and the connection just needs to be reset. All that needs to be done is plug the iPhone's cable into the phone but don't plug into the computer yet. Hold the phone's select button (the round button with the square) down for about 30 seconds or until the apple appears on the screen. your phone will reload and reset the connection and the computer should recognize the device. Allow the phone to charge for at least 30 minutes before unplugging.
Oct 21, 2009 | Apple iPhone Smartphone
My iphone does not want to start up PLEASE HELP!!
sounds like you either need a new powerpack or a new battery :( sorry
Jun 24, 2009 | Apple iPhone (16 GB) Smartphone
Apple iPhone Smartphone Logo
150 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
