There are two things that could be happening...
The hole is plugging up and the wtarer is not running away when it defrosts...
or the defrost control is not working correctly all of the time...
These tips cna help you to figure out the exact problem...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
I would get a wire from the coil into the hole to eliminate that problem... see how it goes and then replace the dsefrost timer or control which ever you have as a last resort....the bimetal just shuts down the defrost it does not initiate it...
heatman101
They could be part of the problem or "a" problem, however I still feel that you may have other issues...time will tell...
sometimes a crazy simple thing like that can mes with evrything...
welcome to the world of fixing things... :-)
heatman101
Yesterday I did a continuity check on the defrost heater and it was good. Also, I made a
continuity test on the bi-metal terminals, and it was good, too. Is there anything else I should check? Is the control damaged?
As additional info, I do notice that little cool air is felt entering the refrigerator from the freezer.
Thanks for any additional help you can give me.
I continued some troubleshooting in my refrigerator and found that the vents from a piece called diffuser, which has small vents where the cool air from the freezer enters the refrigerator side, were closed. This is odd, since the refrigerator was clearly not cool enough and I would expect them to be open so that the cool air could enter the refrigerator. I simply opened them manually and now I can feel the cool air entering the refrigerator. Could this diffuser be a part of the problem?
