Question about Brother DCP 130C All-In-One InkJet Printer
Damn thing won't let me print says Print unable 34 see trouble shooting and maintenance chapter? Will I do not have one and wonder if you can help? Your assistance would be most appreciated.
  • 857 Answers
Although Error 34 could be a few things, it is usually caused by what they call the "auto sensing tray" The paper tray auto senses the size of the paper in it, and if the paper does not match what is on the screen (usually caused when a sheet feeds half way through then stops).
REMOVE ALL the papers and reset the printer (power off and back on after 30 seconds). When you put the paper back in, be sure to "fan" the paper to make sure any static is removed.Then try to print it should work.
If not you will need to get it serviced.
Posted on Aug 07, 2010
  • fairyrosebud Aug 07, 2010
    Thanks Jay I have tried this a number of times and it has failed to remedy the problem.
Unable to print See trouble shooting and routine maintenance chapter in User's Guide
might be a coagulation in the ink in the cartridge in the fax machine. check it if so dip it in mild hot water for some times and replace it wiping the water and it would work.
May 08, 2011 | Office Equipment & Supplies
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Error message
try to re-instal the driver or check the cable
Mar 16, 2009 | Office Equipment & Supplies
TROUBLE SHOOTING
I am having a problem as well. I can't use the Fax either. Very difficult to see th jammed paper. Followed all instructions, but unable to clear the jam.
Feb 18, 2009 | Brother Multi-Function Center MFC-3360c...
UNABLE TO PRINT
press menu then start bk copy then fourtimes arrow-up button (tel.index) quick after another.
machine will be in maintenance mode and lights will flash.
press start bk copy in case machine wont directly display the error code.
Error starting with 4 means defective print head.
Error starting with 5 menas defective purge station or cycle problems.
both error series means: you need a new printer...
Feb 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
Manual
My printes is saying that it is unable to print . It is asking me to see trouble shooting and routine maintenance chapter.
Feb 11, 2008 | Office Equipment & Supplies
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother DCP 130C All-In-One InkJet Printer Logo
42 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
