Question about Husqvarna Designer I
My bobbin is empty, don't know how to wind thread onto it. Not very clear instructions
  • 201 Answers
Can you find the bobbin winder? You need to lift the "lid" and it is on the right-hand side - a small white spindle pointing towards you. Put a HV bobbin on the spindle. Look at the bobbin first - on one side the Husqvarna symbol is embossed - a crowned "H" in a circle. Be sure this H is facing you. Push the bobbin onto the spindle firmly, but not with so much force that you push the spindle into the machine (it takes a pretty big push to do that, but it has been done!) then using your right-hand thumb push in a downwards motion (towards the table). The spindle with the bobbin on it will go about one inch downwards. The bobbin winder is now engaged and you should have a pop-up on your screen. I often reduce the speed by two or even three clicks before I push the spindle down.
Pull the second thread spool - the one closest to the bobbinwinder - so it sits at a right angle to the machine. Put one of the spool holders (white plastic disks) - preferably the bigger one - onto this spool. This gives your thread a base to sit on. Put the thread onto the spool so that the thread unwinds from the right-hand side (closest to the bobbin). Take the thread end directly across to the silver "button" that is near to the first tension slot on the left-hand side. The instructions say to wind it around this and then across to the bobbin winder, but I prefer to take the thread under the silver button, around the left-hand side and then across the top of the button (sort of figure-of-eight style). Just be sure the thread goes in beneath the button i.e. does not sit in a big loose loop around the button.
The thread is then taken across towards the winder by going under the white plastic hook (looks a bit like a beak), then up and over the top of the next little silver button (smaller than the other one). Then you wind the thread around the bobbin four or five times and take the thread end over to the cutter located directly to the right of the bobbin winder. Cut the thread (if it is too short to be cut, just leave it flop down) and press the Start/Stop button.
The bobbin will fill and stop of its own accord when it is done. If it does not fill right up or is uneven (more on one side than another) there is a fix for that too. Write back here if you need to do this.
Don't forget to take the speed back to normal before sewing.
You can wind the bobbin from the needle but be sure you have a metal foot on, not one of the plastic ones. Personally I find I get a better bobbin wind the way described above and it only takes a few seconds to re-thread ready for sewing. I tend to have a big bobbin winding session and do lots of bobbins at once, especially embroidery bobbinfill. At any one time I would have at least six bobbins filled with bobbinfill and a dozen of various thread colours for normal sewing.
Do hope this helps you. Write back if this is still not clear. Did you try to Google for a video of this? I have never looked for one, but it is very likely that someone has made a video and made it available online.
Posted on Aug 07, 2010
Testimonial: " Thankyou very much, very helful indeed. "
Bobbin not not threading, what's the problem?
We don't know the make & model of your machine. Are you trying to wind the thread onto the bobbin?
FWIW, for ~$30 there is a stand-alone bobbin winder called "Sidewinder" that can be used to wind all your bobbins. It saves wear-n-tear on your machine and you can wind bobbins without removing the thread from your sewing machine. Just be sure to verify that your bobbins are compatible with the Sidewinder.
Available at JoAnn's, Walmart, Amazon...
Amazon com Simplicity SideWinder Portable Bobbin Winder
Jul 19, 2017 | Sewing Machines
Winding bobbin on 4411 with right tension
Hello Joyce Strohl
This happens quite often when the thread is not totally engaged through the tension disc before reaching the empty bobbin. You can refer to page 12 or the free downloadable manual found at this link: http://www.singerco.com/uploads/download/1230_4411_heavy_duty_esf.pdf
Note that the thread must winde around the tensioning device in a letter "e" style to be effective.
Place the "mushy" bobbin where the spool of thread normally resides and winde the mushy thread onto another empty bobbin .... this way there is no loss of good thread.
Happy Stitching
Sewingirl/
Apr 23, 2017 | Sewing Machines
How to thread a bobbin
Which Singer machine do you have? I know how to wind and insert a full bobbin for some models.
Some wind the bobbin with it in the case. This is the case with my Touch & Sew. Inserting a full bobbin is simple. Open the slide plate and drop in the bobbin with the rings up. Make sure that to hold the bobbin thread so that it comes off at the left. Then close the slide plate and make sure that the end of the bobbin thread is coming through the notch. Hold onto the threads and turn the handwheel until the top and bottom thread come back up with a twist. To wind a bobbin for this machine, open the slide plate (some models have a little mark to line up the slide plate). Put in the empty bobbin and thread the top normally. Set the machine to straight stitch and push the bobbin wind button in. (This has a bulls-eye symbol on it.) Wrap the end of the top thread around the presser foot screw several times and hold onto the end. Step on the foot control to start winding. Keep winding until the bobbin is full. The thread wound onto the screw should break. Pull some extra thread and cut it to separate the top and bottom threads. Close the slide plate and set your desired stitch.
Other models are wound at the top of the machine. For some of with a drop-in bobbin, you need to bring the thread down to a catch and then off to the left to another catch. Some have a vertical bobbin. I don't remember if they all have a removable case. Those that do need the thread to come through a notch on the case that pulls the thread under a spring that keeps the bobbin tension. However you should check your manual. If you do not have a manual, check if one is available online. (http://www.singerco.com/accessories/instruction-manuals has many of the Singer manuals for sale or download.)
If you post a comment with the model of your machine, I'll give you a description of threading the bobbin or winding one.
Jan 19, 2012 | Singer Sewing Machines
How to wind the bobin on a singer 7050
To get that same thread onto the bobbin, you'll need to windit. Here are the steps:1. Removethebobbin from the sewing machine. If your machine has a free arm, you'llhave to remove this first. Open the bobbin door to reveal the bobbin case, forvertical loading models. If your machine has a drop-in bobbin (horizontalloading) you may have to simply slide the metal plate open, which sitsunderneath the presser foot.2. Lift the latchand pull the bobbin case out of the machine (for vertical loaders). Butfor drop-in bobbins, simply lift the bobbin out of the housing.3. Tip the bobbincase over and let the bobbin fall into your hand. (Some bobbin caseshave a latch on the side, that when lifted releases the bobbin). If the bobbinhas another color thread on it, use a new bobbin. Or, if it's not too muchthread, roll it all off and reuse the bobbin. Just make sure the bobbin youwind begins empty. (But in a pinch, you can wind a new color thread over theold color. Just know that you may have to rewind the bobbin fairly soon, as thedesired color thread finishes faster.4. Place yourselected thread onto the spindle and insert a holder over it, if there is one(usually on horizontal spindles only). Many machines just use gravity toretain the thread, so if your spindle is vertical and you have no such part,don't worry about it. If thisis a brand new spool of thread, you may need to free the end. Look for a smallnotch on one end of the spool. You may have to peel back the label a bit to getat it. Then yank it free.5. Loop the free endof the thread over the bobbin tensioner and any hooks on it. Thelocation of this part varies, but it generally looks about like this. Thread the end of the thread through the pinhole in the top of the bobbin. 6. Press the bobbinall the way onto the bobbin winding spindle. Make sure any springs orclips engage. Put it on so that the end of the thread that you put through thepin hole sticks out towards you (or sticks up, depending on if your bobbinwinder is at the top of your machine). 7. Disengage theneedle mechanism. Many machines have this control in the handwheel. It may require a push, pull or twist of the middle of the hand wheel.Check your sewing machine manual to be sure. The sewing machine may run fasterwhen winding a bobbin than when sewing and you don't want the needle moving upand down wildly. Engage the bobbinwinding mechanism. On some machines, it's done by pushing the bobbinspindle over to one side. You may also need to move the stitch selector to abobbin winding position.8. Hold the free endof the thread and, keeping fingers clear of all moving parts, press the footpedal or knee lever. The bobbin spindle will turn. If you have thebobbin threaded correctly, the bobbin will wind smoothly, evenly, and snugly,with perhaps a slight bulge in the middle. You should cut off the end of thethread you were holding in your hand (very close to the bobbin) as soon asthere's enough thread on the bobbin to hold itself in place so it won't slipout. This will prevent this thread from tangling onto any moving parts.9. Fill the bobbincompletely. It may seem like a lot of thread, but you don't wantto run out too soon while you're sewing. Many machines have a built-in deviceto stop winding when the bobbin is full, often a small blade that automaticallycuts the thread when the wound bobbin is full. If your machine has such adevice, let it tell you how much to fill the bobbin. If not, fill the bobbin nofurther than its edges. Hold the bobbinand case so that they are oriented as shown. Check that thebobbin will unwind in the correct direction. If not, flip it.10. Insert thebobbin into the bobbin case. Pullthe thread under the bobbin tensioner (a thin metal latch). The threadshould advance with a little resistance when you pull at it. Allow this excessthread to just hang. Lift the latch onthe bobbin case and hold it as shown.11. Insert thebobbin case into its housing. Make sure it is all the way engaged (youshould hear it click into place) and that the direction is correct. The bobbincase shouldn't spin and shouldn't come loose when you release the tab. Itshould be locked in. And the loose end of the thread should hang free. Do notclose the bobbin door.12. Re-engage theneedle at the hand wheel, disengage the bobbin winder, and set the machine backtoa straight, forward stitch. Thread the machine with the top thread as usual. Once the threadis through the needle, you must raise the bobbin thread. Hold the end of thethread with your free hand. Turn thehand wheel towards yourself. The needle should go down and back up to itshighest position. One full rotation should do it. The top thread will passaround the bobbin.13. Watch as the topthread pulls the bobbin thread up through the hole in the plate under thepresser foot. Pull the looseends to extend them, and continue to hold them firmly so they don't get tangledas you begin to sew.Closethe bobbin door before sewing.Hope this will help you. Good Luck.
Oct 08, 2011 | Sewing Machines
The thread keeps coming off the needing when i sew
Hello
I would suggest that you revisit the threading up in your manual and double check that the top thread is under tension.
However, if the stitiching on top of the fabric is wonky, this is your bottom tension too loose, and if stitching on the the underside of the fabric is loose, its the top tension causing it.
Quite often bobbin winding can be the cause of bad stitching so pull out the manual and wind a bobbin carefully following the instructions, making sure that the thread is under gentle tension as it winds. What you don't want is for the thread spool to bounce around as it unwinds onto the bobbin as this gives uneven tension of the thread and when you then stitch a seam, the thread relaxes in different amounts causing puckering.
So wind at 3/4 speed, and gently guide the thread onto the bobbin so it fills evenly across the whole core. And ensure there is tension on via a tension guide if your machine has one. If not, then place the curved handle of your scissors onto the top of the thread spool and hold it there as you wind, which holds the spool down and keeps the thread coming off it smoothly.
Always raise the pressure foot when you thread the machine so the top thread goes into tension fully. And new needle for each new sewing job is really important, make sure it is the right size and type of needle for the fabric you are sewing.
Aug 02, 2011 | Brother LS-2125 Mechanical Sewing Machine
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Hi I am having problems with the top tension on my Singer 2662. I am following the instruction manual but nothing I seem to try works. Or it works for a while and then the next time I sew I have problems...
Always raise the pressure foot when you thread the machine so the top thread goes into tension fully. And new needle for each new sewing job is really important, make sure it is the right size and type of needle for the fabric you are sewing. if you aren't sure what size is right www.sewing.about.com has great tips and general machine info, plus needle guides.
Jun 11, 2011 | Singer 2662
Stiches are uneven & the thread bundles up on the back. I have lost my instruction book, so it is hard to slove the problem. If you could send me a new one, I will pay you for it! Linda P...
you can download a manual from here
http://www.ps2netdrivers.net/heirloom.edition/elna.6005/
If you are getting loops in the thread underneath check your top tension, thread is probably not into the tension discs fully or at all. If you can get at them, clean between the tension discs, turn tension knob to zero, then "floss" between with the selvage edge of a clean piece of cotton fabric to remove any dye buildup or lint. Cheaper threads will shed fibres as they go through tension so best to avoid those bargain bin threads, fine for hand sewing but not so great on the machine long term. If you can't get at the tension discs then consider having a clean and service at least bi-annually to keep them clean as well as the other internal moving parts.
Uneven stitches can be caused by a blunt needle - you should put in a new one for each new sewing project (4-6 hours sewing time) ensuring it is a sharp for wovens or ball point for knits. There is a great guide to needles at http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/
Also review how you wind the bobbin, there needs to be tension onto the thread as it goes onto the bobbin, there might be a silver tension disc on top the thread goes around. Wind slowly, and apply a little pressure onto the top of the thread spool you are winding off - your scissors handle is good. This stops the spool bouncing around causing uneven tension on the thread. If the thread is stretched, then relaxed as it winds onto the bobbin, then it will go back to its normal position in the seam causing puckers.
Here's how I wind - take the thread from the spool across to the tension disc, then back to the bobbin, put thread tail through the hole on the bobbin and hold the tail. Pop bobbin onto bobbin winder spindle and click across to engage. Hold the tail and start winding (might be a button on your machine, or just the foot control), wind just enough to go across the bobbin core and hold the starting point. Stop and snip off the thread tail with your scissors. Restart winding slowly while putting some pressure onto the thread spool with your scissors curved handle into the top (I usually use Guttermann thread and they are tall spools coming up past the top of the pin, this might not apply if using a shorter spool but put some pressure onto it). Watch the thread going onto the bobbin and give it a nudge with your finger tip to ensure the thread fills top, middle and bottom of the core evenly, you don't want it all on the bottom or all in the middle.
Wind until 3/4 full, then stop, cut and remove from the spindle and return machine to normal sewing mode. If you have a mushroom type cap put it onto the thread spool now so the thread winds off smoothly as you sew. Also put a felt circle under your thread spool to assist smooth thread flow.
Also, have you cleaned in the rotary hook? You should brush this out each time you use the machine and refering to the manual, remove the bobbin holder/case and clean under it. All machines will get lint/thread bit build up in the rotary hook and need regular cleaning out to prevent impaired operation. Your machine probably also has a oiling wick under the holder, in a little depression in the middle. Don't touch it but you can give it a drop of good quality clear sewing machine oil every few months. Manufacturers would like you to give the machine to them annually for cleaning/lube etc but you can certainly do some cleaning regularly yourself to prolong machine life and keep it running smoothly.
Also, keep machine covered when not in use, never in full sunlight (plastic will yellow) and not in a damp area.
I hope that these tips help you a little, certainly if you try all the above and the machine still isn't performing as it should, then take it back to your dealer and ask them to test sew and confirm if it needs a service. A good dealer would do this for you ( I usually ring first so I don't get them at a busy time though). I have my machines serviced every two years and clean/oil myself each month in between.
Happy sewing.
May 10, 2011 | Elna Heirloom Edition 6005
After following instructions on winding the bobbin for the fast bobbin winding system, the bobbin is not threading
If the bobbin spool is spinning, it will thread.
Take the end of the thread through one of the little holes in the side of the bobbin spool and pull out about 8" of thread. Hold onto it as the bobbin begins to spin.
After the thread has wound 5 - 6 turns, stop the machine and cut off the thread end. Continue the winding process.
Mar 14, 2010 | Brother CS-6000
I cant remember how to fill the bobbin with thread :(
Insert the empty bobbin case onto the bobbin winder in the sewing machine.
Step 2 Set the spool of thread onto the thread peg. Use the same thread you want to use on your material to obtain the best finished stitch.
Step 3 Follow the arrows or guides to take the thread from the spool to the empty bobbin.
Step 4 Start the thread around the bobbin in a clockwise direction.
Step 5 Push the small lever against the bobbin spool to hold it in place. This disengages the needle so it won't go up and down while winding the bobbin.
Step 6 Press the foot or knee pedal to start the winding process. Stop when you have enough thread on the bobbin for your project.
Step 7
Cut the thread between the thread spool and the bobbin. Insert the bobbin into the bobbin case so you can begin sewing.
Open to clarifications.
rate this.
Jan 10, 2010 | Janome Jem Silver 662 Mechanical Sewing...
Sewing Machines Logo
127 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
