Question about Dell 5210n Laser Printer
Hey i'm looking for a pickup roller of Dell 5210N do you know any store in CA carries that part? please let me know
3 Suggested Answers
  • 13 Answers
SOURCE: Our Dell 5210N printer gives the error: 929.00 ser...
A 929 Service Toner Sensor error indicates a problem with the toner sensor, the front harness cable, or the developer drive. It could also mean that the toner cartridge is defective.
  • The most likely cause of this error is the toner cartridge itself. This is especially true if it is a new cartridge and the error started after you installed it.
    1. Take the cartridge out of the printer and locate the encoder wheel on the right-hand side of the cartridge. The encoder wheel can be found on the right side of the cartridge (usually over a bar code sticker). It is a thin, black, plastic wheel with small rectangular notches cut into it. This wheel will sometimes get stuck, but you can free it by turning it by hand.
    2. Try moving the wheel forwards and backwards a little. If it does not turn correctly, you will receive a 929 Toner Sensor error on the printer when you try to use the cartridge it is attached to. Note: The encoder wheel moves only a little bit each way. It should not make a complete revolution. If it does, the wheel is probably broken.
    3. Try to move it a little bit each way a couple of times to see if you can free it up. Caution! DO NOT force the wheel as you could break it.
    4. If the wheel on the toner cartridge is stuck, try another new toner cartridge. ( If you do not have another new toner cartridge available, an old toner cartridge or another cartridge from a working printer of the same model will also suffice for this test.) Power the printer off and install the second toner cartridge. Then power the printer back on. If another toner cartridge clears up the 929 error, the printer is fine and the problem is with the toner cartridge. If the error does not clear, there may be a problem with the printer.
    5. If you narrow down the problem to the toner cartridge, call the point of purchase and explain the situation to them. They may have a replacement policy. If they cannot help you, call our Technical Support Center and we will see what we can do to replace the cartridge that is causing the error. We will not be able to reimburse the price of the cartridge, but we can offer you an exchange. To do this, we may ask you to send in your cartridge first. Please note that we cannot offer an exchange on a refilled or refurbished cartridge. For this, you must go through the point of purchase.
      Click here to order toner cartridges and other supplies for your printer.
  • If you receive this error with a second toner cartridge, you may want to check if the Front Harness Cable is plugged into the Toner Sensor. Do the following:
    1. Turn off the printer and remove the toner cartridge.
    2. Look inside the printer at the place where the cartridge goes (on the right). You should see the Toner Sensor. On the back of the sensor assembly, you should be able to see a white cable connector.
    3. Push this white cable connector into the toner sensor assembly by pushing the connector towards the front of the printer.
  • If you continue to receive the 929 error, your printer will probably need service.
Source: Lexmark KnowledgeBase
Posted on Jun 22, 2010
  • 3 Answers
SOURCE: Envelope Feeder for Dell 5210N wrinkles envelopes
Hey,
This may be a bit late, but I just posted a solution to the Dell 5210 envelope problem here
http://www.laserprintercenter.com/laser-printer-news/2010/10/envelope-printing-and-laser-printers/
Basically, it has to do with the envelope enhance feature...
Posted on Oct 18, 2010
I need a pair of 4 wheels for my large Murano suitcase..where ??
Hey Carol, You might get them from Ebay...I hope this helps...
Apr 02, 2016 | Luggage & Travel
What does the 922.02 service fuser error mean? Will not print,
It means the fuser (roller than heats the toner to the page) has a problem, most like needs to be removed and cleaned or replace.
Jan 17, 2011 | Dell 5210n Laser Printer
The printer keeps sounding like it wants to grab the paper but it doesn't print. it keeps asking for us to resize the paper and put in legal. when we do that it still doesn't work.
If it prints ok from the manual tray, you probaly need to replace the pick up Rollers in the tray. Dell part # dell-p1396 easy to do.
Donde encuentro manuales de esta impresora DELL 5319n
Workgroup Laser Printers Contents: Dell Laser Printer 5210n/5310n Contents: Dell Laser Printer 5210n/5310n Dell™ Laser Printer 5210n/5310n Tech Sheet View Download (PDF, 116 KB) ...
Systems Management Dell Support ...Dell 3115cn Color Laser Multifunction Printer - Dell 3130cn Color Laser Printer - Dell 5210n Mono Laser Printer - Dell 5310n Mono Laser Printer - Dell 5330dn Mono Laser Printer - Dell 7330dn Mono Laser Printer...
Documentation ...Printer 5110cn Dell Laser Printer 5210n / 5310n Dell 5350dn Laser Printer Dell 7130cdn...
Documentation Contents: Dell Laser Printer 5210n/5310n Dell™ Laser Printer 5210n/5310n Tech Sheet View Download (PDF, 116 KB) ...
Systems Management Support Information Matrix for Dell Management Console Version 1.1 ...Color Laser Printer 5110cn Laser Printer 5210n/5310n Laser Printer S2500 (n) Workgroup Color... 5330dn Dell 7330dn Dell 2145cn ...
Systems Management Supported Information: Dell Management Console Version 1.0 User's Guide ... Dell PowerVault ...Dell PowerConnect ...Dell'EMC ...Laser Printer 1815n ...Laser Printer 5210n/5310n Yes ...
Dec 13, 2010 | Dell 5310n Laser Printer
Work has a Dell 5210n Laser printer. When we print everything comes out with streaks running the length of the paper, from top to bottom. How can we correct this?
Replace the toner cartridge with a new one to see if it solves the problem. Check to see you havnt got a label stuck on the roller inside the toner? Be careful you dont touch the roller itself as you may damage it. Fingerprints dont do it any good.
Oct 14, 2010 | Dell 5210n Laser Printer
How do I clean the rollers on my IBM Infoprint 1332??
I most cases if you are having paper pickup issues with this unit the rollers will be worn down not just dirty. The pickup rollers that pull the paper from the paper tray on the bottom of the printer are not very expensive, they run about $4.00 We carry them in stock at: http://www.ccl-la.com/catalog/index.php?cPath=24_59_60 Replacing them would be much better than just cleaning the rollers. If you pull the paper tray out and look under the bottom of the printer you will see 2 small rollers with rubber tires on them. These are the pickup rollers, they should feed rough, if they feel smooth then they need to be replaced. We also carry the full preventive Maintenance roller kit that includes the pickup rollers, charge roller and the transfer roller. We provide full tech support for all purchases too.
I hope this helps, if so please rate our solution,
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 07, 2010 | IBM Infoprint 1332 Laser Printer
Garbage text from Dell 5210n
Try downloading and installing the latest driver from: http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cadhs1&l=en&s=dhs&os=WW1&osl=en&catid=&impid=&SystemID=PRN_LSR_W5210
Besure to select your correct Operating System, and install any Patches and Updates available as well.
Jan 08, 2010 | Dell 5210n Laser Printer
Hey,
Oct 13, 2008 | Dell 5210n Laser Printer
Where to get fuser and rollers
Sorry it took me so long to get back to you, I've been out of town for a few days.
The parts you need for the 1600n are from Dell.
Part# N5796 - Fuser
Part# M5512 - ADF pickup arm roller
Aug 11, 2008 | Dell 1600n All-In-One Laser Printer
Dell 5210n Laser Printer Logo
57 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
