How do I reset lamp timer on TY-LA2005 Hd tv?
SOURCE: How to reset lamp timer
Go to the menu and you'll find lamp timer section.
Posted on Sep 30, 2008
SOURCE: projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Posted on Oct 02, 2008
SOURCE: Bulb or Lamp Unit Timer
"paison" was correct and his solution did work for me. Make sure you first select TV on your remote. Now hold down the dvd/vcr button at the bottom of your remote while also holding down the "volume down" button on th front of the TV. Hold until a "Blue Reset Menu" appears on the screen and say the timer has been reset. Noe just follow the on screen instructions.
Posted on Feb 05, 2009
SOURCE: I have ordered a ty-la1000
I noticed that the manual on the below website has more information and instructions than the one that came with the tv on how to replace the bulb and reset the lamp timer, etc. Easy to do but they told me two years ago I had to have it done by a technician which costed me $300.
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC14
Posted on Dec 30, 2010
moorah1
  • 181 Answers
SOURCE: I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Posted on Dec 06, 2011
Lamp flashes red and tv just shut off
You may have a bad lamp. Open the door on the side & pull lamp. The part number is TY-LA2006. They cost about $200-225. BE SURE to reset the lamp timer. If you buy an original Panasonic TY-LA2006 lamp, it will have instructions to reset lamp timer.
Jan 21, 2011 | Panasonic PT-56DLX76 Television
Where do I purchase and how do I replace a picture lamp for a panasonic PT-56DLX75 56 in. HDTV Television ? I live near Sioux Falls, South Dakota.
Hi there this online store has the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=PT-56DLX75
this link has your TV manual and check page 67 it will show you were the lamp is located in your TV
http://service.us.panasonic.com/OPERMANPDF/PT56DLX25.PDF
this link shows you how to replace the lamp
http://www.fixyourdlp.com/guides/panasonic/TY-LA2005.php
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Oct 11, 2010 | Panasonic PT-56DLX75 56" HDTV
Have installed new lamp TY-LA 1ooo How is the new age timer set???
Press and hold Volume down button on tv front and Split/Play button on remote for 6 seconds to reset lamp timer.
TV will show you lamp timer reset confirmation display.
Sep 28, 2010 | Panasonic PT-43LC14 43" Rear Projection...
How to reset lamp timer on pt 50L C-13
Their manual says:
After lamp replacement, you must reset the lamp
time. Refer to the instructions enclosed with the
lamp unit (Part No.: TY-LA2005).
lamp unit (Part No.: TY-LA2005)."
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC13
Aug 09, 2010 | Panasonic PT-50LC13 50" Rear Projection...
TY-LA1001-K I replaced the lamp and didnt restet
I have searched and searched on how to reset the timer. Most solutions say you have to press and hold the volume down button on the tv while also holding down the zero button on the remote, or the pip or split button on the remote until the screen display reads that the timer has been reset to zero or the lamp and power button both flash.
I have tried every combination and cannot seem to reset my lamp timer. If you figure it out, please share it with us!! I'm frustrated and can't get it to work!!
May 07, 2010 | Panasonic PT-52LCX66 Projection Television
Describe your Panasonic PT-60LC14 60 in. Rear Projection HDTV Television Problem: Need to reset timer light--how does one do that?? We got the new lamp installed but it keeps blocking the screen telling...
Hold VOL - on the TV then aim the remote at the TV (watch so that your arm doesn't block the remote signal and press PIP or the SPLIT button. Do this together for at least 5 second. I hope this helps.
Mar 18, 2010 | Panasonic PT-60LC14 60" Rear Projection...
Resetting lamp hour meter on panasonic tv
press volume down on tv and pip or split on remote
Nov 19, 2009 | Panasonic PT-56DLX25 56" HDTV
Set timer
You did not post model number of TV so try below method to reset lamp timer.
Turn TV ON, Press and hold Volume minus button on TV and press Split/ Play button on remote for 6 seconds, lamp reset message will appear on TV screen.
Jul 02, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Panasonic PT-40LC12
hi...
Panasonic lamp timer reset procedure
1. Press the power button to turn the unit on.
2. There are 3 choices for this step, depending on the housing part number:
A. TY-LA1000, TY-LA1500 or TY-LA2005 While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at the same time for more than 5 seconds.
B. TY-LA1001 or TY-LA2006 While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
C. TY-LA2004 While pressing the VOL- button on the projection display, hold down the MUTE button on the remote control at the same time for more than 5 seconds.
3A. When the reset procedure is complete the the following screen will appear: LAMP TIME WAS RESET TO 0 (this screen may be different from the actual screen)
OR
3B. The POWER and LAMP LED's on the front of the unit will flash for 5 seconds. (TY-LA2006)
When the lamp time reset is finished, the LAMP indicator goes out. It may be necessary to attempt the procedure several times.
Oct 29, 2017 | Panasonic PT-40LC12 40" Rear Projection...
Set lamp timer
Jerico, If you will go on dlp lamps .com I believe they answer that question in their FAQ. You can also give them a call. Look on their site for number. All I know is that they make the whole process really easy.
Jul 11, 2008 | Panasonic TY-LA1000 Projector Lamp for...
Televison & Video Logo
485 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
