Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
My two door fridge freezer works well untill it goes through a defrost then it wont start back up i have replaced the sensors both defrost and room in the freezer and it still does the same thing what could be causing this problem please
  • Samsung Master
  • 43,501 Answers
Then it is the main control or the defrost control board...
Iwould look up the part for you but the model number given here comes up as an oven..
heatman101
Posted on Aug 07, 2010
Samsung refrigerator is freezing up on back panel of refrigerator . Will defrosting the whole unit do any good? The unit is 2 years old
well yes and no , defrosting it will temporally make it work , but main problem is there isn't proper air flow over evaporator coils id clean them with soap and water while defrosting out unit , if low airflow is allowed to continue then refrigerant gas will build to high press and escape and render unit a total replacement
Sep 29, 2016 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
Tip
What do do if your fridge/freezer is not cold
5 reasons for fridge and/or freezer getting warm:
1- the evaporator coils are icing up and won’t let air circulate.
2- the evaporator fan is not working to circulate air.
3- there is no refrigerant in the system.
4- no power to fridge or compressor.
5- the condenser coils have no air circulation
check under the fridge behind the vent. if it is too dusty or the fan isn’t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust.
if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it’s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won’t heat up, it’s the timer or the coil.
the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge.
if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked.
if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes:
1. low refrigerant
2. no fan
3. too much humid air in fridge/freezer due to door open or bad door seals
4. the condensate drain tube is clogged
5. defrost cycle not functioning properly
if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s).
no air, no fan. Replace
if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional.
there defrost cycle starts with the timer. at a certain time of day for a specific time, the timer turns the compressor off and turns on the heater element located at the bottom of the evaporator coil. this stays on until the coil temp sensor reaches a certain temperature to let the timer know that the coils are defrosted and turns off the power to the element. the defrosted water drains to the condensate pan. if the timer is bad, it will never go into defrost, or never get out of it. if the element is bad, the coils will never defrost. if the temp sensor is bad, it’ll go into defrost, but it will either tell the timer that it’s always frozen or already defrosted, resulting in the element never turning on (stays frosted) or never turning off (eventually burning out the element).
on Dec 02, 2009 | Refrigerators
How do I stop frost/ice from building up in freezer (bottom freezer of French Door Stainless Steel bought in Dec 2011)
Check the door gasket carefully for cracks or other leaks. It is crucial to have a good barrier between the moist room air and the super-dry air inside the box that will quickly suck in the ambient humidity and form frost.
It would be difficult to change the sensor and the heater, and if the defrost cycle is running (and you feel some warmth around the bottom of the box when it is cycling) then the sensor and heater assembly are working and do not need to be replaced. The best practice is to remove any frost buildup at regular intervals and often to prevent a thick buildup that is difficult to remove.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 19, 2014 | Samsung RF26VAB (25.5 cu. ft.)...
My refrigerator side is not cooling well. I see ice behind the fan unit when I take out the veggie drawers at bottom. Also fan on fridge side is making lots of noise. Noise stops when I open the door and...
.When you open the door freezer door will get stopped and so, no sound. It will work only when door is closed. Fan sound comes due to malfunction of defrost. If defrost does in right time it won't happens. Unplug and let fridge get defrost all icing. After 3 to 4 hrs,start run again, and set temp @ 5degree freezer. It will start cooling fridge compartment also. But, this is a temerory solution. To solve permanently, find out why defrost not functioned properly?
Follow this steps.
Check defrost timer working which is back of the refrigerator down corner. By with small tip screw driver in some models located in the ceiling of the fresh foodsection or behind the cold control cover. In the defrost timer,slowly turn the screw like wheel in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Jan 28, 2011 | Samsung RS2630SH Side by Side Refrigerator
Refridgerator side not getting cold model gss201epaww
make sure the damper vent door located between the freezer and refrige compartments is opening and letting in cold air from the freezer,if they ice up they can stick shut and not allow air flow,this door is behind a plastic grille an a hair dryer works great to defrost them
Apr 30, 2010 | Refrigerators
Ge freezer works fine but the fridge wont cool.you
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Refrigerators
Refrigerator to warm freezer OK
first check the fan...make sure it is running.
next defrost the freezer unplug and open the doors untill all the frost is gone about 24hrs at room temp..
plug it back in and see it it will work better ..if it does you have a defrost problem... let me know
Nov 12, 2008 | Frigidaire Refrigerators
Fridge not cool, freezer fridge temp
The most likely fault is a problem with the defrost cycle. The most likely is the defrost heater which should be a solid bar which is located directly underneath the coil. If you are capable then you can generally unplug the connectors for the heater and check that you have a resistance across the ends if the heater is faulty it will be open circuit. If it is not open circuit then it could be the defrost sensor or defrost timer at fault. You can also generally tell if the heater is warped or cracked. Hope this is of some help.
Sep 05, 2007 | Maytag MSD2454G Side by Side Refrigerator
Freezer stays cold, but not fridge
i had the same proble open freezer door and unscrew back plate if coils are iced up its eather a sensor on tot or the heaters lond tubes you can see if all iced up get blow dryer out to defrost
Aug 14, 2007 | Frigidaire FRT21P5A Top Freezer...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
91 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
