Question about Motorola Mobility W490 Cellular Phone
Display not working (phone got wet in storm). Can i take it apart and let it dry overnight?
    Genius:
  • 1,340 Answers
You could try it.You even could blot the circuit board dry probably with a paper towel would be best.A cloth will lint too easily.Just blot at it ,don't rub.I have not seen much success when a cell phone gets wet because they are so delicate and small,but it's worth a try.It's better to at least try before replacing.Dry the battery and compartment too.Good luck!(You need alot right now).
Posted on Aug 07, 2010
  • rossatl97 Aug 07, 2010
    Hi icantry, thanks for your response. I will try putting it back together and recharging the phone just before the local provider store opens later this morning. They claim on their web page to offer loaner phones so if my phone is dead my I can get a loaner until a replacement phone arrives. Thanks again.
Hi, the tills raised keypad was cleaned, stopped working, receipts keep unraveling.
Good afternoon Steve.
Drying it with towels or such will sometimes work, sometimes not. Depends on what the wet was. On the drying side, for a more thorough dry, if you're comfortable taking it apart again, do so, wrap in a couple layers of paper towels, lay on a cloth towel on a cookie sheet, and put in your oven, if you can get a setting under 200 degrees F. There is often a Bread Proofing or 'Keep Warm' setting that will be in this range. Put it in overnight to let the higher temp actively drive more water out. I did this with my iPhone 4s that I inadvertently ran through the washing machine in a pants pocket. Next morning, after cooling off and re-charge, worked fine. When you're done, let the phone cool slowly - no putting it in the fridge, you'll condense water on it. Put it back together and charge, see if things improved.
the other possibility is that the source of the wet either carried crud in that's all over the electronics, or it corroded stuff. If you have corrosion, you have little to lose trying to gently clean it, but corroded electonics are rarely more than circling the drain before they fail.
As a general drying-of-electronics tip, go to a Michaels, or other craft store, and get a can of flower-drying dessicant. It's not that expensive, and made specifically to suck up moisture at room temp. Next time a phone drops in the sink, wrap it in a layer of paper towel (to keep dessicant from migrating into the earphone jack, charging port, etc), optionally warm in a gentle oven again to encourage the water to take to the air, and be patient. It works better than the dry rice that is often recommended as a moisture soaker.
Good Luck!
Nov 18, 2015 | Cell Phones
Water spilled on the display
Not sure exactly what happened but I do know if anything wet spills on anything electronic... computer, tv, cell/mobile phone etc, I've gotten them all to work by pulling panels apart(when possible) and letting dry out and sometimes drying it with a hair dryer. Item should be left out to dry for quite a few days. Do not do this with any current hooked up.
Aug 05, 2013 | Televison & Video
Wet LG Xpression
Hi Sandi
Dont switch the phone on! Place it somewhere warm and dry overnight, remove the back cover if possible and leave it to dry out. Hope this works for you.
Feb 19, 2013 | LG AT&T Xpression c395 Used CePhone
Phone got wet need to take apart to dry...how?
One method that has worked for many people and water damaged phones, (myself included), is to put the phone in small zip lock bag of rice to dry.
Simply disassemble the back cover, remove the battery, and place the phone in a zip-lock bag filled about half way with white rice. The moisture in the phone from the water should be absorbed by the rice after a few hours. This is best done every evening for a week or so until the phone has completely dried out.
It is best not to wait until the phone has dried on it's own after a few days, because if water evaporates on it's own in the phone, it can leave behind residue on the internals of the circuit board.
Jun 14, 2011 | Pantech Pursuit P9020
My phone got wet while i was in a rain storm the phone works but the screen is dark can this be fixed?
try letting it dry out . take it apart slowly so that the screen can dry that could solve it
Nov 04, 2010 | Motorola Mobility Tundra VA76r Cell Phone
Blackberry Storm got wet and does not even turn on now. Switched batteries, placed in bag of rice and blew fan on it for two days - all to no avail.
some times water is still in the phone...
If you have a blow dryer then u can dry it out...
By turning it on every side the phone will get hot but will dry it out...
The battery may have water in it too do the same to it....
Do this for 3 days then try to charge your cell phone for 24hrs...
Then push the power on to see if it works and some times u have to press the power switch down 2 or more times....
Because my phone does that some times..
So good luck to ya..,,,
Oct 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
My LG enV3 got slightly wet. Everything works inside just fine. The outside screen is blank it will receive calls but get nothin from any of the other keys. Can the face be popped off and a new circuit...
take phone apart and put all pieces in a bag with rice overnight. Also note that the sticker on the battery and phone changed colors and if you find an older phone and switch stickers then it may work after it dried out completely.
Sep 09, 2009 | LG Cell Phones
Blackberry storm
Like many electronic screens, I prefer basic water and mirofiber. Take a microfiber cloth, lightly wet it so there is very little moistness. Go over the screen with it, then use a dry piece of the microfiber to dry.
Jun 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
Phones are dead
If your phone is wet because of the storm open you cell phone using the presicion screw and make it dry naturally but before that you have to replace everything the motherboard of your cell phone is main trouble you have to dry it naturally and after it is dry you can put it in its original position and try your cell phone to use..
Jul 01, 2008 | GE 25932 Twin Cordless Phone
Phone got wet
I would definately let it dry out fully. Take the battery out and take it apart as much as you can and place in front of a fan (probably overnight). If there was water in the phone when you plugged it in it could permanently damage the phone. Even though the outside is dry, there could still be some water inside. I once had a remote control in a swimming pool overnight and followed these instructions and it worked fine after a couple days of drying. Hope this helps!
Nov 06, 2007 | Motorola Mobility RAZR V3
Motorola Mobility W490 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
