Question about Sony Playstation 3 (PS3) Console
Which modem from telus works best with the ps3 i have a siemens gateway SE567 and always gets the NAT type 3 issue, so i need to know which one will give me nat type 2 or 1 if there are any available from them
  • stricklan362 Aug 09, 2010
    yeah i tried that the siemens modem/router hates the ps3 and the ps3 the same there is no options to forward ports or put the ps3 on the dmz or anything like that alot of people have had the problem with this modem and have tried every option that one can offer....so any help with what type of modem would work from them or even if there is a way to make this modem just a basic modem "dumb" the modem up
    Scholar:
  • 203 Answers
Go to your favorite search engine and look up the manual for your router/modem. Every router and modem has a way to alter your NAT, you just need to look through the manual to have it tell you :)
Posted on Aug 09, 2010
Ps3 slow downloading with at&t
ATT is not the fastest service but if you get 25 MPS that should be enough to avoid buffering. The OS should be Win 10 "CURRENT updated version" for best communication and fast drivers. Try a program from Tweating.com called WIN repair, Free. This can remove jammed code that slows down an OS. Other issues are the amount of RAM, type of RAM, Ram Speed. Be certain all device drivers are up to date also. If the computer is using Wireless to Modem/Internet, try a direct CAT5/6 Ethernet connection.
Feb 06, 2018 | Gateway At&t 2 Wire Internet Wireless...
Find se567 manual
Try this link
http://setuprouter.com/router/siemens/gigaset-se567/manual-1055.pdf
Dec 05, 2012 | Siemens Gigaset Se567 54 Mbps 4-port...
I am trying to games on PS3 and cannot connect with friends. I believe this is because I have NAT Type 3 (closed) and I would like to change it to NAT Type 2 (moderate) but I do not know how.
Hi ..
The PS3 has 3 different NAT types. They are shown below.
Type 1: The PS3 is connected to the Internet without a firewall or router. No NAT issues.Type 2: The PS3 is connected to the Internet through a router which is configured correctly. No NAT issues.Type 3: The PS3 is connected to the Internet through a router that needs configuring.Ideally, you want to have a Type 2 NAT. However, a Type 1 NAT does not affect your game play.
First of all you will have to Disable the firewall in the Router / Modem
If you are using a Router ..
Then
Make sure that UPnP(Universal Plug n Play) is enabled
Enable the IP Address of the PS3 in DMZ
Or Forward the ports
Below are the TCP and UDP ports that need to be forwarded:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
For more details on port forwarding , log on to http://portforward.com/english/routers/port_forwarding/routerindex.htm
Hope it helps
Regards
Tom
Aug 18, 2011 | Computers & Internet
How do you achieve a nat type 1 or a nat type 2 connection to a playstation3?
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Make sure that UPnP is Enabled
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Jan 04, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
PS3 NAT type 3 issue
HI, Upgrade the firmware on the router and then forward ports on the router for the IP Address of your PS3.
Let me know if you need any further help.
Sep 06, 2009 | NetGear RangeMax WPN824 Router
Telus Router - Siemens SE567 Gigaset
login to the router using the ip address 192.168.1.254 default password is telus
Jul 26, 2009 | Computers & Internet
PS3 NAT type problem using Zyxel P-660R-D1 series DSL Modem
thanks for help , the error was from user that have viruse on his pc , thanks again
Nov 11, 2008 | Zyxel P660HW-D1 Router
Speedstream 4200
I keep get a NAT type 3 on my ps3. I've been told when plugging the modem straight into the ps3 it should be type 2. After looking on the net it seems that there is some type of problem because of the Speedstream 4200 Modem. Is there some type of setting I could change on this modem to make it better?
Sep 04, 2008 | Siemens SpeedStream 4200 (13A4200001)...
I have called my Isp about changing my NAT type of my Playstaion 3 from 3 to 1 or 2. I was given numbers from sony to put in the TCP and UDP ports but telus cannot change these function in my SE567...
you are with telus probably? This I believe is a sony software problem or the sony network I have read about this problem for xbox too, however, the problem is fairly new and the router worked fine until the sony firmware update. telus will give you a new router if you bull**** them about how screwed up that one is ( Be Creative) , dont tell them it is the ps3 giving you the trouble they do not support that product and they will not do much for you I dont think. Other than that it is sad really up until this I kind of liked the se567 oh well I guess.
PS. this is the only real solution other than buying a new router yourself.
Aug 09, 2008 | Video Game Consoles & Games
Modem vs ps3 nat type 3
it probably has a built in router for which you nee to open up your ports
Jun 22, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Sony Playstation 3 (PS3) Console Logo
355 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
