Have high end mitsubishi xc-3716c crt monitor. need atsc tuner. new to this stuff,need help
  • 4 more comments
  • ken henderson Apr 28, 2008
    want atsc tuner that will scale this monitior correctly,dvr would be great,has rgb rca s video inputs,need manual and remote. haven't found anything on the net about this unit,help!
    need atsc tuner,reread my post!
    The Mitsubishi 37 inch Monitor was the most desirable one used at functions, racetracks, displays, etc...
    Model (XC-3716C)
    Manufacturer's product description
    Mitsubishi represents the pinnacle in technological achievement for multi-person viewing of workstation generated, high resolution imagery such as CAD/CAM/CAE or scientific visualization. With its 37" (35.0" diagonal viewable image) flat-square CRT, Dynamic Beam Forming for improved image definition at monitor screen edges and with exceptionally sharp 1280 x 1024/75 Hz non-interlaced addressable resolution that is bright and bold even in high ambient lighting, the monitor delivers unparalleled performance and versatility. It also comes equipped with stereo sound and operates from virtually any worldwide video standard, plus compatibility with today's most popular graphics standards. Front control panel or multi-function wireless remote control (NOT INCLUDED) and on-screen display of all set-up functions make control adjustments, as well as input selections, easy and accurate. The XC-3716C color display monitor will truly make your next technical presentation sizzle with unforgettable impact. This unit was built in 1995 and has not seen any serious use since the year 2000
    General
    # Display Type: Presentation display / CRT - stationary
    # Width: 34"
    # Depth: 23"
    # Height: 29"
    # Weight: 209 lbs
    # Enclosure Colour: Gray
    # Compatibility: PC, Mac, Unix
    Display
    # Diagonal Size: 37"
    # Viewable Size: 35"
    # Max Resolution: 1280 x 1024 / 75 Hz
    # Colour support: 24-bit (16.7M colours)
    # Max Sync Rate (V x H): 120 Hz x 85 kHz
    # Factory Preset Resolution Modes: 1280 x 1024 / 75 Hz
    # Front Panel Controls: Power on/off, adjust +/- , colour adjustment
    # On-Screen Controls: Contrast, brightness, H/V-position, H/V-size, degauss, trapezoid, parallelogram, OSD-position, colour temperature selection, audio volume, speaker on/off, select
    # Features: Invar shadow mask
    # Compliant Standards: UL, CSA, DHHS, PTB, FCC-B, FCC-A, VCCI-I
    Video input
    # Analogue Video Format: NTSC, SECAM, PAL, M-NTSC
    # Analogue video Signal: RGB, S-Video, composite video
    Audio output
    # Type: Speaker(s) - integrated
    # Sound Output Mode: Stereo
    # Audio Amplifier: Integrated
    # Speaker(s): 2 x right / left channel
    Connectivity
    Port(s) Total / Connector Type:
    * Audio - line-out
    * 1 x - 1
    No burn ins - Crystal Clear Picture
    Accepts RGB input with special cable that is provided
    VGA inputs for computers and such
    Working condition like new - true colors
    Excellent as a CCTV monitor for security systems
    No Remote - A universal remote unit will work with this model
    This unit was used as a TV computer monitor in a famous recording studio in Miami, Florida.
    This Mitsubishi is being sold AS-IS
    Monitor has been checked out and it is in perfect working condition.
  • ken henderson Apr 30, 2008
    which ota stb is best for this unit?
  • ken henderson May 03, 2008
    am i right in thinking rgb ports are the best inputs on this unit? can anyone tell me if the hdfury-hdmi to rgb converter will work for me? if so then i'd be set for newest stuff right?
  • ken henderson May 04, 2008
    i live in north central iowa,usa.
  • 19,396 Answers
HDfury is a simple device that will allow you to use in 1080p resolutionany HDMI tuner or other device on your, therefore, unless there is an additional problem (faults etc.) , it will work
Posted on May 03, 2008
  • 1 more comment
  • Ginko
    Ginko May 03, 2008
    Regarding the atsc tuner (or HDTV tuner) I can have a look for prices and specs, I need to know your location, and what kind of tuner you need (eg internal on PC etc.)
  • Ginko
    Ginko May 03, 2008
    Best input for hdmi is always hdmi, if you have one, if not, like in your case, you need to use a converter, this will give you HDMI resolution, but can cause some trouble if it moves being quite an heavy adapter.
  • Ginko
    Ginko May 03, 2008
    Here is an example of stand alone atsc tuner (in UK):
    http://www.limitedgoods.com/itemView.php...">
    http://www.limitedgoods.com/itemView.php...">GRANDTEC TUN-5000 Airvision ATSC DTV/HDTV Receiver
    If you connect it to your monitor using an adapter you will get HDMI signal on HDMI channels
    President:
  • 2,712 Answers
Hello jabjab56,
THIS
is what you need, and at $47, you cant go wrong :) Its got all you want ATSC tuner, remote, installation CD, manual, comes with different output ports, etc.
or you can take a look at THIS as well, although I am not sure if there is a remote control with it.
Hope that helps...Should you have any further questions, please feel free to post them here. REMEMBER, please don't assign a rating until you are satisfied, or I have run out of solutions :) Sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 30, 2008
  • Swilin Sampson
    Swilin Sampson May 02, 2008
    Just checking to see if your issue has been resolved… If
    you find that the solution/answer I provided led you to, or resulted in a fix,
    please take a moment to close the ticket with a FixYa! rating under my
    solution.
    I would be very grateful for your show of appreciation.
    post them here.
    Cheers!
    IrishDruid
  • 563 Answers
Have you tried www.mitsubishielectric.com yet ?
    Genius:
  • 1,665 Answers
Did you check ebay?
http://search.ebay.com/atsc-tuner
Posted on Apr 28, 2008
    Genius:
  • 1,142 Answers
    Guru:
  • 1,894 Answers
Have you bought that tuner and asking for help or u need to buy tat tuner?
be clear..
    Genius:
  • 1,447 Answers
You can check this site for info:
Info
and for atsc
ATSC
Posted on Apr 27, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 03, 2008
    Honestly it may or may not work, since you are introducing a third party device which is the adapter. try VGA- HDMI port adapter instead.
    Brigadier General:
  • 6,966 Answers
An ATSC tuner, often called an ATSC receiver or HDTV tuner, allows reception of ATSC digital television (DTV) signals broadcast over-the-air by TV stations in certain regions/countries. An example is a SONY EBSSP35 External High Definition TV Tuner. Others are incorporated as part of a DVD Recorder/Player such as a Samsung DVD-AR650 ATSC DVD Recorder. Of course, you need to check signal input connectors compatibility but generally most would work with each other.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Apr 27, 2008
    Hi again,
    with the indulgence of iqbal_del and s4u311...
    There is a Mitsubishi digital Video recorder that has a built-in HD tuner that is compatible with your high end TV/monitor, Mitsubishi HD-6000 DVR/HD receiver. Here is a fine review detailing features (pros & cons).
    Cheers.
  • 813 Answers
  • 655 Answers
Fujitsu P42xta51: Does my fujitsu have ATSC tuning
Yes, the P42XTA51U has an ATSC (digital OTA) tuner. This is given in the specifications for the Fujitsu 51 Series TVs. That document is available here: http://www.hdtvsolutions.com/Fujitsu-P63XTA51US.htm . The direct link to the specifications sheet is http://www.hdtvsolutions.com/pdf/ht_tuner_brochure.pdf . Fujitsu had to include an ATSC tuner because the TV was manufactured in 2005. U.S. law required TVs over 36" have an ATSC tuner starting in 2005.
If you use the appropriate antenna, you'll be able to watch OTA broadcasts. I recommend checking with TVfool.com for antenna suggestions and the angle between your location and the transmitters. ( antennaweb.org assumes an external antenna but is very conservative in the list of available stations.)
I hope this helps.
Oct 30, 2015 | Fujitsu Plasmavision 42" TV
How can i tell if my tv is digital
The iLo IWT3206 TV provides two built-in -- or integrated -- TV tuners: a National Television System Committee (NTSC) tuner and an Advanced Television Systems Committee (ATSC) tuner.
While the NTSC tuner allows iLo IWT3206-viewers to receive analog, free-to-air TV broadcasts, the ATSC tuner allows viewers to receive digital TV broadcasts via a cable or satellite provider.
The benefit of having an integrated ATSC tuner is that it negates the need for a separate cable box or satellite receiver, which can take up space.
Oct 24, 2013 | iLO IWT3206 TV
Can a toshiba 28z07b be digitally tuned
Your TV set has a 181 Channel Tuner and 100 Programme Positions..
Over the air signals (analog and digital) are free but require an special antennas for Digital reception and reception depends on your where you live and other factors.
Additionally Cable and satellite signals require you to connect a cable to your
TV tuner and a subscription and cable box for premium channels including Digital channels..
While all l TV tuners have the ability to receive over the air TV signals,
not all tuners can receive high definition (HD) signals. In North America, all
over-the-air TV is now broadcast in digital quality (ATSC).
ATSC is the over the air HDTV standard for North America and is currently available
in over 200 cities in the United States.
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 29, 2011 | Toshiba Televison & Video
Is jvc av-32d503 digital ready or do I need to buy a converter box for use with an outside antenna system
Looks like you'll need a converter.
Here's some background info:
Analog TVs were made up until 2007.
Digital tuners for over the air signals are called "ATSC tuners".
To tell if your TV has one:
-If the TV was sold as a "HDTV" or "DTV", it's supposed to have an ATSC tuner built in to it. "HD ready TVs" do not have a digital tuner.
-Check the specs in the owners manual or google the make & model of the TV to see if it has an ATSC tuner.
-If your TV's menu has an option for scaning for digital channels, then it has an ATSC tuner. If it dosen't have a way to scan for digital channels, then it doesn't have a digial tuner.
Most DTVs also have a digital QAM tuner that is used in some (but not all) cable systems.
Jun 11, 2011 | JVC AV-32D503 32" TV
What type of antenna do you reccomend cant get the tv to work at all no picture no sound not using cable no antenna tried auto PLEASE ADVISE!!!!!!!!!!!!!
Lets get started. First the TV you have does not have the new ATSC digital tuner built in. It uses the old NTSC tuner. You might find a few stations, however most major networks have gone Digital because the maximum power for NTSC is limited to 1000 watts. ATSC is the new digital standard for broadcasting both High Definition programs as well as standard definitions programs. So you will need a Digital converter box. They sell them at Radio Shack for around $60. You can get one on ebay for around $25. You will also need and antenna. A good old set of rabbit ears will work fine if you not to far (less than 25 miles) from the transmission towers. If your out in a rural area (greater than 25 miles from the tower) you may want to consider and outdoor antenna. Antennas Direct is a great source for antennas.
http://www.antennasdirect.com/
You can also get help estimating what kind of antenna you need at this web site:
http://www.antennaweb.org/aw/Address.aspx
However you may want to consider buying a new TV which will have a new ATSC tuner built in. You will still need and antenna.
Hope this helps.
Feb 23, 2010 | Philips 25TR19C 25" TV
Do you need a converter box with model CLC502 TV
I am not familiar with this TV but if you look in the manula and it does not say it has a digital ATSC tuner, then you need a converter box. If the TV is more than about 3 or 4 years old it is unlikely it will have an ATSC tuner.
Dec 26, 2009 | Craig Televison & Video
Analog or Digital Tuner in TV?
ATSC is the name given to the new digital signal. NTSC is the current analogue signal. This is the standard name given to the American system of broadcasting.
May 27, 2009 | Audiovox Televison & Video
Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Jan 08, 2009 | Toshiba 24AF42 24" TV
Do I have a ATSC tuner in my 2002 Quasar 27" TV?
NTSC is the (analog) standard passing into history in Feb. '09 and ATSC is the new digital standard being used afterward for over-the-air (reception by antenna) broadcasts. This changeover affects only the broadcast channels and if you have cable or satellite reception the changeover will happen whenever they find they can't charge their captive audience such a high premium for HD.
I found no evidence that your set is ATSC ready so if you are receiving your signal by antenna, you need to scurry about and buy a converter for your set. Make sure the one you buy is on the list of 'approved' models to which you can apply the $40 coupon(s).
Coupon & info site
Oct 05, 2008 | Quasar SP-2725 27" TV
Mitsubishi xc-3716c monitor
ttl is in short from Transistor-Transistor Logic.
Apr 18, 2008 | Computers & Internet
Computers & Internet Logo
182 people viewed this question
David Payne
David Payne
