Question about Panasonic Viera TH-50PX80U Plasma TV
Have a panasonic th50px600u,have no power anywhere,no lights,no blinking light,nothing!!!! checked all fuses-ok,was told it needed new power supply board-just put in tonight-still not a thing!!! i ordered a new off/on switch board,what about noise filter,where power cord plugs in??? was told it was the dg board this time around-could this cause the tv to not power up at all?
  • hugjean5 Aug 07, 2010
    sorry,but like i said im getting nothing ,no power-no clicks,no sounds, no lites at all,its like it wasnt plugged in period!!!and it has the new power board i installed last night-help
    yes i will accept this answer,1st time anyone mentioned power cord,may be something that simple,like i said ,it doest seem to be getting any power to tv-no lites-no blinking lites-no clicking at all!!!!nothing,also noise filter where plugs into power cord could be faulty-thankswill check all and hope something happens
  • Panasonic Master
  • 11,800 Answers
Before replacing any more parts you should do some testing: first make sure that the power cord is ok (no, it's not stupid, you wouldn't belive how many times i stumbled on that); next you should check the noise filter; next the power button (including the starter contact); next the rectifier of the power board; next the output of the power board. From there , if you find a faulty output, you should check the parts/boards powered by that output. Only after you have identified the failed parts you should order them.
Posted on Aug 07, 2010
  • Panasonic Master
  • 5,807 Answers
Hi
hugjean5,
Thanks in advance for choosing Fixya for Assistance
• It could be causes from a bad or group of defective
components
First you need to understand that there are Voltages applied to the
Electronics Components/ Circuits to work.
And these voltages can affect and control the system status, as it has
protections circuits even from the Microprocessor built-in inside your TV.
To know the cause , you may need to open it up ,
Only if you feel you can.
• You may need to measure voltages, But sense of hearing and a
good visual may partially aid you in localizing the problem.
How to test for Continuity
How to use a multimeter
Here are some of troubleshooting Guide:
• When the Plasma TV is plugged in, there’re a few
indications of normal operation. Knowing this will help us
understand what’s going on with the unit when an
abnormality occurs.
1.There is a click from the relays RL402 and RL403
when they are activated.
2.The LED in the Optical Jack inside the DT board turns on
for approx. 4 seconds.
3.Immediately after that, one of the Tuner LEDs (Right) turns on
( Solid Red ) for approximately 20 seconds.
4.The LED in the Optical Jack inside the DT board turns on again for
approx. 1 second and both LEDs (tuner and optical jack) turn off.
5. Then you will hear another click from the relays RL402
and RL403 indicating that they are no-longer engaged and
the Optical Jack LED turn off.)
• You need to check For Standby Voltages
STB 5V and 12V
FSTB 14
For complete troubleshooting :
Service Manual can be downloaded here:
http://www.tradebit.com/filedetail.php/87841602-panasonic-th-50px600u-service-manual-repair-guide
Only with a fee.
• Use it to properly guide and aid you in further troubleshooting.
Regards and Good luck!
palaboy
PANASONIC PLASMA TV- TC-P50G10-03/09-MD90690706 NO PICTURE
Could be an open internal fuse or power supply failure
Jul 13, 2017 | Panasonic Televison & Video
Panasonic Plasma TC-P42C1 10 light blink code, then the light came on and then no light at all-nothing! Power Suppy board?
By blinking led its shows where is exactly the complaint. You have to count the blinking. How much time its blinks in one sequence. the only it will be possible to say is it power supply or any other boards.
www.electro-medical.blogspot.com
Sep 03, 2015 | Panasonic Televison & Video
My Panasonic TV turns on and off continuously once powered on. It makes no sounds, clicks, or blinks of indicator light. Stays off for 1-2 seconds at a time. All fans are working. any ideas?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 23, 2015 | Panasonic TH50PX600U 50 Inch Plasma Flat...
Black screen blinking red light Viera TV 42ld24
First try resetting the unit by unplugging for 30 seconds to 1 minute. plug back in to see what happens. I red light still blinking may be power supply or Main PCB. check voltages from power supply to verify its OK. of all those voltages OK, check the Main PCB.
TZRXN01PTUUS $250.00
http://www.ued.net/ued/viewItemAction.do?itemCode=MSCTZRXN01PVUUS%2FDUD
N0AE3GJ00007S
power supply $72.31 http://www.shopjimmy.com/catalogsearch/result/?q=N0AE3GJ00007S
Apr 02, 2014 | Panasonic Consumer TC-L42D30 42"Viera Full...
Magnavox 37MF321D/37. suddenly just shut off and would not turn back on, no blinking green light nothing!
Price the board first and then decide, I fix these in our shop but do not like or enjoy working on them at all.
Dec 20, 2012 | Toymax Magnavox 37MF231D 37 in. LCD TV
I have a Panasonic 32 inch HDTV. TV worked great until one day tried to turn on and nothing. It acts like it has no electrical power. We have tried plugging into different outlets with no luck. The red...
One simple solution may be to replace the power cable or the power strip that the TV is plugged in to. If you cannot get any power to the TV even after this step, it is most likely a motherboard or some sort of circuitry issue. Make sure you are using the physical buttons on the TV when trying to turn the TV on; leave the remote out of the equation. If it still does not come on, your TV may be far gone. HDTVs have a lifespan these days of anywhere between 3-5 years for plasma, 5-7 years for LCD, and the new LED tvs are supposed to last anywhere between 7-10 years.
Feb 28, 2011 | Panasonic Televison & Video
Panasonic TH42PX80U will not turn on power indicator light blinking
when the power indicator light are blinking, indicate that the TV are in protection mode.
Undo the Back and check for bad caps in the power board, or any blow fuse.
Fosg2000, Rate me please
Apr 25, 2010 | Panasonic Viera TH-42PX80U Plasma TV
2002 Jetta stereo isn't working
Check eBay...you need a double-din Monsoon Radio...make sure it comes with a code to unlock it.
May 18, 2009 | 2002 Volkswagen Jetta TDI
Panasonic Viera TH-50PX80U Plasma TV Logo
213 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
