Question about Sunfire True Sub MK II Subwoofer
Which side is the passive speaker on? - Sunfire True Sub MK II Subwoofer
If you are looking at the sub from the back (side with the volume knob etc) then the passive speaker is on the right.
Posted on Oct 12, 2010
How to make speakers louder.turned up volume on high and still cannot hear good
Are the speakers active (I suspect not) or passive?
If passive speakers (no amplifier inside) change them for active speakers with an amplifier.
Mar 23, 2015 | Audio Players & Recorders
I don't sound from my left Edifier M1250 speaker
If possible, swap the speakers side for side. If that same speaker does not work on the opposite side, the speaker is likely defective. However, the connection to your computer could be bad, causing one channel to drop out.
Dec 29, 2013 | Edifier M1250 2.0 Multimedia Speaker...
How do I hook up passive subs to my board
Sub outs needs an active speaker.
An active speaker have a built in amplifier and preamplifier.
For a passive speaker it needs an amplifier.
Oct 01, 2012 | Mackie 2404-VLZ3 Mixer
How do I hook up two powered 15's and two passive 15's to this mixer(1202-VLZ3)?
You connect the powered 15's using balanced cables. The passive speakers you will have to get an amplifier for as the mixer does NOT have a powered output, only line-level audio outputs.
The powered speakers MAY have audio line level outputs to continue to other powered speakers or, as in your case, external amplifiers to drive your passive speakers.
Remember to power ALL interconnected equipment from the same receptacle or source to avoid ground bounce faults that can destroy sensitive circuits in your equipment.
Mar 05, 2011 | Mackie 1202vlz3 12 Channel Mixer
I have been using two Peavey Pro 15 Mk ii 300 Watt Passive 15" Speakers with two additional speakers on the output side and i notice one of the peavey speakes wasnt working! i then realised i had the...
Passive speakers with 1/4 inch jacks do not define either as input as they are wired in parallel...
Assuming the speakers you added were each no less than 8 ohms this should NOT have overloaded your amp.If you have no sound you have probably blown your amp some way.
Note some amps can be blown if they are on and EITHER side of the speaker cable touches a ground. If the amp is running and a 1/4 inch plug is pulled, it shorts and can blow the amp.
Jan 17, 2011 | Peavey PR15 400w PA Speakers
How many watts is these woofers?
Manufacturer Alpine Wattage 600 Watt Speakers Format Round Active / Passive Speakers Passive Speakers Installation Built-In Category Pair of Speakers, Subwoofer Number of Ways 2, 1 Size (Diameter) in mm 250 EAN 4958043515356
Sep 30, 2010 | Alpine SWS-1040 Car Subwoofer
Passive radiator speaker wiring
Passive Radiators are not driven by the amp. They have no voice coil and no power goes to them. They are used to enhance the bass or lower frequencies in a speaker system. They work by utilizing the back pressure that a driver (woofer) produces. When a woofer produces sound, it moves forward and backwards inside the speaker cabinet. This backward motion is what drives the passive radiator. So in order for the passive radiator to work, it would have to be placed in speaker cabinet along with a woofer that is hooked up to an audio amp.
Jul 23, 2009 | Audio Players & Recorders
Convert passive speaker to active
You don't say anything about your passive speaker, only thing that I understand you have a Yamaha AX-396 witch have an Power output of 60 watts per channel into 8 ohms (stereo)! That means working great with your passive speaker!!!
Apr 27, 2009 | Yamaha AX-396 Amplifier
Sunfire True Sub MK II Subwoofer Logo
99 people viewed this question
Top Sunfire Audio Players & Recorders Experts
shaun taylor
woodzowl307
Joseph Hoffmann
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
