Question about Kitchen Ranges
There is no clicking when you turn on the gas on a burner - plugged in - gas flowing.
  • 4,323 Answers
Hi
Clicking sound comes from the gas burner comes from the spark module. To check this remove the burner knobs and then clean the ignition switches. Dry them by blowing air and then check. If still not working then you’ll need to get the ignition switch replaced. However, if the ignition switches (costs around $10-30) looks fine then there might be an issue with the spark module (would cost between $25 - $60).
Hope this helps you to resolve the issue.
Thanks
Daniel
Posted on Aug 07, 2010
Gas oven/elec start glow plug comes on and remains on, gas burner does not light
I am not familiar with this unit but first I would see if gas is flowing, if so I would go with the glow plug, or can you switch with another burner. Normally you need a flame to turn off the igniter.
Aug 24, 2014 | Kitchen Ranges
Frigidaire professional series gas stove does not light. When handle is turned the "clicking" sound happens, with the smell of gas but no flame. what could be problem? 3 other burners work...
A few months ago I lost one igniter on the left front burner. It clicks and gas flows but wont ignite.Now when I turn on the left back burner, the gas still flows but I hear clicking on the right side, not from that burner. It wont light either.
Dec 17, 2010 | Frigidaire FEF336BC Electric Kitchen Range
NO GAS FLOW INTO BURNER TANK FULL. ALL CONNECTIONS OK. NO GAS FLOW TO BURNER
Hopefully it is something simple like turning on the full tank too fast. Turn it off, disconnect it, reconnect it and turn tank valve back on very slowly. If this doesn't resolve the issue, click on my username and scroll down my profile to my tips and tricks for gas grill lighting issues. One of them should help.
May 16, 2010 | Weber Q Grill
Burner won't light
is gas comeing out of the hole? sometimes by cleaning the orfice hole (food and debrie will get in there and plug the hole not letting the gas come through) i get a needle and poke it.
when you say it is sparking...When you turn the dial for that specific one you want ignited... That one is sparking? If so Great. This means you either have a plug or the valve is bad and not letting the gas flow through.
Apr 04, 2009 | Amana AKS3040 Gas Cooktop
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
The three burners on the top of the range will not light.
You either have an issue with gas flow from the control valves or with the piezoelectric gas igniters. Turn the knob to low and try lighting the burners by hand. If they work, then your problem is not gas flow but the ignition. Turn the knobs to light and see if each burner clicks and you see sparks at the igniters. If you are not seeing a spark, try cleaning up the igniter tips. If that doesn't do it, it is probably time to call the service technician (or the Hotpoint Customer Service hotline).
Mar 03, 2009 | Hotpoint RGB745 Gas Kitchen Range
BBQ Galore Capt'n Cook 4 burner gas grill won't get hot.
Most modern gas regulators have a safety feature to prevent gas left on. If you shut off the tank first and then turn off the burners, it will trigger and keep the gas flow at a very reduce flow to prevent you from turning on the tank again with the burners left on and not realizing it. Turn everything off and then turn on tank first, followed by the burners and this will solve most problems of a low flame or a bbq that won't get hot.
Dec 05, 2008 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Gas Flow
suspect problem is with the regulator on the gas bottle as it would be unusual for all burners to be faulty at the same time. try substituting a new regulator
May 18, 2007 | GE 30 in. JGP337 Gas Cooktop
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
