Panasonic viera 32inch. when swaping from terrestial tv to AV the AV1/RGB stays displayed on the top left of the screen. please advise. many thanks.
  • 4,889 Answers
I dont think this is an OSD problem.. Anyways try it and post back so that I can take it from there..
Posted on Apr 27, 2008
    Brigadier General:
  • 6,966 Answers
Initially, pls check if the OSD (on screen display) is enabled. Perhaps you can try on the remote to deactivate.
Should the problem persist, it may be a glitch on the firmware. Have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (from a few minutes to a couple of hours).
Pls post back for any development(s) or even the lack of it.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
Need code to remove green av1 in corner one for all remote
Press the "Display" button on the remote control to get rid of it.
Aug 11, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
No picture just av1
If the cat sat on the remote, it is likely it changed the tv to AV1. Just find the AV button on the remote and press it again and again. It should cycle through the different AV channels your TV has - my TV has 6 AVs, 2 HDMI and a PC channel so if yours is anything like mine, you may need to press several time to get back to your Sky/freesat/virgin box. Alternatively, some HDMI connected kit just needs turning off and on. That then sends a signal to the TV which changes the TV automatically. For example, my Blu-ray player does that.
Experience - I have a cat that sits on my remote and does the same thing!!
Jul 31, 2012 | Panasonic 37" VIERA Full HD 1080p IPS LED...
I cannot record from a Daewoo DVD recorder ( 8150P) through my Viera TV ( model TX-L32S20B ). The screen says No Signal and instructs me to check inputs. I've tried using all cominations of AV1 and AV2...
If you want to record from the TV to the DVD recorder you have to first select a channel on the TV that you want to record and then take an AV cable ( Yellow / Red / White ) and connect from the Monitor out socket of the TV to the AV in of the Daewoo DVD recorder. Drop a blank DVD select AV on the Recorder and press the record button.
Mar 08, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
How do i get rid of AV1/RGB in top left hand corner
Pressing the ident key on the remote controller will fix that. It has a toggle action. Press for on and press again for off.
Dec 28, 2010 | Panasonic TX-36PF10 TV
My Panasonic Viera TX-L37U10B won't display my Sky+ picture when it is turned on. We have to opt for ''AV1'' every time the TV is turned on!!! Why won't it show my current Sky channel on boot up??
Because the default input is the antenna, not one of the external inputs. If you want it to be picked up at start remove all antenna cables and start the Sky receiver before starting the tv - this is because only when there are no signals from the antenna the tv starts to look at the AV inputs.
Jan 12, 2010 | Televison & Video
Had Sky installed. Displays EC1/RGB on left hand
Double clicked the i button on the TV remote - simples!
Jan 11, 2010 | Panasonic TX-32LX60 32 in. LCD Television
PANASONIC SA PT560
Need more details,you not too clear on your subject!
solutiondoct
Oct 26, 2008 | Panasonic Home Theater System System
Panasonic TV - want to remove on screen message
its an input message i dont have your remote in front of me but im going to say when you hit the input av1 av2 there should be a button on remote for display or info one of these buttons should deactivate that message
May 13, 2008 | Televison & Video
To suppress the AV1 symbol on screen
on original sony remote press the DISPLAY button once
Mar 26, 2008 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
