Question about Fossil Watch Style # CH2527 Watch for Men
How do you remove the screw type spring bar on a fossil ch2527?
Changing the battery in my AM3696 Fossil watch
first you had to take off the band of your watch by detaching either of the spring bar, then you will see the case back, probably you had to use small screw tools with its caseback. note: your watch has two batteries. i hope i had been helped you.
Jul 25, 2011 | Fossil Animated Leather Ages AM3696 Watch...
How do I remove links from a Seiko watch band?
Follow these steps and it will help u resize your watch.
1-Take a good look at the watch bracelet. Seiko watch bands are equipped with one of two different types of pins holding the links in place. One type is a simple, nail-shaped pushpin that's inserted into the joint between two links. The second is a flat, L-shaped piece of metal that slides into the center of a link and locks it into place. Both pins are removed using the same process. If the nail-shaped pushpin is present, you'll see the tiny screw heads in the joints. If the L-shaped pin is present, the links will be open-sided and you'll be able to see a strip of metal inserted in each links.
2-
Look for the arrows on the inside of the watch bracelet links. The arrows indicate the direction the pins and links need to be slid off of the band. Any attempt to go against the arrows could break or warp the links.
3-Remove the spring bar from the clasp with the small pin-removal tool. Set the watch up on it's side so that the top of the spring bar is facing up and the bottom is flush against the table. Put moderate pressure on the top of the spring bar and tilt the watch just a bit sideways so that the spring bar can slide out. Ease out the bar slowly and carefully; the spring bar is spring-loaded and will shoot away from the watch if you're not careful (make sure that the bottom of the watch is pointed away from you at all times). Put the spring bar in a small dish so it doesn't get lost.
4-Line up a small pin-removal tool with the top of the pin and push in the direction of the arrow until it slides out completely. Slide off the link. Place the pin and the link in the small dish. You'll want to save them in case the watch needs to be re-sized again at a later date. Continue removing links, alternating sides of the band to keep it even, until the watch reaches the desired size.
5-Reconnect the watch. On the side opposite where the spring bar was removed, line up the link connected to the clasp and the second link on the band. Slide the pin in the opposite direction of the arrow, using a flat-headed pin inserter to push it into the joint. Use the pin-removal tool to give it a final push, listening for the click.
6-
Reinsert the spring bar slowly, using the pin inserter. Make sure the spring bar is lined up and tightly in place to avoid injury.
Try this and it you cant manage it then you need to get it to a watch repair shop specializing in that brand.
Jan 09, 2011 | Watches
I want to shorten my watch band on my new Casio MTG900DA-8WC It has a metal band
In order to remove the links of your Mtg930 watch you will need a couple of tools . It is recommended to have a watch pin pusher and a spring bar remover tool in order to do so. If you do not you can use a small precision flat head screw driver , the size that is usually used to fix glasses or smaller.
First you need to lay a cloth down at a table . Lay the watch on top of cloth to prevent scratching . flip the watch upside down and have a good at the back of the watch bracelet.
If you look carefully you are going to see notches on the back of each link with an arrow pointing in. This is where the spring bars are accessible and can be pushed in to remove the link.
You need to place your spring bar remover, pin pusher or precision screw drive in the notch against the edge.
Mean while push the opposite side of the watch link up so you can see the most of the spring bar inside the notch.
The spring bar is going to look like a pink with a notch on the the top then gets smaller. As shown below on the left side of the picture. If you are looking at the notch on the spring bar, that is where you need to get our tool ontop of . So you can push down the spring bar.
Once you push down on that notch on the spring bar the link will be able to slip out . Without a spring bar remover it will be more difficult and you will need to be patient as you try to work your flat head screw driver into the notch and be able to push down . Once the pin is push down you need to pull the link from the rest of the bracelet.
Do not be surprised to take anywhere from 5 to 30 minutes if you have no experience and not have a spring bar remover.
Once you removed all the links you desire , You will need to put the spring bars back into the links and close the watch bracelet up.
The easiest way is to slip spring bar into middle of link. Bring the other end of the bracelet over so it the bottom covers the other link with the spring bar head out. Push the spring bar down with your tool as you slide the links back together.
Oct 17, 2010 | Casio G-Shock Atomic MTG930DA 8VCR watch
How do i get a replacement pin that goes on the clasp that locks and unlocks the watch band. Mine fell out and it wont stay closed now
mcdevito75 here, Your best bet is to visit a small watch repir shop in your area, I believe you"d need a spring bar type pin in the clasp and without the watch inhand sizeing the pin would be difficult.
Sep 21, 2010 | Fossil College Kaleido Alabama Kaleido II...
Would you happen to have a watch band pin (link that attaches band directly to the watch casing) for a Fossil Blue Model AM-3515? Great difficulty locating one of these. Thanks for any help on this.
mcdevito75 here, This pin is called a spring bar, while I have many of these I would need the watch to match up the spring bar with the caseing. Best Bet, see a small watch repair shop in your area. Approx. Cost, $5.00 plus install.
Aug 18, 2010 | Fossil Watches
How do I remove the back off a fossill watch to replace the batteries
If it doesn't have the indentations for a tool used to screw off the case back then its a pry off type and you need to use a sharp tool and pry off under the case against the band post
Nov 06, 2009 | Fossil Metal Chronograph White Dial ES1793...
Not sure what parts should be moving on new Fossil Me1020 watch.
I have a Fossil Twist ME1011, basically the same idea behind the one you have. What happens is there is a weighted third-circle that is in the back of the watch behind the battery (you can't see it) that spins a spring (the spring is the bottom seethrough part that ISN"T moving!) the spring then moved the UPPER seethrough part, which in turn spins the second hand!
IF the second hand stops working, carefully take the back off the watch and you'll see the weighted third-circle that I was talking about. It should spin, and in the middle there is a tiny flat head screw. The screw can get loose, so gently tighten it and the second hand should work again!
May 30, 2009 | Fossil ME1020 watch
How do you replace the watch band on a casio g-shock
The following proccedure mentioned can be implied for replacing only resin(plastic) strap.
If you have a spare Band, you can replace it with the help of one small four mouth screw driver and one small 1, 2 or 3 no. screw driver which you can get from any electronics/ computer hardware shop.
Band = Strap
You just need to remove the strap with the help of 1, 2 or 3 no. screw driver which ever you find convinent by removing the Spring Bars. After removing the strap put out spring bars from both sides as these may be used for again fixing the band.
If you find difficulty in removing the Band, you just need to unscrew the screws on for side of the watch case and remove the ring and after fixing the strap you can fix the ring again.
The new band can be fixed in the same way as it has been removed. You need to put the spring bar in the hollow space of strap and keeping the buckle side part of starp above the watch i.e 12 position over the space where it has to be fixed, then put one end of the Spring bar on one hole in the watch case and press the spring bar to get inside from other side (hole in the watch case). In the same way you can replace ******** other side.
In case of any difficulty take your watch to nearest Casio Service Centre for assistance or solution of problem.
Jul 20, 2008 | Casio Watches
Link removal
here are the steps SEARCH Watches Jewellery WATCHES JEWELLERY GIFT CENTER FEATURED ITEMS WATCH SPECIALS GIFT CERTIFICATES WHAT'S NEW HOME EN FRANCAIS ORDER TRACKING CURRENCY CONVERTER ABOUT US CONTACT US HELP How to Remove Watch Links The following method outlines how to remove most watch links. If you have any questions, please send us an email at Info@Webjeweller.com 1. Pin Type I 2. Leaf Spring Coupled Type 3.Single Screw Link Type 4.Snap Type 5.Bracelet Sizing Instructions 1. Pin Type I (Tools: Eyeleteer, Staking stand, Hammer or Pliers) Step 1. Set the watchband onto a staking stand or other appropriate holder. Step 2. Use an eyeleteer to push out the watchband connecting pin toward the arrow. If the pin is too tight, use a hammer to lightly tap out the pin. Step 3. Pull out the connecting pin with a pair of pliers. Step 4. The selected link can be disconnected from the adjoining link. 2. Leaf Spring Coupled Type (Tools: Tweezers or Pliers) Step 1. Use a pair of tweezers to push out the leaf spring of the link in the direction of the arrow. Step 2. Remove the leaf spring by using a pair of pliers. Step 3. Other types of leaf springs as illustrated above are also used in leaf Spring Coupled Type Watchbands. Step 4. Disconnect the link from its adjoining link. 3.Single Screw Link Type (Tools: 1-mm Screwdriver or Tweezers) Disassembly Step 1. Turn the watch on its side. Firmly grasp the bracelet in the area of the link you wish to remove. Insert the 1-mm screwdriver tip into the slot on the screw head. While applying gentel downward pressure on the screwdriver, turn the screwdriver counter clockwise to loosen the screw. Continue to turn in a counter clockwise motion until you can feel that the screw is completely free turing. Step 2. Grasp the end of the screw with the tip of a pair of tweezers and remove the screw from the link. Set the screw in a safe place for reassembly. Step 3. Once the screw is removed, the link will come apart. Repeat this for as many links as necessary. If removing an uneven number of links, remove the greater amount of links from the 6:00 side. Assembly Step 1. Reassembly is opposite of disassembly. Assemble the link, and turn the bracelet on its side. Insert the screw into the link either with a pair of tweezers or your fingers. The screw will only go into one side of the link. Step 2. With the bracelet still on its side, securely hold the bracelet between your fingers, and place the 1-mm screwdriver tip into the screw slot on the end of the screw. While using gentle downward pressure on the screwdriver, turn the screw in a clockwise direction until you feel the screw stop and the top of the screw is just below the edge of the edge of the bracelet. Do not apply more than gentle pressure on the screwdriver as it could cause the screwdriver tip to slip off the screw end, which may scratch the side of the bracelet. Step 3. Once the screw is screwed down in the link as fare as it will go, give the screwdriver one final"twist" to securely tighten the screw. Be careful not to use too much force as the screw head could become damaged. 4.Snap Type (Citizen Sizing Tool) Step 1. Remove the link pine in the direction of the arrow. Step 2. Grasp the band on either side of the link from which the pin was removed. Apply gentle upward pressure on the side nearest the case, while applying gentle downward pressure on the clasp side of the band. You will feel mechanism disengage. Step 3. While continuing to apply gentle pressure as outlined in the previous step, gently"rock" the band to completely release the mechainism. Step 4. After releasing the mechanism move the clasp side of the bracelet towards the case to dissemble the links. Step 5. Gently pull the links apart. Repeat the procedure for as many links as need removing. Reassembly is opposite of disassembly. 5.Bracelet Sizing Instructions (Tools: Citizen Blue Pin Pusher Link Joint Remover II or Tweezers) Link Components 1) Split Pipe -Two pieces, one at each end of the pin. Generally one split pipe will remain attached to pin during sizing. 2) Cylinder Link - Two pieces, one at each side of the bracelet link. 3) Link Pin - Connects link, cylinders and split pipes together. Step 1. Note the engraved arrow on the backside of the bracelet showing the direction in which the link pin should be pushed and lay the bracelet in the cradle as shown above. Align the pin of the pin pusher with the link pin, being careful to centre it. Once centreed?, apply slight pressure until you feel the pin begin to move and then turn fixture upright as shown in illustration . This slight pressure will keep the pin pusher in alignment with the link pin while the tool is being turned upright. Step 2. With the fixture standing in the upright position, apply even pressure to the pin pusher until the pin drops out. Step 3. Using the tweezers, set the pin/split pipe assembly and cylinder aside. If the cylinder comes off of the pin, reassemble the cylinder and pin. The split pipe for the link pin at this outside end is still on the pin and dose not need to be removed. To reassemble pin and cylinder, insert pin into the hole of the cylinder so that the split pipe rests in the recess of the cylinder. Set aside for use during reassembly of the bracelet. HOME TESTIMONIALS LEGAL NOTICE ORDER TRACKING F. A.Q'S REQUEST A WATCH ABOUT US CONTACT US En Fran?ais | Advertising Opportunities | Affiliate Program | Watches | Jewellery | Diamonds | Feedback | What's New Watch Search | Jewellery Search | Volume Pricing | Request a Watch | Specials | Privacy and Security | Site Map WebJeweller.com, Email: Info@WebJeweller.com Copyright © 1999-2006 webjeweller.com. All rights reserved.
Aug 10, 2007 | Fossil AM3425 Wrist Watch
Fossil Watch Style # CH2527 Watch for Men Logo
56 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
john h
Are you a Fossil Watch Expert? Answer questions, earn points and help others
