Question about Sharp Notevision PG-M20X Multimedia Projector
I turned the projector on and worked for a while then it stopped projecting the bulb light is blinking red and the power is green any help
  • 10,865 Answers
It appears that the unit is overheating. Make sure that the fan comes on and that you do not have the projector sitting on a rug or fabic that will restrict air flow. j.
Posted on Aug 07, 2010
Epson 460 powerlite hooked to smartboard green light blinking and no image.
Yes this is most likely the lamp. Does it eventually go back to just a red light?
Dec 06, 2012 | Epson PowerLite 410W LCD Projector
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
I plugged in my xd490u [mitsubishi] data projector...and then power turned red, status turned green for few some seconds. later power blinked [red + green] and did not work. can anyone tell me what the...
It sounds like your lamp may need replacing. Before you go that route try all of these:
-Make sure the lamp cover on the bottom is fully attached. -If you unplug the power cord while the fan is rotating, the lamp may not turn on about 1 minute when you plug the power cord next time. After the status indicator stops blinking press the power button to turn it back on. May have to press it multiple times. -If your Power Light continues to blink red/green then you should contact your dealer.
Sorry I couldn't be more helpful.
Feb 28, 2011 | Mitsubishi XD490U Multimedia Projector
Have a KDF 60Wf 655 will not turn on. Green light comes on then red light with 7 blinks any suggestions? Took bulb out but the bulb light never lit and the bulb doesn't look blown.
Wether it looks blown or not replace it and dont put oil from your fingers on the bulb. Also clean the cooling fans for the bulb and projector (which may mean taking the back off and taking apart projector). Dirt in the projector fans can cause a fault not allowing for the unit to turn on. All the cooling work ins conjunction with a good bulb.
Apr 24, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I turn on the 4805,green led blinks & bulb does not come on?
After a few minuets does the green blinking light turn to a red blinking light?
If so the problem is the lamp did not strike.Either the lamp has failed (most likely) or there is a problem with the power supply (less likely)
Feb 12, 2009 | InFocus ScreenPlay 4805 Multimedia...
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
Sharp Notevision PG-M20X Multimedia Projector Logo
199 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
