Question about G-Technology G-DRIVE (90801201) 250 GB Hard Drive
How do I reformat my G Drive mobile USB for using it on windows 7
1. Open Disk Management by right clicking on "My Computer" and then
clicking on "Manage."
2. Go to Disk Management and resize the window so you can view ALL the drives in the lower right section of Disk Management.
3. IMPORTANT!!! Locate the Disk # next to the disk that indicates
"GPT Protective Partition" In the example below it is Disk 1. Be sure to locate YOUR DISK # and don't just choose Disk 1 because of the sample image
below. It is only an example!!!
4. Open a Command window by clicking on the "START" menu and selcting "RUN"...
...then type "CMD" (without quotes) in the window that opens:
Click OK
Note: Should you not see the Run option, you can access the command prompt by clicking Start Button --> Programs --> Accessories --> Command Prompt.
5. In the Command window type"diskpart" and hit enter ENTER
6. Now type "select disk X" and hit ENTER; (X = the drive that is GPT Protected) BE CERTAIN YOU HAVE SELECTED THE CORRECT DISK.
7. Now type "clean" and hit ENTER (this will start the process)
8. type "exit" ENTER (this will exit the window)
9. Your G-DRIVE is now formatted and ready!
Posted on Nov 02, 2012
    Problem Solver:
  • 12 Answers
You dont need to re-format unless it was set for some wierd OS like MAC or linux
But you can use the device manager from within win 7
go to control panel then administrative tools then computer management then disk management and it shgould show up in there and then select it and format it from there
Posted on Aug 07, 2010
HP windows 8 does not recognize simpleteck hard drive
I purchased a SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx for my Vista machine and all was well. Then I purchased a Windows 7 machine. It would not recognize the devise. I contacted SimpleTech only to be told my model cannot be used on machines newer that the Vista. Recently I purchased a Windows 8.1, did a little research, plugged the SimpleTech into the 8.1 and reformatted it using the Windows feature. The SimpleTech is alive and well on my 8.1.
Aug 02, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
My lg external hdd hxd2 works with other computers but not on mine i have reformatted my windows 7 and it does not work ?
I usually face scenarios like yours and this is what i normaly do. Firstly Change the USB ports(in other words try all the usb ports you have on the computer. If it doesnt work try to use a diffrent USB cable. If it doesnt, then open up the hard drive and remove the usb connector and connect it directly to your computer's motherboard as a slave. Here, no doubt you will access it. Even though you have re-installed Windows 7, maybe your computer needs High speed USB Drivers
Dec 19, 2011 | Computers & Internet
How do I delete all info from my SanDisk 2 gb flash drive . I have Toshiba Satellite CD655 laptop running Windows 7
If you are talking about a USB removable thumb drive. The fastest way would be to reformat it. THIS WILL WIPE OUT EVERYTHING ON THE DRIVE.
Insert the drive.
Right click on the drive in Windows Explorer and right click of the USB thumb drive. Select "Format". Format using exFAT (should be default), you can use NTFS to format if you so desire. You can check the current formatting by right clicking the USB drive and look at the properties.
You can also open the drive in Windows Explorer, select a single file/folder. Hold down the "Ctrl" key and press "a". This should select everything on the drive. Then hold down the ""Shift" key and press the "delete" key. THIS WILL ALSO WIPE OUT EVERYTHING ON THE DRIVE. There is no need to reformat after this operation,
For either of these methods,nothing will be put into the recycle bin (Waste Basket). THERE IS NO GOING BACK FROM EITHER OF THESE OPERATIONS, so be careful and take your time.
Sep 11, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Window command to format HDD H551 portable.
If you are connect it with a windows 7 it ask you reformat your hard drive. But if you work in a windows Xp it will work fine and no need to reformat.
Jul 19, 2011 | PQI H551 640GB 2.5" USB 2.0 Portable...
My verbatim model # 47562 is not working on Window 7.It was being used on Mac and was formatted for Mac. How do i reformat it for windows 7
Need to plug it in sys you wish to use,go to my computer choose drive and in propertys choose format option.Good luck!
Jan 09, 2011 | Verbatim (47562) 250 GB USB 2.0 Hard Drive
Will windows 7 suport this hard drive
Yes Windows 7 will support this drive but if it was formatted using either a Mac or an older version of windows it will tell you it needs to format the drive. If it was formatted with an older version of Windows simply dismiss the warning and do not allow it to format the drive. If it was formatted with a Mac, then you will need to reformat it before it will work on a PC but you will want to copy everything off the drive before formatting it as formatting will destroy the files currently saved on the drive.
Hope this helps FixYa,
Chris
Dec 22, 2010 | Iomega eGo Portable Hard drive 500 GB ...
How do i use a cruzer blade usb flash drive 4gb san disk. I put it in my usb port and it seemed to be copying my files- now I can't get it to show on my laptop. I use windows 7 - am totally confused.
mojones309
It sounds like the drive letter that the usb flash drive wants are already reserved by another device. The link below will help you change the drive letter so you will see the usb flash drive in My Computer.
How to change your drive letter in Windows Vista and Windows 7
http://www.fixya.com/support/r4176803-change_drive_letter_in_windows_vista
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 03, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Running Windows 7 Home premium. External drive Verbatim USB 250 Silver is recognized, but, needs to be reformatted. I've tried to format (NTSF) using tool in Disk Management. Format runs forever and...
Hello and thank you for using Fixya's services.
This problem happens quite a bit with Windows Vista. It seems that Windows Vista puts a hidden file in the backup; which locks the device.
Open the external device (Windows 7 is fine). Click on "view hidden folders and files." Delete any hidden files you may have in the external.
Go back to "my computer" and right click on the external hard drive letter. Choose properties and security tab. Make your user-name as a main user (administrator) and disable the read only.
Reboot the computer and see if this works.
Please let me know if you have any questions.
Nov 04, 2009 | Office Equipment & Supplies
I emptied the cruzer 8Gb by deleting the files.
Reformat the drive. Plug it into the Windows computer, and right click on it in the My Computer folder. Select properties, and you can reformat from there.
Oct 29, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
G-Technology G-DRIVE (90801201) 250 GB Hard Drive Logo
1,560 people viewed this question
Top G-Technology Computers & Internet Experts
General Systems...
dbgreenfield
Level 1 Expert
Julie Clark
Julie Clark
Are you a G-Technology Computer and Internet Expert? Answer questions, earn points and help others
