ACER MONITOR AL2216W recieved 4/22/2k8. It worked fine when I recieved it. Yesterday 4/26/2k8 it lost screen color with the exception of a pale yellow.
  • wwwsr Apr 27, 2008
    HELLLLLLP
    Yes it was a cable problem. THANX
    Problem Solver:
  • 7 Answers
Good morning
here are some step that may correct this issue
  1. Do you have another pc to test the monitor on to make sure it is not the video card
  2. check the cable going to the pc and to the monitor and make sure they are tight
  3. check the pins on both sides of the cable and make sure none of them are bent they can cause a problem with colors if they are bent
Posted on Apr 27, 2008
  • Kenneth Pierro Apr 27, 2008
    i need to know did you follow those step
    please let me know this way i can help you
    anytime
    thats what i am here for
My acer al2216w screen flashes black and white every few seconds. power light is on with no flashing
hi. check out put voltage of supply board. if it was correct check inverter and lamps.
Apr 26, 2015 | Acer AL2216W LCD Monitor
Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Jan 30, 2011 | Acer AL2216W LCD Monitor
Wrong background color
Right click anywhere on your desktop.Make sure all programs are closed.Select properties,then select desktop.From here you can change it to anything you like.
Apr 11, 2010 | Acer AL2216W LCD Monitor
My acer monitor was working fine when I turn it off in the evening. in the morning my monitor color had gray mix with black patches and the line have dots and also some areas the dot form crosses with dots...
on your desktop screen, right click mouse, go to properties then settings and change the colour or resolution settings there, apply and save and that should be you sorted. Hope this helps ;)
Mar 18, 2010 | Acer Computers & Internet
Acer AL2216W's green light goes off completely when the computer is turned on. When I turn on the computer and monitor, there is green light on on/off button while an irritating Acer logo is showing up....
You may have failure in the power supply due to bad caps, bad inverter circuits such as shorted transistors, transformers, bad lamps. You need to open it up and make some measurement, see example of failed ACER monitors: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 13, 2010 | Acer AL2216W LCD Monitor
I have a acer AL2216w. it randomly shuts itself off
Replace the following capacitors:
3 pcs. - 220 microFarad - 25v
2 pcs. - 1000 microFarad - 25v
1 pc. - 2200 microFarad - 25v
Resolder the 2 inverter transformer's legs.
Roan
Triangle Tech Whiz
Jun 11, 2009 | Acer AL2216W LCD Monitor
Native resolution suddenly scrolls.
The native resolution for the Acer AL2216W is 1600X1200. It is acting correctly for the resolution you have set it to.
Apr 05, 2009 | Acer AL2216W LCD Monitor
Computers & Internet Logo
David Payne
David Payne
