Question about Home
After installing a new Fluidmaster 400A a few months ago, the refill tube started running constantly - not at 100% like when we flush it but enough that it always sounds like it's running and I would guess it to be approximately 1 gallon every 15 - 20 minutes. Adjusting the float up or down seems to make no difference. We have soft water. Thanks for any help.
  • 43,501 Answers
With the fluidmaster you should have found instructions on how to take it apart and flush it out if dirt gets in the valve...
If not look up the fluid master website, the instructions are there...
You simply have dirt in the needle valve...
heatman101
Posted on Aug 07, 2010
Our toilet systern is constantly running it won't shut down
Faulty flush valve or leaky flapper
Nov 30, 2017 | Home
Have a new 400A and water level is normal in the tank : upon flushing the bowl fills almost to an overflow?
What's wrong with that that's were it should be.with a 2.5 gal tank that water level is corect.Iff think that's too much, adjust the water level adjust clip, by sueezing clip and move it down to adjust the water levelto lower.
Sep 10, 2014 | Fluidmaster 400A Toilet Fill Valve Cap
How to adjust fluidmaster
There should be a small black rubber tubing piece that connects to the fill valve and the other end goes in the overflow tube to refill the bowl after each flush. Make sure this tubing is installed correctly and that should solve the problem. Hope this helps.
Bob
Jul 03, 2014 | Home
300. Why does it occasionally get stuck in the up position or fails to refill tank completely?
It has been my experience that they are reliable. Fluidmaster instructions say to flush the valve (not the toilet) after installation to purge debris. It may be necessary to do this again. Also check for interference with the refill tubing. The float and linkage should be able to move freely.
Oct 10, 2012 | Fluidmaster Fill Valve and Flapper Repair...
We have installed an american standard duel flush toilet that uses a fluidmaster valve. Problem! The refill tube is mounted on a float attached to the overflow pipe. When the toilet is flushed the nozzle...
The overflow pipe should be attached to a small clip that holds it in position over the over flow pipe. If it is loose or attached to the outside it will do what yours is doing.
Apr 28, 2017 | American Standard 2480.516 FloWise Dual...
Installed a fluidmaster dual flush a number of months ago. I was SOOO happy b/c our toilet FINALLY worked properly for the first time!!! Three months ago the toilet began to run continually unless...
sounds like you have a problem with the drain,check to see if the flapper is closing.If by chance you use those disks you put into the tank Id bet the chlorine deformed the rubber and the water is leaking by.
Jan 20, 2011 | Fluidmaster Plumbing
I have fluidmaster in my mancesa toilet. After flushing the toilet tank doesn't refill unless I turn off the water supply and turn it back on. What do I do to fix this problem. Wayne
First thing to do is figure out if the problem is with the fluidmaster or with the shutoff valve. If the water doesn't run at all after flushing, then instead of cycling the shutoff valve, just loosen the nut where the supply tube attaches to the fluidmaster (under the tank). If the problem is in the fluidmaster, it will start to squirt out at you, otherwise it won't. Then you know what to disassemble and attempt to repair, or replace.
Jan 29, 2010 | Fluidmaster Plumbing
My fluidmaster 400 is ghost flushing about every ten minutes.
okay, WTF does this have to do with this router?
Redo your question!
Sep 29, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Home Logo
263 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
