Question about HP VP6121 Multimedia Projector
Hello, the power will not come on on this particular projector. I've checked the power cord, i've unplugged the projector for 15 minutes, and still no response. After one 15 minute break, it DID turn on. I assumed the problem was fixed, so I took it into another room and plugged it in to a 'working' outlet, but would not turn on again. I've been trying ever since to try to get it to work, but no success. Can you help?
  • 89 Answers
The airvent filter cleaning timer is at the max. Reset if after cleaning the filter
Posted on Aug 10, 2010
Lamp timer reset for toshiba tlpx100
To reset the lamp counter:
  1. Turn power off and unplug the power cord
  2. Simultaneously hold down these three buttons: "ON/STANDBY", "RETURN", "DOWN" (the arrow down symbol)
  3. Plug in the power cord while still holding down the buttons.
    The Projector will emit a series of beeps.
  4. Turn on power using "ON/STANDBY" button and check that "0H" appears on the lamp time in the status display.
  5. Turn off projector using "ON/STANDBY" button
  6. Unplug power cord.
I hope this helps.
Sep 25, 2013 | Toshiba TLPX100 Projector
Dell 1800mp projectors turns on for a few seconds then turns off and lamp light stays solid orange...what's the problem. New bulb?
Hello
If the Lamp light and power lights are blinking orange, the lamp driver has failed, and the projector will automatically shut down. Unplug the power cord from AC mains wall socket, wait for three minutes and replug and see whether it helos you. If not, contact Dell service center.
OK.
Nov 19, 2010 | Dell 1800MP Projector
How do you change the bulb?
Hello :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp
Here are the steps that explained in the manual :
Lamp Replacement Procedure:
1. Switch off the power to the projector by pressing the Power/Standby button.
2. Allow the projector to cool down for at least 30 minutes.
3. Disconnect the power cord.
4. Use a screwdriver to remove the screws from the cover.
5. Push up and remove the cover.
6. Remove the 2 screws from the lamp module.
7. Pull out the lamp module.
PLEASE RATE !
Apr 13, 2010 | Optoma EP747 Multimedia Projector
I have a Canon LV-7350 that comes on for 15 secs then turns off.. everything is hooked up correctly. and I have swiched out the bulb to rule that out.. anyone ever seen this?
Hello :
It must be overheating problem . Check the fans . If the fans run properly , then you need to check the fuse or the power PCB [printed circuit board ] . If everything is okay with all of those , then I recommend you to replace the bulb .
Here I'll tell you how to replace it :
  1. Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
  2. In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
  3. Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
  4. Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
  5. Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
Warning:
  • avoid touching the bare projector lamp
please rate !.
Apr 12, 2010 | Canon LV 7350 Multimedia Projector
I press the power on and the lamp led not the
Hello :
Try to change the bulb .
Here is how :
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp.
please rate !
Apr 12, 2010 | ViewSonic PJ458D Multimedia Projector
Model PJ556D will run for a few minutes and then shuts off. Once it cools down it will start back up, but shuts off again a few minutes later.
Hello, Greg.
The most common reasons are the temperature is too high or the ventilation holes are blocked.
Unplug the AC power cord, wait 5 or 10 minutes then turn back on.
There could be dust or the air filter needs to be changed.
Take the lamp cover off the bottom. It's possible that the screws holding the lamp are loose.
Hope this helps.
Apr 05, 2010 | ViewSonic PJ556D DLP Projector
Projector not booting up
The projector may not be receiving power or it may be malfunctioning. Turn the projector off and unplug the power cord. Confirm the power cord is securely connected to the projector and then plug the cord back in to a different outlet and turn on the projector. If this does not solve the problem, and another light is on or flashing, check the projector’s status.
Hope this helps
Apr 01, 2010 | InFocus IN24 Multimedia Projector
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
Jan 11, 2010 | D-Link Computers & Internet
Lamp timer on Sharp XV-Z2000 will not reset
I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the  "0000H" on the bottom left of screen...that's how mine worked today.
Feb 15, 2008 | Sharp XV-Z2000 Multimedia Projector
Problems with keeping the projector on!!
if it is blanking orange:1- if any objects are blocking the air inlet or outlet grille remove them.2- do not expose the air outlet to hot air emitted from heating appliance.3-check whether the filter is clogged with dirt-clean the filter if clogged.
if it is blanking green:-after status indicator stop blanking press power.if you unplug power cord while the fan is rotating the lamp may be not turn on for one minute next time you plug the cord.
press power button several times.
Dec 08, 2007 | Mitsubishi HD4000U Multimedia Projector
HP VP6121 Multimedia Projector Logo
177 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
