FixYa.com
Tags:
Hotpoint 23 in. BFI62 Built-in Dishwasher
Problem selecting programme (by 3 users)
posted by eltel74 on Apr 27, 2008
my bf162 is misbehaving, when pressing the programme select button it now makes a short high pitched beep and doesn't move the light indication, i switch it off at the supply for a bit then turn back on, this resets for a couple of mins and a programme can be selected then it starts but after a min or so stops and the left hand light flashes and is locked out as described earlier, please help soon as the dishes are piling up
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Jun 03, 2008
1st indicator light flashing, tried to reset, no joy. Problem started when kitchen fitter had replace door panel. Possible he had banged it and disturbed wire in control panel?
Manual does not give fault code and directs you to call in a Hotpoint engineer £££££. Would be cheaper to buy a new one if no one can help!!!! PLEASE help as I have to pay the kids to wash-up!!
Comment by uncle_ceps, posted on Jun 02, 2008
Hi.
I have the same problem.
I put it on for an ecowash, however after about 20 seconds there is a beep and the first light starts flashing. The dishwasher makes the normal noise for those twenty seconds but it doesn't kick in with the water.
Any solutions please let me know.
Best Solution
posted on May 18, 2008
Thanks for Trying (70)
hot wash doc
Rank:Guide Guide
Rating: 91%, 5 votes
hi
sounds like you have a heater problem,check connections on your main module behind control panel if all appear ok check you heater for open curcuit.
Rating Locked! (?) eltel74 has rated this solution as Thanks for Trying
Can you Help with these Dishwashers problems?
Hotpoint Dishwasher BF1620...
The first and second green... Answer This...
dishwasher hoitpoint BFI260...
When I start the dishwasher It... Answer This...
Hotpoint BF162 no longer cleans...
My diswasher no longer cleans... Answer This...
BF1620 leaking dishwasher...
Please help if you can. My... Answer This...
dishwasher
my dishwaher keeps triping the... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
