Question about GARDENA Melnor/Gardena 31169 Watering Timer
What do I set frequency? What does 8, 12, and 24 hr mean?
  • 490 Answers
That means how far apart the watering cycles are. For instance, you may choose to have it turn on water for 1 hour (or whatever you like) every 8, 12 , or 24 hours. Hope this helps:)
Posted on Aug 27, 2010
Can't get it to start Record LInk on a JVC HR-S3600U VCR.
Hi my nameis Mike Houston of DISH Network and I see you can't get it start the recordlink on you're JVC HR-S3600u VCR. As faras the DISH Network receiver goes press Menu-7 and then the tab Create Timer. Youwill see Timer Type and select VCR then the timer Frequency type, and then youwill set your VCR to the time of the recording. If you have any questionsplease e-mail me at michael.houston@dishnetwork.com.
Jul 31, 2011 | DISH Network ViP 211 DTV Receiver
I can not find the frequencies for east pasco county fl or any others in my area plez help
I have many years experience repairing Canon scanners so here is my suggestion for you.
Im not quite sure what you mean by frequency's? If you mean the dipswitch settings that is a different matter. You dont mention what model or make of scanner you have. The dipswitch settings are set at a factory default setting so unless you really have to I would leave them as they are. If you could give me a little more information I would be glad to help you out.
Mar 30, 2011 | Office Equipment & Supplies
HOW DO I CHANGE MY WATCH FROM 24 HOUR MODE TO 12 HOUR MODE?
click on mode or setting option.then you will see the default time.edit it..try to change it using select or any mode available.there you can see 24hr clock and 12 hr clock.select which one you want.if it is in 12 hr then the time will be displaying like eg:7:00am or 7:00pm it means that it is in twelve hours.if it is showing 7:00 or 19:00 it means it is in 24hr clock.
Jan 29, 2011 | Casio W71-1V Wrist Watch
Received new DirecTV HR-21-100 PVR, tried to set up device in remote, now nothing works
Your DirecTV device is probably set on RF (Radio Frequency), which the Harmony can't use. You will need to set it to IR (Infrared) for the Logitech remote to control it.
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
May 20, 2010 | Logitech Harmony 670 LCD Remote Control
Crossover to Es 100 to JBL 8400P. I have Harmon kardon 460 reciver?
setting Crossover frequency is trying to find the best frequency where the sub will see below that frequency and the es100 will see above that set frequency for maximum speaker efficiency.
8400P, i believe has a adjustable crossover frequency or cut frequency from 50-150Hz.
The e100 has a rated frequency response of 32Hz to 40kHz. So, the lows going to the sub, will allow the es100 to not have to handle deep bass frequencies.
So, I would suggest starting at 100Hz. That would mean your sub will be seeing roughly 100Hz and down, and the es100 will see roughly 100Hz and up.
Listen to your favorite music, and adjust accordingly.
Apr 05, 2010 | JBL Studio L 8400P Subwoofer
Audio settings for pioneer DEH-P3100UB
The q1w and all that- is a way to fine tune your eq settings: the q means "frequency" the w means wide and the n means narrow. if you choose to boost your lows at 125 hz which is a low midbass the q selection you choose will focus more on the frequencies very close(narow) to that frequency. if you choose a w setting it will spread the boost to frequencies further away(wider) from the center frequency(125hz) Dink around with it and you will notice the way it contours the sound a little. The different numbers associated with the lows mids or highs are the frequencies that you want to boost when you're adjusting your sound-example if you turn up the bass and it starts distorting your speakers = go into settings 2 and change the "lows" Q to a higher frequency(change 80 hz to 125hz) and that way it wont muddy up your sound quite as bad if at all
Jan 15, 2010 | Pioneer DEH-P3100 CD Player
Acer h233h monitor flickers with any cpu usage above about 20%
sounds as though you sre using to hich a resolution frequency...try to set your frequency to 60mhz or possibly 75mhz. Anythinh higher can cause problems.This can be done through "control panel" at the monitor settings.
Jan 04, 2010 | Acer AL1511 15" LCD Monitor
Hp 2009m screen goes black - no signal
change frequency setting to 60hz from the option of graphic setting using another monitor then agin connect your problematic monitor.
step1.open properties on desktop using right mouse click.
step 2.goto last tab (setting)
step3.goto advance optinion
step 4.goto third tab(monitor)
and there is option of frequency change it to 60hz save it and press enter.
now shutdown computer then connect your screen goes monitor check it.hope it works.
when screen black its mean the range of signal frequency higher then compatible frequency.
Aug 01, 2009 | Computers & Internet
Convert 400m3/hr N to kg/shr
I think you mean kgs/hr and are you sure you don't mean cm3 instead of m3 (that's a lot of gas)...if so, there are .028 kg of nitrogen/ 1000cm3
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 12, 2009 | Welding Tools
GARDENA Melnor/Gardena 31169 Watering Timer Logo
Top GARDENA Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Bill Boyd
Are you a GARDENA Hardware and Accessory Expert? Answer questions, earn points and help others
