Question about Craftsman Garden
I just bought a used Craftsman 3.8 Briggs and Stratton Edger. It works great but leaks gas after I quit using it. It seems to come from underneath a round aluminum bowl. How would I look to fix this?
Probably missing seal to the carby bowl, undo the round bowl (watch out for petrol/drain tank first ) then check to make sure the bowel has a rubber seal . if not auto shop should be able tio locate one if you take the bowl in tp size it . or you can use a gasket sealer thats petrol proof
Posted on Aug 07, 2010
  • mick
    mick Aug 07, 2010
    if its under warranty tho take it back to the place you bought it and explain the problem
Craftsman tiller, 850 series, model 917.297032, Briggs and Stratton engine, will start but not run. If it does start, it's a rough idle, and it kills as soon as I move it off of choke. I have cleaned...
It could be the gas you are running in it, if it contains ethenol use some stabil in this type of gas. Ethenol attracts moisture and will cause the carbs. on small engines to gum up and get a fouled. I run 100% gas in everything. It may cost a little extra now but it will save you alot more in the long run!
Feb 26, 2011 | Craftsman Gas Mini - Tiller/Edger
My 675 will fire up a start and will immediatly quit. i have cleaned the spark plug and put in new gas.
it's still getting bad gas. take off air filter, prime with fresh gas, use an old spray can, and keep spraying while running until all old gas is used up in the carb
Jun 26, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Gas leak
sounds like the float needle valve is stuck open or it got lost as you were putting it back together. take onother look at it.
Dec 23, 2009 | Briggs & Stratton Briggs Stratton Intek V...
I craftsman 20 hp twin mower quits after waarm up
SOUNDS LIKE A FUEL PROBLEM OR DIRT WHAT OTHER SYMPTONS DOES IT HAVE
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman Edger 536-797520 is leaking gas from the air filter
The needle valve is sticking open. The carb needs cleaning and diaphragm replaced. Probably best taken to a shop unless you have experience with diaphragm carburetors. Dwain
May 27, 2009 | Craftsman Gas Mini - Tiller/Edger
Garden Logo
83 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
