Question about U-Line Echelon Clear Combo® CLRCO2175 Beverage Cooler
My uline echelon 2175RF shows the temp then flashes ER. What is the problem.
3 Suggested Answers
  • 286 Answers
SOURCE: uline under the counter two drawer refrig seems to
Hi
Er means that somthing is wrong. It could be a temperature problem that caused it. Does it beep at all. That is a alarm for the door being open. You may need to check the magnet on the door and the reed switch on the wall. Upper left for the top drawer. and on the bottom is on the grill and door. Normally this is something I would ask for a tech to look at. But if you feel confident to try this I can get you into the program to see what its telling us. Now hold the up arrow and at the same time press and release the light bulb 3 times. Then release the up arrow last. If you did this right then you will have a 0 on the display. Yes, Then up arrow until you get to 3. Then press and release, It should give you a number. E# ? Let me know what this is. You may have a couple so write down all of them.
Now after you got the number then just push up arrow until you get to 99 then press and release the light bulb to go back to the refrigeration cycle.
E3= bottom drawer open to long
E10= Top drawer open
E1 = Thermistor #1 open
E5 = 10 degrees to warm E6 = 10 degrees too cold E7= Thermistor 2 E8=Thermistor 3 E9 =Thermistor 4 open thermistor 1 located top drawer Thermistor#2 I/M or evap if no icemaker
Thermistor3 is located in freezer or base if no freezer thermistor 4 is drain pan
Hope this helps
Posted on Jul 24, 2009
  • 286 Answers
SOURCE: ULine 2175RF Digital Touch Controller not responding.
Hi
You will need to remove the grill. Unplug the unit, Then on the control board you will see 4 wire with a black connector. Unplug that and plug it in 4 or 5 times. Make sure you dont bend the pins. Then plug the connector back in and plug unit back in. You should have better response on the display. They have a special coating and the pins needs to be cleaned this way.
Posted on May 14, 2009
ULINE wine cooler 3018WCSA... Freezing occurs at the bottom of the unit.
Yes, the thermostat is full open. It needs replacing.
Apr 12, 2018 | Refrigerators
I have a CLRO2175S-00 it was installed in 2007 it show Er when turned on and we can't get it to do anything. where can I find a manual?
Have you tried googling the error for your specific model?
Another post was resolved with a freezer fan replacement. They can stop turning from dry bearings which can be remedied with cleaning the bearing and motor shaft and a bit of oil if it is hard to turn. If that helps then plan on buying a replacement fan in the future. If it's not the same issue, then the usual list of culprits should be checked from temp sensors, fans, defroster, ice maker and so on. If all that seems ok, then it could boil down to a faulty control module.
Give me an old non-computerized refrigerator any day, they fail less often. My Whirlpool is 24 years old and still purring, only had to change water control valves for sticking closed, which is expected on any refrigerator.
Oct 16, 2014 | U-Line 2175RCS00 2175RCS-00 5.2 Cu. Ft....
What does 34F ER mean
Put a freezer thermometer in the freezer and see if it reads +34 degrees, then put it in the refrigerator. If the freezer reading is above 0 degrees, say +34, then the freezer is too warm. If the refrigerator is reading 34 and the freezer is way cold, then the refrigerator is getting too cold. This could be either a thermostat setting too cold or the sensing isn't reading properly or a much more serious issue. Generally a refrigerator should be no warmer than +40 but not freezing either +32 degrees and a freezer should be about 0 degrees. Make sure nothing is blocking the air flow duct work or where the sensors are located.
Aug 14, 2014 | U-Line Echelon Combo® CO2175DWR Compact...
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Jun 22, 2011 | U-Line ULine CLR2160S00 Echelon Series 15"...
The panel control going shows Er in temp display
ER in temp means error code next 2 letters are first letter of part giving problem or where problem located.. if " ER DH" means def heater not coming on, does not mean heater bad but def control bad not letting voltage to heater. could need main bd also
Aug 21, 2009 | LG LRSC-26922 Side by Side Refrigerator
My Uline ? Model U-217RS-O is 14 months old. The problem I have is the temp will not go below 38. What can I do?
Ok On the display hold the up arrow for 5 seconds then let go. It will tell you the temperature. Do you have and er at the display? Is the unit outside? What is the temperature(ambient) around the unit? If you hold the up and down arrows together for 5 seconds then release it will show you thermistor temperature for 2,3, and 4 You should only get 2 to give a temperature. 1=refrigerator temp and 2=evaporator temp.
Make sure the condenser is clean from dust.
Jun 28, 2009 | U-Line ?chelon 2175RB-00
Hi
Jan 18, 2009 | U-Line Refrigerator Ice Maker
U-Line Echelon Clear Combo® CLRCO2175 Beverage Cooler Logo
1,080 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
