Question about HP DVD1040i 20x Super Multiformat Dvd Writer, Internal Burner
Drive tray refuses to open when empty (it may take 20 or more pushes on the button)- if a disk is left in it (right side up or down), it operates good and opens every time. I tried removing the driver and e-installing it, updating the driver, disconnecting and reconnecting wires, plugs etc. Tried to find firmware update (non existent I think). This is the second drive to do this. Thanks in advance Bob Kennedy
    Sergeant:
  • 271 Answers
This is the computer, the the drive.
Try putting your computer on it's side.
Posted on Aug 07, 2010
How to eject dvd disk samsung laptop no eject button?
There are two ways toopen the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
Apr 01, 2012 | Samsung NC10-14G Notebook
My husband always operated the DVD player. He has died and now I'm at a loss what to do. I rented a DVD at the video store. I tried to put it into the tray on the DVD player. I had to pull the tray...
Hi, Very sorry for your loss. As always the first step is to make sure the player is connected to the wall outlet and turned on. To put a disk in the DVD you should push the "Eject" button to open and close the tray it looks like a home(a triangle over a dash) on the front side of the box down left corner of the tray. You have the same button on the remote marked "Eject". Push either once, put the disk with the shiny side down on the tray and push the Eject button again to feed the tray back into the player. Usually the disk starts automatically and you will see a menu on the TV with alternatives like "Play the movie", "Setup", "Scenes",... you may highlight the "Play the movie" alternative, using "Up", "Down", "Left" and "Right" and then press the "OK" button. Or just push the "Play" button either on the box or the remote control. If you click "Here "you can download the manual in PDF form. To open it in your pc you'll need "Adobe Acrobat Reader" (or any other PDF reader) installed.
I will gladly answer your questions Best Regards Bruce
Aug 23, 2010 | Amphion Mediaworks S99 DVD Player
Tray won't open
Hi
You'll need to press the manual eject button on your DVD drive. Locate a small hole located underneath the DVD drawer. Use a safety pin or a paper clip & insert it into the hole. Push the pin gently in the hole and it will open partially. Pull the tray and check for any obstructions in the tray's path.
Daniel Scott
Jun 07, 2010 | BenQ (1650V0C4) Internal DVD Drive
Dvd tray will not open
under teh machine there is an opening near the tray. Look inside adn you will see a small white tab. Use a small tool to reach in their and push it to the other side. That will open the tray.
Sep 08, 2009 | Philips DVDR985 DVD Recorder
I bumped into my dell computer disk tray while it was open, and popped it out. When I try to put it back in, it seems to lock into place, but when I push the button to close the disk tray, it only goes in...
It sounds like you have the drive gears on the tray out of sync with the tray. Pull the tray out all the way again if you can. On the left hand side of the drive is a large gear that engages the side of the tray, turn this gear counter clockwise (the same way it turns as the tray ejects). You should be able to see a plastic slide with a rack gear on it (teeth in a straight line). Slide this part all the way to the right. Now try inserting the tray back in. Good luck.
Aug 21, 2009 | Dell Inspiron 530s Desktop Computer...
Philips dvdr 3480 disc draw refuses to open
Illustration:
This usually happens when you close the drawer with no disc in it. There is a strong magnet inside the DVD-drive that keeps the spinning disc in the correct position. But when the drive is empty, the magnet is connected to tough to its counterpart (no disc in between) and the worn out motor and/or transmission (belt) is not able to pull them apart in order to open the disc tray.
How to fix - "brute-force-attack":
Press OPEN and give the disc draw a couple of decent slaps (or snap at the tray cover with your forefinger) until it opens. Repeat procedure, if motor stops before drawer is open.
How to fix - "high-tech-approach":
Disconnect power chord. Locate the slot provided at the bottom of the device, near the smaller, left clip holding the front panel. Insert a screwdriver into it at the far right (when viewing from the front), so you can push a small white plastic-lever-thingy (can be seen thru the slot) to the far left. Now the tray is partly opened and can be pulled out completely.
Future outlook:
Don't you never ever close your old machine with no disc in the tray - or just start over again...
Jul 26, 2009 | Philips Televison & Video
My Acer Extensa 5620Z DVD-ROM Driver wont open or operate
#1
first go to your system tray and click on the "Safely Remove Hardware" icon
** if it's not there you can skip this step
click on the icon and stop your dvd/cd drive
#2
There is an eject button on the side of your drive. not the disk eject button. this button will eject your drive from the computer. it should be on the right side of the drive. push this button and remove your drive.
#3
Inspect the drive for signs of damage.
Give it a few blows of air to knock any dust off it
#4
Reinsert the drive into your computer
After you do that Windows should recognize there is a drive there and little bubbles should pop up from your system tray. give it a minute to finish.
#5
Insert a disk and check to see if it is working properly
IF windows didnt recognize it and/or it still has no power, you most likely will have to replace your drive. but let me know what happened after you do this
Dec 26, 2008 | Acer Aspire 5100 Notebook
Xbox 360 tray won't open
if u can't get it to open unplug ur power take ur faceplate off and get a paper clip there are two very small holes right under the silver tray there is a button u can poke which will pop ur tray out. i know this doesn't fix ur problem but if u can't get a game out it helps
Jan 20, 2008 | Microsoft Xbox 360 Console
CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Sep 19, 2006 | Sony MHC-RX70 Shelf System
HP DVD1040i 20x Super Multiformat Dvd Writer, Internal Burner Logo
144 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
