Question about Frigidaire FRT8B5E Top Freezer Refrigerator
What are the specifications for a PLHS269ZCB2 refrigerator compresor
How cold should my freezer get on my plhs269zcb2 side by side?
Good Morning Friend,
I understand you want to know how cold the freezer should get on your Frigidaire refrigerator, model# PLHS269ZCB2. The freezer compartment should be kept at 0 degrees Fahrenheit or lower. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire Refrigerators
Why does the freezer only get to 26 degrees on my plhs269zcb2 side by side?
have you try to lower the temp with the selector switch or you may simply need to clean the condensing coil and area for proper ventilation
Maytag mbf254h compresor will not shut off
You need to replace the compresor relay, this is the problem
May 15, 2010 | Maytag MBF2254H Bottom Freezer...
You need to replace the compresor relay this is the one that is stuck.
Mar 28, 2010 | Maytag MBF2254H Bottom Freezer...
Refrigerator tries to come on but doesnt
Probably you heard a click on and off when the compresor is trying to start , that could be the relay or the compresor went bad .Try replacing the relay (no more than $30) If the compresor doesn't start is either burned or stuck and has to be replaced.
Aug 19, 2009 | Kenmore Refrigerators
Compressor doesn't run
If the fan located next to the compresor works that means that the compresor relay is bad or the compresor burned out.
Jul 18, 2009 | Frigidaire FRS23R4A Side by Side...
Compressor not kicking in. sounds like it is trying to. everything else is working fine. not getting cold.
Its sound like the compresor is off on overload ,eithe you have a bad relay(located on the side of the compresor under a black plastic cover ,cost about $20 or is a bad compresor wich cost alot more.I will try the relay first.
Apr 19, 2009 | Amana SXD524VW Side by Side Refrigerator
No cooling,compressor comes on and shuts off quickly
All refrigerators compresors have a relay and a overload thermal protector ,both are located on the side of the compresor behind a black plastic cover atached to the compresor with a metal clip(or just the cover snaps in on the compresor).Unplugged the fridge ,pullout the cover and you'll see the relay and the overload replaced them (no more than $30).If this doesn't solve the problem you have a bad compresor, wich is a much more expensive job.
Apr 19, 2009 | Frigidaire FRS-26DR7D Side by Side...
Refrigerator continuously cycles
This is a generic problem with Whirpool refrigerators.The start relay for the compresor(located on the side of the compresor under the black plastic cover) is probably bad ,replace it(about $ 20) with a new one(write down where the wires go) that should solve the problem if not the compresor is bad.
Apr 15, 2009 | Whirlpool Refrigerators
Turns on...clicks every few minutes....never gets cold
It looks like the compresor is trying to start and goes off on overload ,it could be a bad relay or a bad compresor.Try first replacing the relay located on the side of the compresor under a black plastic cover(ALWAYS UNPLUGGED THE FRIDGE BEFORE DO ANY WORK) if that does not work you need to replace the compresor.
Apr 09, 2009 | Danby DAR482BLS Compact Refrigerator
Frigidaire FRT8B5E Top Freezer Refrigerator Logo
66 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
