Question about Avanti Dishwashers
Possibly stuck in a cycle od humming but nothing is happening.
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 19, 2012 | GE Washing Machines
GE Potscrubber Dishwasher Stuck on Cycles
Could be a defective cycle timer
Jan 30, 2018 | GE Dishwashers
My front loader has stopped in the middle of the cycle.
you need to clean your pump something is stuck not allowing the pump to drain
Dec 25, 2008 | Washing Machines
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire dishwasher does not clean
the start switch in the motor is probably bad,it could also be the motor relay.if you can get to the motor run the unit and while it hums try to turn the motor.it also could be something is stuck in the motor let me know.
Aug 13, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Stalled Motor
quite possibly the drain pump which would cause it to stick in rinse cycle. the humming noise you heard is probably the drain pump powered up but jammed. likely cause is a foreign object stuck in the pump impellor - main culprit is bits of bra wire. take the pump to pieces and extract whatever is jamming it.
May 12, 2007 | Kenmore 24852 Top Load Washer
Dishwashers Logo
24 people viewed this question
Top Avanti Dishwashers Experts
David Ellis Rhea
Robert Plante
Are you an Avanti Dishwasher Expert? Answer questions, earn points and help others
