Question about Mtd Garden
I have a Tecumseh tvs115 engine on my mower. It is getting fuel and a small spark but it will not start. The mower has sat very many years.
  • 7 Answers
SOURCE: I have a Centura 3.5 Tecumseh lawn mower. It sat
If the oil level is too high smell the oil to see if it has gas in it. If it does the carb needs to be cleaned and the oil changed.
Posted on Jul 18, 2009
  • 133 Answers
SOURCE: engine will not start, no spark
Try taking of the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs that are really close to the fly wheel. Use fine sand paper or emery cloth. Then check the spark plug wire for rust (clean if any). Try replacing the spark plug if it is old.
Let me know if this helps.
roundo4
Posted on Aug 22, 2009
  • 62 Answers
SOURCE: engine starts dies down immediately.fuel is ok spark plug ok
Most likely the carburetor is not ok. An engine does not just DIE. If you press the prime bulb, does fuel squirt in carb. If it starts the runs for about 3-5 seconds then dies, there is most likely a float or needle shut off problem. Or it could be as simple as a clogged carburetor. It only takes one tiny peice to clog one. Take the carb off and make sure all jets( small holes in carb) are clean. Mike. Rate 100% please.
Posted on Sep 19, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a Sears Craftsman mower with Tecumseh, major oil leak
On many Tecumseh engines, there is a crankcase breather located under the flywheel. It has a cork gasket to seal the top plate of the breather. Either the rubber breather housing is cracked, or the cork gasket needs replaced.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My 2 year old Yard Machine 21in 139cc MTD engine
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on Jun 03, 2010
How can i get engine started
Make sure the spark plug is connected
Use only highest octane gas
throw out /drain any old gas from last year
check and add oil
change the spark plug
clean the air filter or replace it
check that fuel injection lines and port holes are not plugged
if that does not work go to dump and get a new one cheap from discarded mowers that had a cheap broken deck.
Aug 16, 2014 | Tools & Hardware - Others
6.5 toro self propel.....new plug and new gas,,,turns over but then shuts down...replaced both neoprene hoses
Carburetor Cleaning TUNE UP of Toro 6 5HP Lawnmower with Tecumseh Engine
The above link will provide a video on how to clean the carb on the 6.5 hp mower. Before you go to that length, try putting some carb cleaner in the fuel tank and see if that corrects the problem. Also, as the video shows, make sure the spark plug is getting a good spark. If the spark is weak , the fly wheel may be rusted, ot the magneto is bad.
May 09, 2014 | Garden
Tecumseh 13hp overhead valve snowblower engine starts fine than sputters and dies, replaced the carb with new and exact same symptoms, Lots of fuel at the carb.
Make sure the fuel is good. Ethanol laced fuel starts to varnish after 20 days and is no good by 30 days, it also attracts water. Be sure you have good fresh fuel, then try a new spark plug.
Oct 19, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
5.0hp tecumseh power sport wont start
you have to take the bowl off the carb and see if the Jets are clogged.
How long did it run before you shut it off?
Oct 04, 2012 | Garden
Tecumseh 13.0 horspower overhead valve engine will not start
do you have spark?do you have fuel getting to the engine?is it cranking over?
May 19, 2012 | Tecumseh Garden
Wont start, have cleaned the carb, new filter, new spark plug. removed plug and grounded. Very tiny little sparks, not real single snapping spark. Any idea of what could be the problem? Ariens model...
I believe you have a timing problem. Do you remember hitting something hard with your blade? I would say you have sheared your timing key. Order of repair : remove top cover to engine, this may involve gas tank, gas line, oil filler tube. Remove flywheel nut, remove flywheel. Timing key is the small key between flywheel and crankshaft. Timing key may just be dented but it will need to be replaced. Bring it with you, Tecumseh has a few different styles of key depending on engine and year.
GOOD LUCK.
Jun 12, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
I have a lawn boy 10335 push mower that sat unused for several years. I added new gas and went to start it up it spring a gushing leak out of the carburator. There is a small red hose that the gas was...
The needle and seat are bad in the carburetor. You need a tecumseh part 631021barterjoe_2.jpg and it might be recommended to get a service manual. They are inexpensive at a shop like www.arcolawn.com
good luck
Joe
Feb 13, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn Mower will not stay running then will not restart
I think we all understand the frustation penaone.
I noticed u didn't clean the fuel tank, water, dirt, and rust in it can give u problems. But u need to clean the lines and carb. again also. One of the kids filled my mower gas tank with driveway gravel once, and after I cleaned things out, the mower never run so good. Also your spark may be grounding out somewhere before it gets to the spark plug. Check for a bad spot in the wires from the magneto. Some of that may be behind the flywheel though.
ballping
Jul 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
SMALL ENGINE PROBLEM
Carb will need to removed and thouroughly cleaned.
Also you can file or clean coil where the contacts rub on flywheel.
Change your spark plug as well.
May 13, 2009 | Garden
Garden Logo
148 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
