Question about Kenmore Slider/Casement Air Conditioner
I have a Kenmore Air Conditioner Model No. 253.71123010 .The water lays inside the back of the unit under the fan blades and the blades tend to fling the water around inside the unit. Should there be a drain hole on the bottom of the unit to allow the water to drain away?
    Problem Solver:
  • 5 Answers
Make sure the filter and coil behind the filter are not dirty (I am sure you did that already) as this would cause icing and excess water build up. There may be a steel or plastic plug in the bottom rear of the unit. If not, I have drilled a hole in the very rear right or left side of some to help drain the water, but you need to be sure that nothing, nothing at all is on the otherside where you drill (No wires, no tubing, no compressor, etc,) as you will damage the unit. If it is a newer unit under warranty call the manufacturer as newer units disipate the water in the exhaust air and it may be malfunctioning or it may just be extremely humid ouside and the unit is struggling to disipate the water.
Posted on Aug 07, 2010
My frigidaire air conditioner is making my apartment feel damp and when i took my filter out to clean it that part was damp too! What do I do to fix this?
You may have a clogged drain or the unit is installed without enough angle pitch for the water to drain to the back of the unit toward the outdoor section of the unit. I'm assuming it's a window air conditioner? The moisture condenses on the cooling coil near the filter and should drip down into a condensate drain pan, then the water should drain to the back of the unit into a pan at the condenser coil fan that is rejecting the heat outside. The fan blade usually has a ring on the outdoor fan that pick up the condensate moisture the fling accumulated water onto the hot condenser coil to evaporate it. Also the filter should not be touching the cooling coil. Make sure it in the correct slot. Some a/c cooling coil require a wetting agent that allow the water to slide down the coil and not pull off of the coil into the indoor circulating fan.
Sep 11, 2015 | Frigidaire Heating & Cooling
How do I drain the water from my LG portable air conditioner (LP1010SNR)
Lift up the window securing the AC, and CAREFULLY tilt back the unit. The water lays towards the back of the A/C under the fan.
Apr 17, 2012 | LG Heating & Cooling
Brand new kenmore air conditioner 18500 btu, there is no place for the water to drain, no drain plug? water is getting high... model 70181
The new Room A/C's do not have drains as it uses the condisation from the pan to help cool the coils this makes the unit more effecient.
Sep 01, 2011 | Kenmore Room Air Conditioner
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
We have an in wall air conditioner. I am not sure of the model #, but recently it has started spraying a fine mist back into the room. I removed the front of the unit this morning and found that the foam...
You could have a pin hole in your refrigeration line. The mist is probably the refrigerant coming out. Check the coil very carefully to see signs af any breaks. You may also have a bad drainage and the water is accumilating inside the unit. The fan blades can throw the water against the filter. Look inside for standing water. Good luck!
Aug 04, 2011 | Fedders A3X05F2A Air Conditioner
I have a sharp window AC unit, model af-609x. does it have a drain hole? there is no water coming out of it, but when we take it out of the window we get soaked from water somewhere inside the unitl
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
Jul 22, 2011 | Sharp AF-M609X Air Conditioner
Our unit is making loud clicking noise and spraying water when in the cooling air condition mode, but not when the fan is on. What could be the problem, and is it fixable?
you may hear water splashing that is because it is coming off of the condenser the part that is outside the water runs off the condenser and is forced out by the fan for as the noise could be something in or on the inside fan blade or outside fan blade as long as the water is not coming inside your house and you have enough slope on the unit you should be ok
Jul 04, 2011 | LG Electronic Window Air Conditioner
All of a sudden the airconditioner started filling up with water and the fan blades started spraying water out of where the air comes out. The unit is draining from the back.
Try cleaning out from under The evaporator (front) coils towards the back so the water can drain underneath the front coils towards the back
Make sure the unit is tilted a little towards the back
Clean drain hole in back too.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 23, 2010 | Kenmore 75050 Wall/Window Air Conditioner
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Heating & Cooling Logo
271 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
