Question about Cub Cadet Garden
Have a zforce 44 with Kohler command 20 engine. Engine won"t turn. Ran a jumper to starter post< starter spins but doesn"t engage. Bought new starter and Solenoid, does same thing. any suggestions?
  • 100 Answers
How much voltage does battery have? should show 13.2 to 13.6 volts....
Posted on Aug 14, 2010
Kawasaki starter not engaging
Hi, Ricky the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starter spins but engine does not crank
Starter spins but doesn start the bike Ex 500 com The home of the Kawasaki...
Starter spins but doesn turn the engine
Mar 22, 2017 | kawasaki Motorcycles
The starter motor will not engage
Hi, Paul the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day. Starter spins but doesn turn the engine
Starter spins but won catch
http://www.apriliaforum.com/forums/showthread.php?189764-starter-spins-but-doesnt-engage
Inside look of starter spinning but not engaging
May 15, 2016 | Motorcycles
The starter on the 12res Kohler generator just hums (spinning sound). It doesn't engage the flywheel. Do I need a new starter?
OC is over crank failed to start. It will normally try 3 times before giving this error. You need to disconnect the battery and remove the starter motor, make sure it is free to move / spin. Either the starter has seized or the engine has siezed. Make sure the engine is free to rotate also, once you remove the starter you will see the engine flywheel there, removing the spark plugs will make it easier to rotate the engine. I would guess it is more the starter.
Jan 06, 2014 | Kohler 12 kW Emergency Power System -...
Kohler CH640-3075 (one year old and in a Grasshopper 720K) will not turn over. Battery charged.
check fuses first. then check starter solenoid for proper power and then this will lead you to either a safety switch issue or a power issue...
turn key on, pull pto switch... does pto engage, then your problem is at or after the key switch
Oct 08, 2013 | Kohler Engines New 20 HP Kohler Engine...
I have a 1999 Gilera Runner 180FXR, New bat 12V 9 amps. Starter turns and spins pinion gear but won't engage starter ring. If it does it turns ver slow or won't turn engine over. In manual it
Yep, not enough amps to engage the starter clutch, and when ti does engage, not enough amps to turn the engine. You need a 12 amp battery.
Nov 17, 2012 | Motorcycles
Starter won't engage on 17.5 koehler command
Try replacing the solenoid. If that doesn't do it, replace the starter.
May 05, 2012 | John Deere Garden
Engine wont turn over on my gv 2006
The 1st thing i need to do is clarify what you mean by "won't trun over" do you mean the starter motor spins the engine and it will not fire up or that the starter doesn't trun the engine over? If the starter doesn't turn the engine over do you hear a clicking coming from the starter solenoid when this happens? If so replace the starter solenoid the heavy electrical contacts are burned.
Dec 28, 2011 | 2006 Suzuki Grand Vitara
Kohler 20 in zero turn mower will not restart after operating for 20 minutes. When restarting there is only a clicking sound. PTO is off and brake is engaged. After sitting 20 minutes it starts. Engine has...
AS SOON AS IT DOES THIS, TAKE A HEAVY DUTY JUMPER WIRE AND JUMP ACROSS THE TWO LARGE POSTS ON THE SOLENOID, IF IT CRANKS, REPLACE THE SOLENOID IF IT DOESN'T THEN CHECK YOUR BATTERY TO SEE IF IT HAS 12 VOLTS OR MORE. IF IT DOES YOU NEED A NEW STARTER AND IF IT ONLY HAS 50 HOURS ON IT YOU SHOULD BE ABLE TO GET WARRANTY UNLESS THE WARRANTY TIME IS UP
Oct 01, 2009 | Garden
Kohler command cv15s starter sping in the opposite direction???
It's more likely you hooked the battery up backwards. That reverses the polarity and will make the starter spin backwards.
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler Command 12.5 OHV (starter?)
You should properly test the battery. A dead cell in a battery will absorb the current that you are trying to supply by jumping.
There may be a fault in the wiring system, thus not allowing enough current to properly supply the starter. Construct a way to temp. connect the positive jumper cable lead to the tractors battery cable connection on the starter that will not short circuit and connect the other poss. end to your trucks poss.battery terminal and then connect the ground lead as normal but to the tractors frame, then attempt to start. If this allows the starter to operate properly then disconnect your jumpers and Inspect the positive and ground wires for insulation cracks, blisters and corrosion. Also check the connections for being clean and tight.
You could also remove the spark plugs ( to release compression that will allow the engine spin free) to see if the starter will then turn the engine.
If all fails, sorry to say, your starter may be weak and in need of replacement.
Good luck
Aduz
Mar 25, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Garden Logo
334 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
