Question about 1002 Car Alarm Security System
My viper alarm system is not working. my car does not want to unlock. I had even put a new battery on my key alarm system so it cant be that
5 Suggested Answers
SOURCE: 2003 chevy trailblazer. alarm problem 771xv
CHECK THAT YOUR BYPASS POWER IS ONNECTED TO THE ACC.CABLE FOR IT WILL NOT DRAIN YOUR BATTERY
Posted on Jan 22, 2009
  • 87 Answers
SOURCE: my viper alarm remote just beeps flashes TX and
Try to reprogram this. If this routine does not work please let me know and we will try something else
Posted on Jun 03, 2009
  • 24 Answers
SOURCE: Replaced the battery in my car need to reset my viper alarm
Alarms are not supposed to shut down the engine while you are driving if it was installed properly. Could be another installed accessory or the car itself has a problem. If it was in anti-hijack mode, you would receive a warning like honking horn. You may have to visit a repair shop and maybe your local Viper dealer to have them take a look. DC
Posted on Nov 04, 2009
  • 171 Answers
SOURCE: disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Posted on Jan 08, 2010
How do I turn off the alarm?
Try pressing the unlock button twice quickly.
Aug 21, 2017 | Viper Vehicle Parts & Accessories
The viper 350 system locks and unlock no chirping sound and the car does not start
when this happens it is because it has a valet function. this function is used to turn off the alarm but the lock and unlock will still work. to reactivate the alarm open the door, turn the key on, then off and then press valet switch once and this will reset the alarm.
May 29, 2014 | Viper Vehicle Parts & Accessories
I have a Viper 5301. Just recently the blue light on the valet stopped blinking when the car is locked with the remote. It just stays on all of the time, no blink. At the same time, the remote started...
The blue light on solid means that your alarm is in the valet mode. Open any door, press lock, unlock, lock. This should put the alarm back into an active mode. Afterwards, check the system for normal operation.
Apr 14, 2011 | 5301 LE 2 Way Car Remote Starter System
Viper Responder 350 2 Way
Well, the problem is that the remotes don't just lose programming from a simple battery swap. Either the original installer ran a separate power source to the battery for the unit and the repair shop just didn't hook it up or when they installed the new battery or if your car was jumped to get it started it may have blown the fuse for the security system. So bring it back to the installer or put the car in valet mode.
Apr 01, 2010 | Viper Security and Remote Start System...
Disable viper alarm
Jan 07, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Oct 23, 2009 | Viper Vehicle Parts & Accessories
Problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
Dec 28, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 791 XV Automatic Start Not Working
Try putting the key in the key cylinder but do not turn it at all. Then try and remote start the car. If it works then your bypass module is bad and needs to get replaced.
Nov 17, 2008 | Viper Security and Remote Start System...
1002 Car Alarm Security System Logo
185 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
