Question about Transcend 8GB SSD, 2.5- Inch, IDE, SLC Hard Drive
I cant copy large file int my jf v30/8gig - Transcend 8GB SSD, 2.5- Inch, IDE, SLC Hard Drive
    Champion:
  • 219 Answers
Make sure the file is not larger than the stick will hold.
Posted on Aug 07, 2010
Hello, i have a Transcend JF V30.. that after when i copy a file folder with a capacity of 4.80GB to the flash drive, and when i open the files in it, some files aren't copied. But still its 4.85G
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps
Jul 05, 2012 | Transcend Electronics - Others
Tip
REMOVE CAMERA SHUTTER SOUNDWorking on: N73ME, 5700, 6120C, N95-1, N81 8GB, N78...
1. Turn on "Caps Off"
2. Open X-plore
3. Goto "Z:\Private\10202be9\101F8809.txt"
4. Copy the file to "C:\Private\10202be9\101F8809.txt"
5. Edit the file "101F8809.txt"
6. At the end of the file, u will find the line
Code:
0x7 int 10 cap_rd=alwayspass
cap_wr=alwaysfail
7. Change it to
Code:
0x7 int 00 cap_rd=alwayspass
cap_wr=alwaysfail
8. Save the file and exit X-plore
9. Turn on "Caps On"
10. Turn off "Warning tones" in ur profile
11. Restart the phone.
No more sounds in camera
on May 09, 2010 | Cell Phones
I cant copy a big file (example: ISO file size 7gb) into my transcend external hard disk 500gb. a pop out message will appeared (File too big to transfer) help me please. Thanks
Please check how many Mb free disk space you currently have on your transcend device as the description of the pop up message sounds like the default error message from the operating system stating that the file you're trying to transfer is too large to fit on the destination drive. Perhaps try copying and pasting a smaller file first just to make sure that there's nothing wrong with the drive before attempting to transfer such a large file.
Apr 12, 2011 | Computers & Internet
Cant' play the game : Rap[ala Pro Fishing (Activision)
A. There is a known fix to the problem that you have experienced and if you follow the instructions below, you will be able to resolve it. What you're going to need to do is find the file called 'Console.cfg'. This is located in your game's install folder (My Computer -> C:\Program Files\ActivisionValue\MagicWand\Rapala\Rapala\Cfg) inside the \Cfg folder. It might be easiest to just do a search from the start menu for 'Console.cfg'. Once you find that file, open it up with notepad or wordpad. You will see a series of lines, the 5th line says: "addvar r_windowed int; r_windowed = 0". You're going to want to change that to: "addvar r_windowed int; r_windowed = 1". Towards the bottom of the file (scroll down) you'll see two lines: "addvar rWaterReflect int; rWaterReflect = 1" and "addvar rWaterRefract int; rWaterRefract = 1" . You're going to want to change those to: "addvar rWaterReflect int; rWaterReflect = 0" and "addvar rWaterRefract int; rWaterRefract = 0". Make sure you save the file and that it asks you to replace it when you save. Then you can start the game. It will not take up the whole screen, but you can fix that by going into the options menu from the main menu and increasing the resolution.
Apr 08, 2009 | Activision Rapala Pro Fishing for Windows
Cann't transfer data through pen drive and cann't copy data
can not copy to pen drive& vice versa.And then can not Format.when Formating,it shown "this volume is write protected".what can I do...help me ..my cell no..9025274371...
Feb 16, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Download copy JFSW.exe for JetFlash elite
Driver Installation – Windows® Me, 2000, XP and Vista
No drivers are required. Newer Windows operating systems have built-in drivers that support the JetFlash®. Simply plug your JetFlash® into an available USB port and Windows will automatically install the files needed to use your device. A “Removable Disk” with a newly assigned drive letter will appear in the My Computer window.
JFSW.exe is the older version. You might want to try JetFlash Elite v2.0, a newer more advanced version of JetFlash elite - highly recommended:
http://www.transcendusa.com/Support/DLCenter/Software/Setup_JFSW2.exe
I think you know about this page, but here's a link to save you googling:
/index.asp?axn=SRH2&ModNo=107&ItemID=TS2GJFV30
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | Transcend T.sonic 610 MP3 Player
Cant copy DVD software to SD
write me at vince954@yahoo.com if this does not work. On the dvd there is also a zipped version of the map_sd directory, copy it to your pc and unzip it and then copy the contents to your sd card. as the file is so large, some dvd drives have issues reading it.
Aug 16, 2008 | Fine Digital FineDrive 400 GPS Receiver
Cannot copy files (music, photo etc) from int memory to memory card
i'm having the same problem. can't transfer files onto memory card. when i try, it says "no entry". someone please help.
Jan 03, 2008 | Samsung SGH-D820 Cellular Phone
Transcend 8GB SSD, 2.5- Inch, IDE, SLC Hard Drive Logo
115 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
