Question about Garden
What oil do i need to use in my titan 6500 diesel generator?
  • 8,404 Answers
  • 1,675 Answers
A standard diesel graded motor oil is ok to use in these like 10w40 sj/a2 will be just right
Posted on Aug 07, 2010
Kipor generator 6500 starting and stoping after few minutes running what could be the problem Diesel model
Im taking it as the engine is cutting out?
Is this a diesel model?
Try, low oil cut off, fuel tank not vented correcly, fuel blockage.
Feb 25, 2018 | Kipor Electrical Supplies
7500 titan diesel gen. About 4 hrs. Into run. It will trip to stop an shut down. Not low oil. Then flip it back to run an it will crank back up an run another 4-5 hours. What is doing this.
it could be a flow sensor in the fuel line to stop the engine before air gets sucked in form low fuel or broken lines
I would first go to the tank vent and ensure that it is not blocked , restricting fuel flow to the pump
there is nothing obvious as the engine would not restart so look for the simple things that trip the stop system
if there is any electronic control , it may be a slowly overheating component that needs checking but I would leave that to a last thing to check
Oct 19, 2015 | Diesel Electrical Supplies
Why woun't my 6500 ransond generator start its a diesel
See id it is actually pumping fuel and if so see if the glow plugs are getting hot.
Oct 07, 2014 | Cars & Trucks
Generator wont start up unless i spray starter fluid into it
This sounds like a dirty carbureator. Just bad enough that it won't start cold.
Mar 29, 2014 | Electrical Supplies
Northstar 6500 generator oil pressure switch wiring
Need to look at what your talking about, too many possibilities.
Jan 18, 2013 | Northstar Generator 10 Hp, 6500 Watt,...
I have a 6500 lp onan marquis generator in my rv. It starts then stops after 15 seconds or so. I did a code check on it using the manual and it read code 47. Controller not reading generator running. Any...
ONANS ARE PRETTY QUIRKY AS IT IS NOT CONSUMER FRIENDLY. THE GENSET IS DESIGNED FOR ROUTINE AND SIMPLE MAINTENANCE PERFORMED BY THE OWNER, AFTER THAT, U WILL NEED TO TAKE IT TO THE NEAREST DEALER OR CUMMINS DIESEL REPAIR SHOP.
Jan 10, 2010 | Watts Onan Portable Generator - 5000 ,...
Yamaha 6500 watt diesel runs but usually shuts
First thing to monitor is the fuel solenoid power. See if it is the thing that goess away to cause shutdown.
Tracing this back there is only a few things that control this: The battery, the low oil shutdown switch, and the run switch, and associated wiring.
If I were to ventture a guess, I would put money on the low oil shutdown switch.
Aug 24, 2009 | Taylor Skid Mount Diesel Generator Set 30...
Diesel mixed with oil in the sump
You run again the generator but before running, check & mark the oil level. Then stop the generator & wait until the oil settle to the bottom of oil pan. Check the oil level again & if the oil level is higher than the marking before that's means you have an engine gasket leak.You need to replace that gasket.
Mar 19, 2009 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Just won't start
check the spark plug after a failed attempt to start. If dry, then no fuel is entering engine.
Did you leave old fuel in carb? if so, your carb probably is dirty: old gasoline deposits varnish, gum, and you will need to dissassemble carb and clean it.
Nov 14, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Garden Logo
108 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
