I have an asko w6021 washer that has a new board and it will not take on water.I also put on a new water selinoid . still no water and no movement. the door lock does work. stumped?
  • jimmyzinstal Aug 09, 2010
    thank u for your time
    President:
  • 1,554 Answers
There can be no movement unless the tub is filled with water to the appropriate level. Since a new board and a new water inlet valve is installed, you should check the continuity or the physical condition of the wire harness connecting the two. Make sure the wire harness is intact and fully inserted to both the board and the water inlet valve assembly.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 08, 2010
  • 15,935 Answers
Did you replace the entire valve - or just the solenoid on the valve?
Thanks!!
Posted on Aug 07, 2010
  • jimmyzinstal Aug 07, 2010
    complete assy its the three solenoid valve
    when u hold the start /stop in to start mach you can hear the relay on the board click but mach does nothing
Asko w6021 started to fill with water and then shorted out the power any suggestions?
not much help sorry but is possibly the motor shorting, try turn the drum a little before you reconnect and see if it still shorts. I have had an element rupture and therefore be soaked in water and thus causing the short. Sorry I cant help more
Mar 04, 2013 | Asko W6021 Front Load Washer
My ASko washer machine will not start up, all I hear is a short humm when I press the start button. I took the cover off and noticed the control board has a burned chip on it. There is also a resistor with...
Sounds like the control board is fried. If you have gotten it open here is a link for a new board:
http://www.superiorapplianceparts.com/shop/asko-washer-control-board/?q=/shop/category/washer/asko/
Good luck! And make sure the thing is unplugged before you work on it!
Joseph
Apr 04, 2011 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer error detected "F3 Outlet Blocked". How to solve this problem?
The drain access is at the bottom left of the washer. Insert a screw driver in the right side of the cut-out and and gently pry open. Open the drain pump. You will need a small container and a towel to help catch the water that will be coming out. After letting all the water out, clean out any objects in the drain pump. After cleaning out drain pump, put everything back together and restart washer.
Feb 05, 2011 | Asko W6021 Front Load Washer
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Jun 15, 2010 | Asko W6021 Front Load Washer
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
Asko Washer W6021 Problem
CHECK THE BRUSHES ON THE MOTOR, FOR BEING WORN DOWN!
REGARDS........TREVOR. FLEETWOOD UK.
Mar 09, 2009 | Asko W6021 Front Load Washer
Asko W6021 won't start
change the carbons theres nothing wrong with the board
Jul 30, 2008 | Asko W6021 Front Load Washer
Asko w6021 still not working
check that all the plugs are in the correct position on the board,you may have introduced the fault,because the only fault you had to start with was worn carbons.did you break off any links maybe J4 etc if the original board had the link taken off and you dont do it on the new board you will hard program the new board and will have to order another board. is the machine heating.put on wool wash and select heating you should hear it start to heat.let me know.thanks Ian
Mar 31, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Nov 01, 2007 | Asko W6021 Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
