Question about GE Dishwashers
Hello, my 1992 GE potscrubber 630 is not cleaning well at the moment. Could vinegar or a little bleach help if it something is clogged with hardwater or food particles. thx.
My GE Potscrubber 630 dishwasher leaves a white film on all of the dishes. Is there a filter that can be cleaned out?
Posted on Jan 22, 2011
Bleach stains on black jeans
Bleach doesn't stain ! it removes the dye from the fabric.
I would suggest trying to re dye the fabric with a black dye as Jeans material might be more successful .
Synthetic fabric is not as easy to re dye end up using a permanent black marker on Synthetic Shirt that I got bleach on. .
Mar 12, 2014 | Clothing
How to clean
Hello Lisa Rucker - I suggest to first rub some bleach around the door gasket. Let this dry. Next rub some vinegar around the door gasket. Let this dry. (Do NOT mix the bleach and vinegar) Then run a hot empty load of bleach in all three dispensers. Put 1/2 cup of bleach in the detergent dispenser and fill the softener and bleach dispenser to the max fill line with bleach. Once that is done repeat the process with vinegar. Please make sure you run a load of towels or some sort of items that will not matter if you get a little bleach on them once this process is done.
Jan 09, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer Feels like there are gallons of water in the bottom
Hello Holly Davis -
Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately. However, regarding the odor my advice to you is first rub some bleach around the door gasket. Let this dry. Next rub some vinegar around the door gasket. Let this dry. (Do NOT mix the bleach and vinegar) Then run a hot empty load of bleach in all three dispensers. Put 1/2 cup of bleach in the detergent dispenser and fill the softener and bleach dispenser to the max fill line with bleach. Once that is done repeat the process with vinegar. Please make sure you run a load of towels or some sort of items that will not matter if you get a little bleach on them once this process is done.
Dec 11, 2012 | Frigidaire ATF6000ES Front Load Washer
How to clean my washing machine Electrolux Front Loader
Hello -
First rub some bleach around the door gasket. Let this dry. Next rub some vinegar around the door gasket. Let this dry. (Do NOT mix the bleach and vinegar) Then run a hot empty load of bleach in all three dispensers. Put 1/2 cup of bleach in the detergent dispenser and fill the softener and bleach dispenser to the max fill line with bleach. Once that is done repeat the process with vinegar. Please make sure you run a load of towels or some sort of items that will not matter if you get a little bleach on them once this process is done.
Sep 21, 2012 | Electrolux EW1000i Front Load Washer
Problem is rotten smell inside GE profile fridge. I've checked for rotten food-none; taken everything out and cleaned inside plus all shelves with added bleach in water. Smell is still there. I...
Hi, pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. You can also mix 1/3 cup of bleach and 2/3 cup of water , and pour down drain tube (rear bottom in freezer section. Too much bleach and the smell of bleach would be circulated by the fan to the room, so be sure to add water. Finally, another popular methods of removing fridge odor include washing the entire fridge out with a vinegar and water solution, placing fresh coffee grinds or boxes of baking soda on each shelf and even using trays of cat litter.
May 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE potscrubber 940 isnt cleaning properly. Glasses cloudy, some dishes still dirty. Is there a filter that can be checked?
You need to add some vinegar. Depending on your water as much as 4-5 cups per load. I have had a Potscrubber for close to 10 years and discovered that they clean beautifully as long as you don't skip the vinegar.
Mar 01, 2011 | Dishwashers
GE Potscrubber 950 not cleaning very well takes at least twice and there is still food on most of the dishes
Clean out recirculating drain on inside of unit and try running bleach, maybe a 1/2 through a full cylce.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 26, 2009 | Dishwashers
GE potscrubber 700
upc leaks when dishwasher is emptying
May 12, 2008 | GE Dishwashers
CLEANING OUT CAT DANDER ETC FROM WASHER
Quenie, vinegar will not harm your washer at all. Place it in the detergent side of your dispenser and run a Hot wash cycle. Don't mix chemicals, though... if you choose to clean your machine with bleach, for instance, don't use additional cleaners along with it. Vinegar only, bleach only... you get the point.
You may want to run a "water only" Hot wash cycle with bleach (no clothing/towels) after your Son has finished his laundry. This may help alleviate your allergy problem.
For regular maintenance on your washer, you ought to try something like this. It'll keep your washer smelling great.
Nov 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
1,282 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
