Question about Acer Computers & Internet
How to reload to factory settings - Acer Computers & Internet
    Master:
  • 344 Answers
When you turn on the computer hold the ALT key and keep pressing F10 key until you get the menu.. there it will give you options on how you want to 'reset' the system... when it asks for a password if you haven't already applied a password to it the default is 000000 (six zero's)
Posted on Aug 07, 2010
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
I have a samsung recovery media disc sp1 does it contain factory settings i got with the laptop
Hard to say from my desk. If you reloaded Windows , you didn't mention which version, all you need to do is Windows and Samsung updates. What Factory settings have you lost? You can put the DVD or CD in the laptop and reboot from disk and see what is on it and abort/cancel or try repair my computer.
Dec 03, 2012 | Computers & Internet
My default IP ADRESS is192.168.1.1, and am trying to change my router password for wireless connection
If you ever lose your settings or if your settings are changed and the router is not functioning properly, you can come to this area to restore your saved settings from the backup file you created. Click Browse to locate the backup settings file you previously created. When you have located it, click Restore and the settings saved within this file will be applied to the router. If you did not create a backup file, you may need to restore the factory default settings.
device3.gif Factory Settings If you ever want to erase all personal settings of your router, come to this area and click Reload to restore the factory default settings. All the current settings will be lost. If you change the router's configuration and it stops functioning properly you can reload the factory settings to fix it.
device3.gif The other method to restore the factory default settings is to press in and hold the RESET button on the Wireless MAXg Router for between five and ten seconds. You will lose all of your personal settings if you restore the factory default settings. You might need to do this if you are unable to access the Web User Interface or have forgotten your password.
Nov 07, 2010 | U.S. Robotics MAXg USR5461 (738168036790)...
Need to know the password
Or;
http://www.usr.com/support/5461a/5461a-ug/install.html
Nov 04, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
How do i do a factory reload for acer desktop
Hi! follow the steps to reload the system to factory settings:
Restore without a recovery cd:
This recovery process will restore the C: drive to the original software content that is installed when you purchase your notebook. It is important to back up all data files before you use this option.
1.Restart the system.
2.While the Acer logo is showing,press <Alt>+<F10> at the same time to enter the recovery process.
3.The message "The system has password protection.Please enter000000." is displayed.
4.Enter six zeros and continue.
5.The Acer Recovery main page appears.
6.Use the arrow keys to scroll through the items(operating system versions) and press <Enter> to select.
hope this helps...
May 20, 2010 | Acer Veriton 5800 PC Desktop
There is a messeg on my screen says reload
Your Blackberry probably just needs to be restored to factory settings. The steps you need to take to restore the blackberry firmware are described at this website: Restore Blackberry to factory settings.
Mar 20, 2010 | RIM BlackBerry Storm 9530 Smartphone
I am trying to reload my tiny computer to factory settings with the reload disc that was supplied but when i press the R on my keyboard for reload it does not work. Can someone please help.
Depending on what type of computer you have, most computers have a key you can press during start up that will restore the computer to factory settings, I know the eMachine's have this function as a F11 as with the HP's.
Jan 30, 2010 | Computers & Internet
WIPE AND RELOAD TO FACTORY SETTINGS. HAVE A
Good articles here and here. Hp also has some good info particular to your system here and here. Good reliable malware removal protocols here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 17, 2009 | HP Pavilion dv9000z Notebook
Need to restore acer to factory settings
just boot from your backup disk. it will guide you to reload the Operating system (factory default).
FYI, if you haven't delete the recovery partition, you can use alt+f10 to reload. just press alt+f10 during boot.
Jul 31, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
71 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
