Question about Fisher and Paykel GWL11 Top Load Washer
My top loading washing machine stops several times during the washing cycle and starts beepng sound and some times lit first and seventh light. When it advanced to spinning spin well
  • 15,935 Answers
This is a timer issue.
Replace it to fix the problem.
Thanks!!
Posted on Aug 07, 2010
UL in digital display coming on during wash cycle. When washer is spinning during wash cycle it is very loud and the washer moves. We have had it repaired a couple of times. It will work for several...
Hi
Thanks for using FixYa. ULis displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 27, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
The third, fifth & seventh light come on when the washer is trying to fill with water at start of wash cycle.
Hi just read your posting.Sorry to ask you this but could you confirm the lights that are lit.Starting from the left of the machine to the right which ones are lit when the machine is beeping.Is it the 2nd and 4th or the 5th and 7th ---etc---?The reason I am after this information is there is no fault code with that number.Looking forward to your reply.
Jul 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer stops during rinse cycle and isn't easily restartable....
Sounds like the contacts in the timer has a problem. Unplug washer. Remove the back of the washer and spray WD40 in the timer. Put towels around and under to to collect excess runoff.
Rrotate washer dial 25 times and spray some more wd40. Rotate 25 times again. Do a wash load. If it works put everting back together.
May 04, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer stops and must be restarted flashes F51
there is a updated wiring harness and sensor on the the bottom of this tub on the motor. It needs replaced
Nov 13, 2008 | Kenmore 22422 Top Load Washer
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
The washer has been stopping during or after the wash cycle. It then begins to beep about 1 time per second. The 3rd and 4th light in the wash cycle and the first light in the rinse cycle are lit. The...
Plug off the wall. Open up behind the machine. Check to see if any wires loose. See that the wires from the control panel to the motor are plugged in tight. Vibration from the machine could loosen the wires and give the display wrong readings, or disrupt the run.
Rate me please..........
Dec 26, 2007 | Fisher and Paykel GWL11 Top Load Washer
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
Aug 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Beeping and odd light sequence
I have the same problem with my 603 washing machine stopping in the middle of a cycle and i would have to go and manually advance the wash. I have just replaced the top curcuit board with a new one. can you please help or offer a solution. Thank you.
Jun 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
