Question about Sanyo 42 in. LCD TV
Have a Sanyo 42 in. LCD Tv , and the led power light on the front is flashing and the Tv will not come on . Is there a way to fix my problem cheap ?
My Sanyo LCD-42E3 does the same thing, but it's only a few days old. It was working fine up to a few days ago. Red LED comes on when it's plugged in, but will not turn on.
Other set-top devices will power on sharing the same surge protecto, or when plugged directly into the same outlet the TV was using.
Posted on Aug 23, 2010
  • 11,361 Answers
Not likely, shop repair can be from $200 and up.
You may have bad power supply or backlight inverter board problems.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 07, 2010
How much does picture tube for 42 inch flat screen Sanyo TV cost
There is no picture tube in a modern flat screen TV.
And unless it's physically broken, it's usually something else that has failed and not the screen.
A picture tube is a CRT (cathode ray tube) that sends electrons from the back to the front to light up different color phosphorous dots.
A modern flat screen TV on the other hand is LCD (liquid crystal display) that turns on and off to allow backlighting through multi colored filters. (LED TV also uses a LCD screen, the only difference is the backlighting is LED and not fluorescent lamps.)
Nov 26, 2016 | Sanyo Televison & Video
Sanyo 42 inch LCD TV - Could the back light inverter be the cause of not getting any power? There is a red light on it and that is all
> Could the backlight inverter be the cause of not getting any power?
If the set uses a fluorescent backlight (many use LEDs instead) it will not prevent it from turning on so at least audio should be present.
With no backlight. you will not see any video but the set will receive and audio will work.
If you replaced the (main) power supply with a 'pull' (removed from another set) it may have failed like your original one.
Jun 25, 2015 | Sanyo Televison & Video
I plug in my Vizio TV and it will not power on however the orange light in the front is flashing.
Sounds like mine I replaced the Bridge Inverters ( easy job ) , and worked great after that. I got mine from Shop Jimmy dot com paid $85 cheap fix not like $300 - 500 ! you may pay for repair man.
Jul 23, 2014 | Vizio VO420E 42 in. LCD TV
How to troubleshoot b159-001 power board
https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Aug 13, 2013 | Sanyo DP42746 42 in. Plasma Television
Tv is coming on for brief period and shutting down also constant flashing of green led light on front of tv
I have a plasma that does the same thing. I don't know but have been told it is probably the power supply.
Jan 11, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a Sanyo 42 inch Mode Number: DP42647. I bought it 2.5 years ago, and suddenly, the video is out. The sound is ok, as well as the "power" green LED. By looking at other forums, it seems...
I would just replace the TV, because any guess you make without the testing and equipment is just an expensive guess. New TV's are cheap by comparison. I have had a lot of TV'ds and the best do far is my Vizio 42 Inch LCD. 11 years old no issues.
May 20, 2017 | Sanyo 42 in. LCD TV
Blue light flashes on front of tv cannot get set to turn on
my sanyo 37 inch was workin fine put it on the wall now the blue light on the front is flashin like mad screen wont *** on got the clicky sound as if i was turnin it over by the side any ideas ??
Aug 21, 2010 | Sanyo 42 in. LCD TV
Hello my Sanyo dp42849 42 inch has no picture and no sound. when i turn on the tv a green light in the bottom right hand corner comes on and occasionally flashes off and then back on.
First, you need to know the sub-model of your TV.
It is called "chassis" and is shown on the back of the TV on the label where the model number is shown.
For example it can be "P42849-00" or "P42849-01".
Then search at www.coppelltvrepair.com/search or just go to www.coppelltvrepair.com and enter the link for SANYO DP SERIES to search for that.
Here's an example of a repair service (note it may NOT be the one for your exact model though!):
http://www.coppelltvrepair.com/p/41/sanyo-dp42849-p42849-00-does-not-power-on-repair-service
Hope this helps!
Jul 16, 2010 | Sanyo 42 in. LCD TV
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sanyo  42 in. LCD TV Logo
346 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
