Question about AEG Lavamat 88840 Front Load Washer
Motor huming bowl not spinning - AEG Lavamat 88840 Front Load Washer
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
Sounds like the drive belt has come off. may be something under the drum that caused it to come off.is there any error code.
Posted on Aug 07, 2010
Pushed start switch and making huming noise and won't start ge gas clothes dryer model dvlr223gg8ww
In most cases the motor is seized or something is preventing it from spinning (seized drum wheel for example).
Feb 10, 2015 | GE Dryers
The water wont go down and the motor is huming. What can I do?
Humming as in has power but appears to not be doing anything? If so, it's likely stalled because of a jam or clog. Going to have to put on some gloves etc and explore the tank for starters. My recollection is that Saniflo has all their installation, maintenance manuals online (Google is your friend ;) ). Be sure the unit is unplugged before opening up the tank! It's possible, although less likely that the clog is in the piping leading to the macerator or in the bowl, you can try a plunger also... Good luck!
Jul 09, 2011 | Saniflo Sanibest macerator with multiple...
I have a eziset 605 it will wash the clothes but when it comes to the spin cycle it wont spin but the agitator still turns causing the clothes to become tangled on one side causing to unbalance. i have...
If you look you will find that when the machine is supposed to spin that is the spin bowl turn. Instead of the spin bowl turning, the agitator is turning and so BALLING the clothes. So......it is most likely a *** designed machine so it has a brake arm and pawl, operated by a small motor or a solenoid. This motor or solenoid is most likely not pulling the brake lever and releasing it to allow spin action. So check the release of the brake. Tony the technician down under....
Apr 02, 2011 | Washing Machines
Gw 612 washes ,drains wont spin fault comes up as on off off off on
Hi just read your posting.Now the problem you might have, and I have had before, is the motor is not turning the bowl far enough when it is starting to spin and therefore the machine thinks the bowl is not turning.To get your machine spinning 1st undo the 2 screws under the lid so you can lift the hob up to see the bowl.Select a spin cycle and hit start while you are holding the hob up enough to see the bowl.The reason for lifting the hob instead of the lid to see the bowl is if you lifted the lid the machine would not work because of the lid switch.Now when you are holding the hob up to see the bowl make sure the lid is closed so the machine will work.Now once you have started the spin cycle you will see the bowl turning one way then reverse and turn the other way.While you are holding the hob up when the bowl turns in 1 direction help turn the bowl in that same direction with your hand.Once the bowl reverses help turning it in that direction also.This will make the machine register that the bowl is loose enough and will kick to spin.Once it is spinning let it spin for the cycle and you should be fine.Please reply for further help if needed,Good luck
Jun 16, 2010 | Washing Machines
Huming when start button pused, no start
Sounds like the motor bearing is bad and seized or nearly seized. Could be something fell into the fan blades and has it jammed.
Feb 26, 2010 | Amana Dryers
My roper will fill and agitate but will not spin and can hear huming sound.
You will need to replace the motor coupler pt # 285753A. Go to appliance guru for directions on how to replace.
Jan 15, 2010 | Washing Machines
Lihgt huming from motor not washing
The starting capacitor may be bad but more likely the motor is stuck with a bone fragement or it is a bad motor.
Aug 02, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Motor works but will not turn on
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl asssembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Jan 01, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
My brand new Cuisinart 14 cup food processor won't turn on. All the components are locked in place and it's plugged in. Help
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Nov 23, 2008 | Cuisinart DLC-5 Food Processor
AEG Lavamat 88840 Front Load Washer Logo
83 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
