Hifi hi there, my hitachi micro hifi smelt like it was burning, anyway its not working mow. Could u tell me what the problem is and how much it could cost to fix, if not fixable do u know where i will be able to purchase just the amplifier from the amp is a hitachi ax-m66. thanks peter ,
    Sergeant:
    Champion:
  • 319 Answers
Unit obviously has circuit problems, Have serviced
Posted on May 07, 2008
I have a 42" Hitachi TV (model UT42V702) that was off, but plugged in, and I smelt an electrical burning. Small hint of smoke coming from top right of tv. Is it a relatively cheap fix or trash it?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 13, 2016 | Hitachi Televison & Video
SET UP GUIDE
I am sorry to say that there is no way for you to get into the region selection menu once you have changed your region once . The only people who can fix/change this for you are the folks at Hitachi. It's a pity that you changed your region from all to 2...I always prefer all regions...
Dec 25, 2007 | Audio Players & Recorders
My bush Tv remote turns hifi even when it is not pointing at the Hi fi which is at the other end of the room
Most likely the remote control uses an RF control signal rather than an IR signal. IR signals are directional; RF signals are not - they are range-based.
Mar 02, 2015 | Philips Televison & Video
My LED screen is broken, how can i fix this and if I get someone to fix it how much would it cost ? - also any recommendation on where to get it fixed ?
There is to repair fix to a broken LCD screen. Only replacement with a new one can be done. The cost will come around 2/3rd of the total cost of a new TV; [including the price of the LCD screen + Service charges].
Nov 16, 2014 | Hitachi Audio Players & Recorders
IC-736 total failure whilst on air, fuse OK, nothing smelt burning etc, not over heated, no voltage surge, SWR was moderate but protected by APC circuit. Totally dead now.
Hi Jack, (No Pun Intended)
As this is such a fine radio, I would take it to the radio doctor for a once over check-up, The technician will find the problem and give you an estimate of cost to repair the fault, Take care of you radio, it's a great unit that should give you many more years of service.
I hope this advice is of help to you.
Cheers,
Peter
Dec 02, 2012 | ICOM Informatique BP-84SM,...
It doesn't want to work anymore!! There appears to be no power to the Disc Player, Cassette Deck or the Sound Processor? The Amplifier screen displays F61 Hope you can be of assistance Thank you
With my crystal ball I can see its a Technics 4 part Hifi micro system you have although the image is just too fuzzy for me to tell which model.!
Joking apart...Your power amp module has a blown channel. These are specific Technics modules and some for the 3/4/5 channel units are quite expensive UK £40-80 just for the module + fitting costs
No DIY fix I'm afraid
Sep 04, 2010 | Audio Players & Recorders
The dyson smelt of burning then stopped sudenly
Hi the burning smell is from the Motor. Your Motor has burnt out. You will need it replaced.
A new motor will cost around £40
If you would like us to advise you on how to swap the motors over then please order the motor and come back to us.
Thanks you
Aug 19, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Faulty micro switch in Hitachi NR90GC
Hi, had the same problem. After market micro switch replacement for Hitachi NR 90GC from RS Components Stock number 682-1888 MPN; D2HWC203MR.
Note; this requires soldering in with heatshrink and cutting flyleads to correct length. Part of the alignment issue can be the handle screws working loose over time with use. Don't force anything back when assembling and use a little grease on contact parts.
Mar 17, 2009 | Hitachi NR90GC 3 1/2" Gas Powered Clipped...
Technics cd hi-fi
hi bobro, when burning the cds, make sure that you are burning it as an audio cd, as this player does not support mp3 formats, just normal audio cds... hope this helps!
Feb 11, 2007 | Technics SCEH790 CD Shelf System
412 people viewed this question
 Grubhead
Grubhead
