Question about GE WBSR3140DW Top Load Washer
Washer wont go into rinse cycle-just sits and hums
The water pump is probably jammed or broken
Posted on May 03, 2008
  • tsakatsaka May 03, 2008
    check the water pump. it may be jammed or broken.
GE washers are junk! Mine lasted less than one year. Junk!!!
Posted on Apr 28, 2008
Stops rinse cycle
Hi Alex - Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. If you noticed a humming noise, it could either be a clogged drainage hose or pump that needs to be cleaned, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Jun 24, 2013 | Frigidaire GLWS1233A Top Load Washer
SM 8525492A whirlpool washer rinse cycle no water comes out, just hums
when the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
Apr 25, 2013 | Washing Machines
Fisher and Paykel washer will not do rinse cycle.
with the lid up, can you turn the washing drum around by hand, if the answer is no disconnect the power plug and see if it makes any difference to amount of friction. if the friction disappears you may have a faulty main board
Nov 27, 2011 | Fisher and Paykel Washing Machines
Washer stops at rinse cycle
Hi There,
Sounds like you need a new timer. Hope this helps and thank you for using FixYa!
Mar 30, 2009 | Maytag Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer hums on rinse cycle
It sounds as if you are using WARM water for the wash cycle since your complaint begins with the rinse cycle. The rinse cycle generally uses COLD water, so I must deduce that your washer is not filling up for the rinse cycle. The humming sound is likely coming from the fill valve being starved for cold water.
Investigate your cold water supply to the washer and if you have good supply, you may want to replace the fill valve.
Let me know what you find...Thanks for contacting FIXYA.com
May 27, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
GE WBSR3140DW Top Load Washer Logo
88 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
